REST API reference
Create an NFS configuration for an SVM
POST /protocols/nfs/services
Introduced In: 9.6
Creates an NFS configuration for an SVM.
Required properties
  • svm.uuid or svm.name - Existing SVM for which to create the NFS configuration.
Default property values
If not specified in POST, the following default property values are assigned:
  • enabled - true
  • state - online
  • transport.udp_enabled - true
  • transport.tcp_enabled - true
  • transport.rdma_enabled - true
  • protocol.v3_enabled - true
  • protocol.v3_64bit_identifiers_enabled - false
  • protocol.v4_id_domain - defaultv4iddomain.com
  • protocol.v4_64bit_identifiers_enabled - true
  • protocol.v4_enabled - false
  • protocol.v41_enabled - false
  • protocol.v40_features.acl_enabled - false
  • protocol.v40_features.read_delegation_enabled - false
  • protocol.v40_features.write_delegation_enabled - false
  • protocol.v41_features.acl_enabled - false
  • protocol.v41_features.read_delegation_enabled - false
  • protocol.v41_features.write_delegation_enabled - false
  • protocol.v41_features.pnfs_enabled - false
  • protocol.v4_features.subnet_filter_enabled - false
  • vstorage_enabled - false
  • rquota_enabled - false
  • showmount_enabled - true
  • auth_sys_extended_groups_enabled - false
  • extended_groups_limit - 32
  • qtree.export_enabled - false
  • qtree.validate_export - true
  • access_cache_config.ttl_positive - 60
  • access_cache_config.ttl_negative - 30
  • access_cache_config.ttl_failure - 1
  • access_cache_config.harvest_timeout - 3600
  • access_cache_config.isDnsTTLEnabled - false
  • file_session_io_grouping_count - 5000
  • file_session_io_grouping_duration - 120
  • security.nt_acl_display_permission - false
  • exports.netgroup_trust_any_nsswitch_no_match - false
  • exports.name_service_lookup_protocol - udp
  • security.permitted_encryption_types - [aes-256,aes-128,des3,des]
  • security.rpcsec_context_idle - 0
  • security.chown_mode - use_export_policy
  • security.ntfs_unix_security - use_export_policy
  • windows.v3_ms_dos_client_enabled - false
  • windows.default_user - ""
  • windows.map_unknown_uid_to_default_user - true
  • credential_cache.positive_ttl - 3600000
  • credential_cache.negative_ttl - 3600000
  • credential_cache.transient_error_ttl - 30000
  • credential_cache.harvest_timeout - 86400000
  • protocol.v40_features.acl_preserve - true
  • protocol.v41_features.implementation_domain - 'netapp.com'
  • protocol.v40_features.acl_max_aces - 400
  • protocol.v3_features.ejukebox_enabled - true
  • protocol.v3_features.connection_drop - true
  • protocol.v3_features.fsid_change - true
  • protocol.v3_features.mount_daemon_port - 635
  • protocol.v3_features.network_lock_manager_port - 4045
  • protocol.v3_features.network_status_monitor_port - 4046
  • protocol.v3_features.rquota_daemon_port - 4046
  • protocol.v3_features.mount_root_only - true
  • transport.tcp_max_transfer_size - 65536
  • root.ignore_nt_acl - false
  • root.skip_write_permission_check - false
  • protocol.v40_features.referrals_enabled - false
  • protocol.v41_features.referrals_enabled - false
  • protocol.v4_fsid_change - true
  • protocol.v4_lease_seconds - 30
  • protocol.v4_grace_seconds - 45
  • protocol.v4_session_slots - 180
  • protocol.v4_session_slot_reply_cache_size - 640
  • vserver nfs create
  • export-policy access-cache config show
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
access_cache_config
access_cache_config
boolean
Specifies whether or not extended groups support over AUTH_SYS is enabled.
credential_cache
credential_cache
enabled
boolean
Specifies if the NFS service is administratively enabled.
exports
exports
integer
Specifies the maximum auxiliary groups supported over AUTH_SYS and RPCSEC_GSS.
integer
Number of I/O operations on a file to be grouped and considered as one session for event generation applications, such as FPolicy.
integer
The duration for which I/O operations on a file will be grouped and considered as one session for event generation applications, such as FPolicy.
protocol
protocol
protocol_access_rules
qtree
qtree
root
root
rquota_enabled
boolean
Specifies whether or not the remote quota feature is enabled.
