Add primary key servers to an external key manager
Adds primary key servers to an external key manager to manage encryption keys securely. This operation helps ensure that your data encryption keys are controlled and accessible through your configured key management system.
HTTP method and endpoint
POST /security/key-managers/{uuid}/key-servers
Introduced in
ONTAP 9.6
Usage notes
Adds primary key servers to a configured external key manager.
Required properties
uuid- UUID of the external key manager. -
server- Primary Key server name.
Related ONTAP commands
security key-manager external add-servers
uuid |
string |
path |
True |
External key manager UUID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
port |
integer |
TCP port number for the key server. |
records |
array[records] |
An array of key servers specified to add multiple key servers to a key manager in a single API call. Valid in POST only and not valid if |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
Example request
"password": "password",
"port": 5698,
"records": [
"port": 5698,
"server": "bulkkeyserver.com:5698"
"server": "keyserver1.com:5698"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[key_server] |
"num_records": 1,
"records": [
"port": 5698,
"records": [
"port": 5698,
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536038 |
A maximum of 4 active primary key servers are allowed. |
65536042 |
Cannot add key server because it is already a secondary key server. |
65536600 |
Cannot add a key server while a node is out quorum. |
65536821 |
The certificate is not installed. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536828 |
External key management is not enabled for the SVM. |
65536834 |
Failed to get existing key-server details for the SVM. |
65536852 |
Failed to query supported KMIP protocol versions. |
65536870 |
Key management servers are already configured. |
65536870 |
The key management servers already exist. |
65536871 |
Duplicate key management servers exist. |
65536921 |
Unable to execute the command on the KMIP server. |
66060338 |
Unable to establish secure connection to KMIP server due to incorrect server_ca certificates. |
66060339 |
Unable to establish secure connection to KMIP server due to incorrect client certificates. |
66060340 |
Unable to establish secure connection to KMIP server due to Cryptsoft error. |
href |
string |
_links
node
name |
string |
uuid |
string |
key_server_state
The connectivity state of the key server for a specific node.
node |
state |
string |
Key server connectivity state |
connectivity
This property contains the key server connectivity state of all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability |
boolean |
Set to true when key server connectivity state is available on all nodes of the cluster. |
node_states |
array[key_server_state] |
An array of key server connectivity states for each node. |
records
password |
string |
port |
integer |
server |
string |
key_server
password |
string |
port |
integer |
records |
array[records] |
server |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
