REST API reference
Create the local user configuration for an SVM
Creates a local user configuration for a Storage Virtual Machine (SVM). This is typically used to manage access control within your storage environment by defining user accounts specific to an SVM.
HTTP method and endpoint
POST /protocols/cifs/local-users
Introduced in
ONTAP 9.9
Usage notes
Creates the local user configuration for an SVM.
Important notes
  • The user name can contain up to 20 characters.
  • The user name cannot be terminated by a period.
  • The user name does not support any of the following characters: " / ? [ ] , : \| < > + = ; ? * @ or ASCII characters in the range 1-31.
  • The password must be at least six characters in length and must not contain the user account name.
  • The password must contain characters from three of the following four categories:
  • English uppercase characters (A through Z)
  • English lowercase characters (a through z)
  • Base 10 digits (0 through 9)
  • Special characters: ~ ! @ # 0 ^ & * _ - + = ` ? \| ( ) [ ] : ; " ' < > , . ? /
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the local user.
  • name - Name of the local user.
  • password - Password for the local user.
Default property values
If not specified in POST, the following default property value is assigned:
  • account_disabled - false
  • vserver cifs users-and-groups local-user create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
account_disabled
boolean
Indicates whether the user account is enabled or disabled.
description
string
Description for the local user.
full_name
string
User's full name.
membership
array[membership]
Specifies local groups of which this local user is a member.
name
string
Local user name. The maximum supported length of an user name is 20 characters.
password
string
sid
string
The security ID of the local user which uniquely identifies the user. The user SID is automatically generated in POST and it is retrieved using the GET method.
svm
svm
Example request
  "description": "This is local user.",
  "full_name": "user name",
  "membership": [
      "name": "SMB_SERVER01\\group",
      "sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
  "name": "SMB_SERVER01\\user",
  "password": "string",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of local user records.
records
array[local_cifs_user]
  "num_records": 1,
  "records": [
      "membership": [
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262278
Name and password are required fields.
655399
CIFS server must exist to create a local user.
655660
The operation is allowed only on data SVMs.
655661
The user name should not exceed 20 characters. Also full_name and description should not exceed 256 characters.
655665
The user name must not match the CIFS server name of the specified SVM.
655668
The specified user name contains illegal characters.
655675
The local domain name specified in user name doesn't exist.
655682
The user name cannot be blank.
655733
The password does not meet the password complexity requirements.
655736
The specified user name already exists.
2621706
The specified SVM UUID is incorrect for the specified SVM name.
string
membership
name
string
Local group name. The maximum supported length of a group name is 256 characters.
sid
string
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method.
svm
name
string
uuid
string
local_cifs_user
account_disabled
boolean
description
string
full_name
string
User's full name.
membership
array[membership]
name
string
password
string
sid
string
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