security
security
showmount_enabled
boolean
Specifies whether or not the showmount feature is enabled.
state
string
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests.
svm
svm
transport
transport
vstorage_enabled
boolean
Specifies whether or not the VMware vstorage feature is enabled.
windows
windows
Example request
  "access_cache_config": {
    "harvest_timeout": 3600,
    "ttl_failure": 1,
    "ttl_negative": 30,
    "ttl_positive": 60
  "credential_cache": {
    "harvest_timeout": 86400000,
    "negative_ttl": 3600000,
    "positive_ttl": 3600000,
    "transient_error_ttl": 30000
  "exports": {
    "name_service_lookup_protocol": "string"
  "extended_groups_limit": 32,
  "file_session_io_grouping_count": 5000,
  "file_session_io_grouping_duration": 120,
  "protocol": {
    "v40_features": {
      "acl_max_aces": 500
    "v41_features": {
      "implementation_domain": "string",
      "implementation_name": "string"
    "v4_id_domain": "string"
  "protocol_access_rules": {
    "cifs_access_type": "string",
    "nfs3_access_type": "string",
    "nfs4_access_type": "string"
  "security": {
    "chown_mode": "string",
    "ntfs_unix_security": "string",
    "permitted_encryption_types": [
      "string"
  "state": "string",
  "svm": {
    "name": "svm1",
  "transport": {
    "tcp_max_transfer_size": 16384
  "windows": {
    "default_user": "string"
Status: 201, Created
num_records
integer
Number of NFS Server Records
records
array[nfs_service]
  "num_records": 1,
  "records": [
        "ttl_failure": 1,
        "ttl_negative": 30,
        "ttl_positive": 60
      "exports": {
      "protocol": {
        "v40_features": {
          "acl_max_aces": 500
        "v41_features": {
      "security": {
          "string"
      "state": "string",
      "svm": {
        "name": "svm1",
      "transport": {
      "windows": {
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1534829
The port numbers allowed are 635 (the default) and 1024 through 9999
2621516
This operation is only supported on a data SVM
2621570
This operation is not permitted on an SVM that is configured as the destination for SVM DR.
2621574
This operation is not permitted on an SVM that is configured as the destination of a MetroCluster SVM relationship
2621706
The specified SVM UUID is incorrect for the specified SVM name
3276852
NFSv4.1 implementation name length for the SVM must be less than 256 bytes.
3276872
NFSv4 lease timeout value must not be less than 10.
3276873
NFSv4 lease timeout value must be between 10 and (protocol.v4_grace_seconds-1).
3276874
NFSv4 grace timeout value must not be greater than 180.
3276875
NFSv4 grace timeout value must be between (protocol.v4_lease_seconds+1) and 180.
3276900
NFSv4.1 implementation name cannot be an empty string
3276916
Vserver is not running
3277038
Cannot enable \"showmount\" feature because it requires an effective cluster version of Data ONTAP 8.3.0 or later
3277048
3277049
Cannot enable \"showmount\" feature on ID-Discard Vserver. Ensure that the Vserver is initialized and retry the command
3277052
NFSv4.x access to transitioned volumes in this Vserver could trigger conversion of non-Unicode directories to Unicode, which might impact data-serving performance. Before enabling NFSv4.x for this Vserver, refer to the Data and Configuration Transition Guide
3277069
Cannot disable TCP because the SnapDiff RPC server is in the \"on\" state
3277085
The port numbers allowed are 1024 through 9999
3277089
Attempting to create an NFS server using 64-bits for NFSv3 FSIDs and File IDs on Vserver. Older client software might not work with 64-bit identifiers
3277099
Domain name contains invalid characters or it is too short. Allowed characters are: alphabetical characters (A-Za-z), numeric characters (0-9), minus sign (-), and the period (.). The first character must be alphabetical or numeric, last character must not be a minus sign or a period. Minimum supported length: 2 characters, maximum of 256 characters
3277140
Cannot set "transport.tcp_max_transfer_size" to a value other than multiples of 4096
2621507
The NFS protocol is not allowed for the specified SVM.
2621519
SVM name is invalid. The SVM name must begin with a letter or an underscore. If the SVM is of type "sync-source", the maximum supported length is 41. Otherwise, the maximum supported length is 47.
