Create an NFS configuration for an SVM
Creates an NFS configuration for an SVM, establishing the necessary settings for NFS protocol access. Use this endpoint when you need to set up or modify NFS properties for storage operations within an SVM environment.
HTTP method and endpoint
POST /protocols/nfs/services
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- Existing SVM for which to create the NFS configuration.
Default property values
If not specified in POST, the following default property values are assigned:
enabled- true -
state- online -
transport.udp_enabled- true -
transport.tcp_enabled- true -
protocol.v3_enabled- true -
protocol.v3_64bit_identifiers_enabled- false -
protocol.v4_id_domain- defaultv4iddomain.com -
protocol.v4_64bit_identifiers_enabled- true -
protocol.v4_enabled- false -
protocol.v41_enabled- false -
protocol.v40_features.acl_enabled- false -
protocol.v40_features.read_delegation_enabled- false -
protocol.v40_features.write_delegation_enabled- false -
protocol.v41_features.acl_enabled- false -
protocol.v41_features.read_delegation_enabled- false -
protocol.v41_features.write_delegation_enabled- false -
protocol.v41_features.pnfs_enabled- false -
vstorage_enabled- false -
rquota_enabled- false -
showmount_enabled- true -
auth_sys_extended_groups_enabled- false -
extended_groups_limit- 32 -
positive_cached_credential_ttl- 7200000
Related ONTAP commands
vserver nfs create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
auth_sys_extended_groups_enabled |
boolean |
Specifies whether or not extended groups support over AUTH_SYS is enabled. |
enabled |
boolean |
Specifies if the NFS service is administratively enabled. |
extended_groups_limit |
integer |
Specifies the maximum auxillary groups supported over AUTH_SYS and RPCSEC_GSS. |
positive_cached_credential_ttl |
integer |
Specifies the time to live value (in msecs) of a positive cached credential |
protocol |
rquota_enabled |
boolean |
Specifies whether or not the remote quota feature is enabled. |
showmount_enabled |
boolean |
Specifies whether or not the showmount feature is enabled. |
state |
string |
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests. |
svm |
transport |
vstorage_enabled |
boolean |
Specifies whether or not the VMware vstorage feature is enabled. |
Example request
"extended_groups_limit": "32",
"positive_cached_credential_ttl": "7200000",
"protocol": {
"v4_id_domain": "string"
"state": "string",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of NFS Server Records |
records |
array[nfs_service] |
"records": [
"protocol": {
"state": "string",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3276916 |
Vserver is not running |
3276994 |
Kerberos must be disabled on all LIFs on Vserver before adding or removing AES encryption. Disable Kerberos on the LIF and try again |
3277038 |
Cannot enable \"showmount\" feature because it requires an effective cluster version of Data ONTAP 8.3.0 or later |
3277049 |
Cannot enable \"showmount\" feature on ID-Discard Vserver. Ensure that the Vserver is initialized and retry the command |
3277052 |
NFSv4.x access to transitioned volumes in this Vserver could trigger conversion of non-Unicode directories to Unicode, which might impact data-serving performance. Before enabling NFSv4.x for this Vserver, refer to the Data and Configuration Transition Guide |
3277069 |
Cannot disable TCP because the SnapDiff RPC server is in the \"on\" state |
3277089 |
Attempting to create an NFS server using 64-bits for NFSv3 FSIDs and File IDs on Vserver. Older client software might not work with 64-bit identifiers |
3277099 |
Domain name contains invalid characters or it is too short. Allowed characters are: alphabetical characters (A-Za-z), numeric characters (0-9), minus sign (-), and the period (.). The first character must be alphabetical or numeric, last character must not be a minus sign or a period. Minimum supported length: 2 characters, maximum of 256 characters |
href |
string |
_links
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
v3
The NFSv3 operations
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
v4
The NFSv4 operations
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
v41
The NFSv4.1 operations
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
metric
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
The NFSv3 operations |
v4 |
The NFSv4 operations |
v41 |
The NFSv4.1 operations |
v40_features
acl_enabled |
boolean |
Specifies whether NFSv4.0 ACLs is enabled. |
read_delegation_enabled |
boolean |
Specifies whether NFSv4.0 Read Delegation is enabled. |
write_delegation_enabled |
boolean |
Specifies whether NFSv4.0 Write Delegation is enabled. |
v41_features
acl_enabled |
boolean |
Specifies whether NFSv4.1 or later ACLs is enabled. |
pnfs_enabled |
boolean |
Specifies whether NFSv4.1 or later Parallel NFS is enabled. |
boolean |
Specifies whether NFSv4.1 or later Read Delegation is enabled. |
boolean |
Specifies whether NFSv4.1 or later Write Delegation is enabled. |
protocol
v3_64bit_identifiers_enabled |
boolean |
Specifies whether 64-bit support for NFSv3 FSIDs and file IDs is enabled. |
v3_enabled |
boolean |
Specifies whether NFSv3 protocol is enabled. |
v40_enabled |
boolean |
Specifies whether NFSv4.0 protocol is enabled. |
v40_features |
v41_enabled |
boolean |
Specifies whether NFSv4.1 or later protocol is enabled. |
v41_features |
v4_64bit_identifiers_enabled |
boolean |
Specifies whether 64-bit support for NFSv4.x FSIDs and file IDs is enabled. |
v4_id_domain |
string |
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
v3
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
v4
iops_raw |
latency_raw |
status |
string |
throughput_raw |
timestamp |
string |
v41
iops_raw |
latency_raw |
status |
string |
throughput_raw |
timestamp |
string |
statistics
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
v4 |
v41 |
svm
name |
string |
The name of the SVM. |
uuid |
string |
transport
tcp_enabled |
boolean |
Specifies whether TCP transports are enabled on the server. |
udp_enabled |
boolean |
Specifies whether UDP transports are enabled on the server. |
nfs_service
boolean |
enabled |
boolean |
integer |
integer |
protocol |
rquota_enabled |
boolean |
showmount_enabled |
boolean |
state |
string |
svm |
transport |
vstorage_enabled |
boolean |
nfs_service
boolean |
enabled |
boolean |
integer |
integer |
protocol |
rquota_enabled |
boolean |
showmount_enabled |
boolean |
state |
string |
svm |
transport |
vstorage_enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
