REST API reference
Add primary key servers to an external key manager
Adds primary key servers to an external key manager, integrating them into the existing configuration. This operation is useful when expanding the key management infrastructure to accommodate additional servers.
HTTP method and endpoint
POST /security/key-managers/{uuid}/key-servers
Introduced in
ONTAP 9.6
Usage notes
Adds primary key servers to a configured external key manager.
Required properties
  • uuid - UUID of the external key manager.
  • server - Primary Key server name.
  • security key-manager external add-servers
uuid
string
path
True
External key manager UUID
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
password
string
Password credentials for connecting with the key server. This is not audited.
records
array[records]
An array of key servers specified to add multiple key servers to a key manager in a single API call. Valid in POST only and not valid if server is provided.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if records is provided.
Example request
  "password": "password",
  "records": [
      "server": "bulkkeyserver.com:5698"
  "server": "keyserver1.com:5698"
Status: 201, Created
num_records
integer
Number of records
records
array[key_server]
  "num_records": 1,
  "records": [
      "records": [
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
65536038
A maximum of 4 active primary key servers are allowed.
65536042
Cannot add key server because it is already a secondary key server.
65536600
Cannot add a key server while a node is out quorum.
65536821
The certificate is not installed.
65536824
Multitenant key management is not supported in MetroCluster configurations.
65536828
External key management is not enabled for the SVM.
65536834
Failed to get existing key-server details for the SVM.
65536852
Failed to query supported KMIP protocol versions.
65536870
Key management servers are already configured.
65536871
Duplicate key management servers exist.
65536921
The following issues were found. Unable to execute command on KMIP server.
66060338
Unable to establish secure connection to KMIP server due to incorrect server_ca certificates.
66060339
Unable to establish secure connection to KMIP server due to incorrect client certificates.
66060340
Unable to establish secure connection to KMIP server due to Cryptsoft error.
string
node
name
string
uuid
string
key_server_state
The connectivity state of the key server for a specific node.
node
node
state
string
Key server connectivity state
connectivity
This property contains the key server connectivity state of all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability
boolean
Set to true when key server connectivity state is available on all nodes of the cluster.
node_states
array[key_server_state]
An array of key server connectivity states for each node.
records
password
string
server
string
key_server
password
string
records
array[records]
server
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