262196
Field "access_cache_config.harvest_timeout" cannot be set in this operation.
string
access_cache_config
harvest_timeout
integer
Specifies the time after which an entry is deleted from the access cache, if unused.
isDnsTTLEnabled
boolean
Specifies whether Dns TTL is enabled.
ttl_failure
integer
Specifies the time to live value for entries for which a failure was encountered, in seconds.
ttl_negative
integer
Specifies the time to live value of a negative access cache, in seconds.
ttl_positive
integer
Specifies the time to live value of a positive access cache, in seconds.
credential_cache
harvest_timeout
integer
Specifies the age of the unused cached entries, in milliseconds, after which they are cleared from the cache.
negative_ttl
integer
Specifies the age in milliseconds, of the negative cached credentials after which they are cleared from the cache.
positive_ttl
integer
Specifies the age in milliseconds, of the positive cached credentials after which they are cleared from the cache.
transient_error_ttl
integer
Specifies the age in milliseconds, of the cached entries during a transient error situation.
exports
string
Specifies the protocol to use for doing name service lookups.
boolean
Specifies if you can consider a no-match result from any of the netgroup ns-switch sources to be authoritative. If this option is enabled, then a no-match response from any of the netgroup ns-switch sources is deemed conclusive even if other sources could not be searched.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
v3
The NFSv3 operations
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
v4
The NFSv4 operations
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
v41
The NFSv4.1 operations
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
metric
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3
v3
v4
v4
v41
v41
v3_features
connection_drop
boolean
Specifies whether the dropping of a connection when an NFSv3 request is dropped is enabled.
ejukebox_enabled
boolean
Specifies whether NFSv3 EJUKEBOX error is enabled.
fsid_change
boolean
Specifies whether the change in FSID as NFSv3 clients traverse filesystems should be shown.
hide_snapshot_enabled
boolean
Specifies whether hiding a snapshot directory under a NFSv3 mount point is enabled.
mount_daemon_port
integer
Specifies which port the NFS mount daemon (mountd) uses.
mount_root_only
boolean
Specifies whether the SVM allows MOUNT protocol calls only from privileged ports (port numbers less than 1024).
integer
Specifies which port the Network lock manager uses.
integer
Specifies which port the Network status monitor port uses.
rquota_daemon_port
integer
Specifies which port the NFS quota daemon port uses.
v40_features
acl_enabled
boolean
Specifies whether NFSv4.0 ACLs is enabled.
acl_max_aces
integer
Specifies the maximum number of aces in a NFSv4.0 ACL.
acl_preserve
boolean
Specifies if the NFSv4 ACL is preserved or dropped when chmod is performed. In unified security style, this parameter also specifies if NTFS file permissions are preserved or dropped when chmod, chgrp, or chown are performed.
boolean
Specifies whether NFSv4.0 Read Delegation is enabled.
referrals_enabled
boolean
Specifies whether NFSv4.0 referrals is enabled.
boolean
Specifies whether NFSv4.0 Write Delegation is enabled.
v41_features
acl_enabled
boolean
Specifies whether NFSv4.1 or later ACLs is enabled.
string
Specifies the NFSv4.1 or later implementation ID domain.
implementation_name
string
Specifies the NFSv4.1 or later implementation ID name.
pnfs_enabled
boolean
Specifies whether NFSv4.1 or later Parallel NFS is enabled.
boolean
Specifies whether NFSv4.1 or later Read Delegation is enabled.
referrals_enabled
boolean
Specifies whether NFSv4.1 referrals is enabled.
trunking_enabled
boolean
Specifies whether NFSv4.1 or later trunking is enabled.
boolean
Specifies whether NFSv4.1 or later Write Delegation is enabled.
v42_features
seclabel_enabled
boolean
Specifies whether NFSv4.2 or later security label is enabled.
sparsefile_ops_enabled
boolean
Specifies whether NFSv4.2 or later sparsefile operation is enabled.
xattrs_enabled
boolean
Specifies whether NFSv4.2 or later extended attributes is enabled.
protocol
boolean
Specifies whether 64-bit support for NFSv3 FSIDs and file IDs is enabled.
v3_enabled
boolean
Specifies whether NFSv3 protocol is enabled.
v3_features
v3_features
v40_enabled
boolean
Specifies whether NFSv4.0 protocol is enabled.
v40_features
v40_features
v41_enabled
boolean
Specifies whether NFSv4.1 or later protocol is enabled.
v41_features
v41_features
v42_features
v42_features
boolean
Specifies whether 64-bit support for NFSv4.x FSIDs and file IDs is enabled.
