REST API reference
Create the NFS configuration for an SVM
Creates an NFS configuration for a storage virtual machine (SVM) to enable and define how NFS protocols interact with the SVM. This is typically done to set up or modify NFS services for the SVM.
HTTP method and endpoint
POST /protocols/nfs/services
Introduced in
ONTAP 9.6
Usage notes
Creates an NFS configuration for an SVM.
Required properties
  • svm.uuid or svm.name - Existing SVM for which to create the NFS configuration.
Default property values
If not specified in POST, the following default property values are assigned:
  • enabled - true
  • state - online
  • transport.udp_enabled - true
  • transport.tcp_enabled - true
  • protocol.v3_enabled - true
  • protocol.v3_64bit_identifiers_enabled - false
  • protocol.v4_id_domain - defaultv4iddomain.com
  • protocol.v4_64bit_identifiers_enabled - true
  • protocol.v4_enabled - false
  • protocol.v41_enabled - false
  • protocol.v40_features.acl_enabled - false
  • protocol.v40_features.read_delegation_enabled - false
  • protocol.v40_features.write_delegation_enabled - false
  • protocol.v41_features.acl_enabled - false
  • protocol.v41_features.read_delegation_enabled - false
  • protocol.v41_features.write_delegation_enabled - false
  • protocol.v41_features.pnfs_enabled - false
  • vstorage_enabled - false
  • rquota_enabled - false
  • showmount_enabled - true
  • auth_sys_extended_groups_enabled - false
  • extended_groups_limit - 32
  • positive_cached_credential_ttl - 7200000
  • qtree.export_enabled - false
  • qtree.validate_export - true
  • access_cache_config.ttl_positive - 60
  • access_cache_config.ttl_negative - 30
  • access_cache_config.ttl_failure - 1
  • access_cache_config.harvest_timeout - 3600
  • access_cache_config.isDnsTTLEnabled - false
  • vserver nfs create
  • export-policy access-cache config show
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
access_cache_config
access_cache_config
boolean
Specifies whether or not extended groups support over AUTH_SYS is enabled.
enabled
boolean
Specifies if the NFS service is administratively enabled.
integer
Specifies the maximum auxillary groups supported over AUTH_SYS and RPCSEC_GSS.
integer
Specifies the time to live value (in msecs) of a positive cached credential
protocol
protocol
protocol_access_rules
qtree
qtree
rquota_enabled
boolean
Specifies whether or not the remote quota feature is enabled.
showmount_enabled
boolean
Specifies whether or not the showmount feature is enabled.
state
string
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests.
svm
svm
transport
transport
vstorage_enabled
boolean
Specifies whether or not the VMware vstorage feature is enabled.
Example request
  "extended_groups_limit": 32,
  "positive_cached_credential_ttl": 7200000,
  "protocol": {
    "v4_id_domain": "string"
  "protocol_access_rules": {
    "cifs_access_type": "string",
    "nfs3_access_type": "string",
    "nfs4_access_type": "string"
  "state": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of NFS Server Records
records
array[nfs_service]
  "records": [
      "protocol": {
      "state": "string",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
3276916
Vserver is not running
3276994
Kerberos must be disabled on all LIFs on Vserver before adding or removing AES encryption. Disable Kerberos on the LIF and try again
3277038
Cannot enable \"showmount\" feature because it requires an effective cluster version of Data ONTAP 8.3.0 or later
3277049
Cannot enable \"showmount\" feature on ID-Discard Vserver. Ensure that the Vserver is initialized and retry the command
3277052
NFSv4.x access to transitioned volumes in this Vserver could trigger conversion of non-Unicode directories to Unicode, which might impact data-serving performance. Before enabling NFSv4.x for this Vserver, refer to the Data and Configuration Transition Guide
3277069
Cannot disable TCP because the SnapDiff RPC server is in the \"on\" state
3277089
Attempting to create an NFS server using 64-bits for NFSv3 FSIDs and File IDs on Vserver. Older client software might not work with 64-bit identifiers
3277099
Domain name contains invalid characters or it is too short. Allowed characters are: alphabetical characters (A-Za-z), numeric characters (0-9), minus sign (-), and the period (.). The first character must be alphabetical or numeric, last character must not be a minus sign or a period. Minimum supported length: 2 characters, maximum of 256 characters
string
access_cache_config
harvest_timeout
integer
Specifies the time after which an entry is deleted from the access cache, if unused.
isDnsTTLEnabled
boolean
Specifies whether Dns TTL is enabled.
ttl_failure
integer
Specifies the time to live value for entries for which a failure was encountered, in seconds.
ttl_negative
integer
Specifies the time to live value of a negative access cache, in seconds.
ttl_positive
integer
Specifies the time to live value of a positive access cache, in seconds.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
v3
The NFSv3 operations
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
v4
The NFSv4 operations
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
v41
The NFSv4.1 operations
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
metric
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3
v3
v4
v4
v41
v41
v40_features
acl_enabled
boolean
Specifies whether NFSv4.0 ACLs is enabled.
boolean
Specifies whether NFSv4.0 Read Delegation is enabled.
boolean
Specifies whether NFSv4.0 Write Delegation is enabled.
v41_features
acl_enabled
boolean
Specifies whether NFSv4.1 or later ACLs is enabled.
pnfs_enabled
boolean
Specifies whether NFSv4.1 or later Parallel NFS is enabled.
boolean
Specifies whether NFSv4.1 or later Read Delegation is enabled.
boolean
Specifies whether NFSv4.1 or later Write Delegation is enabled.
protocol
boolean
Specifies whether 64-bit support for NFSv3 FSIDs and file IDs is enabled.
v3_enabled
boolean
Specifies whether NFSv3 protocol is enabled.
v40_enabled
boolean
Specifies whether NFSv4.0 protocol is enabled.
v40_features
v40_features
v41_enabled
boolean
Specifies whether NFSv4.1 or later protocol is enabled.
v41_features
v41_features
boolean
Specifies whether 64-bit support for NFSv4.x FSIDs and file IDs is enabled.
v4_id_domain
string
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol.
cifs_access_type
string
Access available for the CIFS protocol.
nfs3_access_type
string
Access available for the NFSv3 protocol.
nfs4_access_type
string
Access available for the NFSv4 protocol.
qtree
export_enabled
boolean
Specifies whether qtree export is enabled.
validate_export
boolean
Specifies whether qtree export validation is enabled.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
v3
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
v4
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
v41
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
statistics
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3
v3
v4
v4
v41
v41
svm
name
string
The name of the SVM.
uuid
string
transport
tcp_enabled
boolean
Specifies whether TCP transports are enabled on the server.
udp_enabled
boolean
Specifies whether UDP transports are enabled on the server.
nfs_service
access_cache_config
access_cache_config
boolean
enabled
boolean
integer
integer
protocol
protocol
qtree
qtree
rquota_enabled
boolean
showmount_enabled
boolean
state
string
svm
svm
transport
transport
vstorage_enabled
boolean
nfs_service
access_cache_config
access_cache_config
boolean
enabled
boolean
integer
integer
protocol
protocol
qtree
qtree
rquota_enabled
boolean
showmount_enabled
boolean
state
string
  • online - NFS server is ready to accept client requests.
  • offline - NFS server is not ready to accept client requests.
svm
svm
transport
transport
vstorage_enabled
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
