Add primary key servers to an external key manager
Adds primary key servers to an external key manager to configure additional key management resources. This operation is typically performed when you need to expand the key server infrastructure for enhanced security management.
HTTP method and endpoint
POST /security/key-managers/{uuid}/key-servers
Introduced in
ONTAP 9.6
Usage notes
Adds key servers to a configured external key manager.
Required properties
uuid- UUID of the external key manager. -
server- Key server name.
Related ONTAP commands
security key-manager external add-servers
uuid |
string |
path |
True |
External key manager UUID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
records |
array[records] |
An array of key servers specified to add multiple key servers to a key manager in a single API call. Valid in POST only and not valid if |
secondary_key_servers |
array[string] |
A list of the secondary key servers associated with the primary key server. |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
Example request
"password": "password",
"records": [
"secondary_key_servers": [
"string"
"server": "keyserver1.com:5698"
"string"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[key_server] |
"records": [
"records": [
"string"
"string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536038 |
A maximum of 4 active key servers are allowed. |
65536821 |
The certificate is not installed. |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536828 |
External key management is not enabled for the SVM. |
65536834 |
Failed to get existing key-server details for the SVM. |
65536852 |
Failed to query supported KMIP protocol versions. |
65536870 |
Key management servers are already configured. |
65536871 |
Duplicate key management servers exist. |
65536921 |
The following issues were found. Unable to execute command on KMIP server. |
66060338 |
Unable to establish secure connection to KMIP server due to incorrect server_ca certificates. |
66060339 |
Unable to establish secure connection to KMIP server due to incorrect client certificates. |
66060340 |
Unable to establish secure connection to KMIP server due to Cryptsoft error. |
href |
string |
_links
records
password |
string |
array[string] |
server |
string |
key_server
password |
string |
records |
array[records] |
array[string] |
server |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