v4_fsid_change
boolean
Specifies whether the change in FSID when NFSv4 clients traverse file systems is displayed.
v4_grace_seconds
integer
Specifies the grace period for clients to reclaim file locks after a server failure.
v4_id_domain
string
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol.
v4_lease_seconds
integer
Specifies the lease seconds of the NFSv4 clients. If it is inactive for more than the time displayed, all of the file lock states on a node might be lost.
integer
Specifies the number of bytes of the reply that is cached in each NFSv4.x session slot.
v4_session_slots
integer
Specifies the number of entries in NFSv4.x session slot table.
v4_subnet_filter_enabled
boolean
Specifies whether NFSv4 subnet filtering is enabled.
cifs_access_type
string
Access available for the CIFS protocol.
nfs3_access_type
string
Access available for the NFSv3 protocol.
nfs4_access_type
string
Access available for the NFSv4 protocol.
qtree
export_enabled
boolean
Specifies whether qtree export is enabled.
validate_export
boolean
Specifies whether qtree export validation is enabled.
root
ignore_nt_acl
boolean
Specifies whether Windows ACLs affect root access from NFS. If this option is enabled, root access from NFS ignores the NT ACL set on the file or directory.
boolean
Specifies if permission checks are to be skipped for NFS WRITE calls from root/owner. For copying read-only files to a destination folder which has inheritable ACLs, this option must be enabled.
security
chown_mode
string
Specifies whether file ownership can be changed only by the superuser, or if a non-root user can also change file ownership. If you set this parameter to restricted, file ownership can be changed only by the superuser, even though the on-disk permissions allow a non-root user to change file ownership. If you set this parameter to unrestricted, file ownership can be changed by the superuser and by the non-root user, depending upon the access granted by on-disk permissions. If you set this parameter to use_export_policy, file ownership can be changed in accordance with the relevant export rules.
boolean
Controls the permissions that are displayed to NFSv3 and NFSv4 clients on a file or directory that has an NT ACL set. When true, the displayed permissions are based on the maximum access granted by the NT ACL to any user. When false, the displayed permissions are based on the minimum access granted by the NT ACL to any user.
ntfs_unix_security
string
Specifies how NFSv3 security changes affect NTFS volumes. If you set this parameter to ignore, ONTAP ignores NFSv3 security changes. If you set this parameter to fail, this overrides the UNIX security options set in the relevant export rules. If you set this parameter to use_export_policy, ONTAP processes NFSv3 security changes in accordance with the relevant export rules.
  • Default value: 1
  • enum: ["ignore", "fail", "use_export_policy"]
  • Introduced in: 9.11
  • x-nullable: true
array[string]
Specifies the permitted encryption types for Kerberos over NFS.
rpcsec_context_idle
integer
Specifies, in seconds, the amount of time a RPCSEC_GSS context is permitted to remain unused before it is deleted.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
v3
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
v4
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
v41
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
statistics
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3
v3
v4
v4
v41
v41
svm
name
string
uuid
string
transport
rdma_enabled
boolean
Specifies whether RDMA transport is enabled for the NFS server.
tcp_enabled
boolean
Specifies whether TCP transports are enabled on the server.
integer
Specifies the maximum transfer size in bytes, that the storage system negotiates with the client for TCP transport of data for NFSv3 and NFSv4.x protocols. The range is 8192 to 1048576.
udp_enabled
boolean
Specifies whether UDP transports are enabled on the server.
windows
default_user
string
Specifies the default Windows user for the NFS server.
boolean
Specifies whether or not the mapping of an unknown UID to the default Windows user is enabled.
boolean
Specifies whether NFSv3 MS-DOS client support is enabled.
nfs_service
access_cache_config
access_cache_config
boolean
credential_cache
credential_cache
enabled
boolean
exports
exports
integer
integer
integer
protocol
protocol
qtree
qtree
root
root
rquota_enabled
boolean
security
security
showmount_enabled
boolean
state
string
svm
svm
transport
transport
vstorage_enabled
boolean
windows
windows
nfs_service
access_cache_config
access_cache_config
boolean
credential_cache
credential_cache
enabled
boolean
exports
exports
integer
integer
integer
protocol
protocol
qtree
qtree
root
root
rquota_enabled
boolean
security
security
showmount_enabled
boolean
state
string
  • online - NFS server is ready to accept client requests.
  • offline - NFS server is not ready to accept client requests.
svm
svm
transport
transport
vstorage_enabled
boolean
windows
windows
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
