Create a new cluster-scoped or SVM-scoped role
Creates a new role at either the cluster or SVM scope. Use this endpoint to manage access permissions by defining roles with specific privileges within your ONTAP environment.
HTTP method and endpoint
POST /security/roles
Introduced in
ONTAP 9.6
Usage notes
Creates a new cluster-scoped role or an SVM-scoped role. For an SVM-scoped role, specify either the SVM name as the owner.name or SVM UUID as the owner.uuid in the request body along with other parameters for the role. The owner.uuid or owner.name are not required to be specified for a cluster-scoped role.
Required parameters
name- Name of the role to be created. -
privileges- Array of privilege tuples. Each tuple consists of a REST API path and its desired access level.
Optional parameters
owner.nameorowner.uuid- Name or UUID of the SVM for an SVM-scoped role.
Related ONTAP commands
security login rest-role create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
builtin |
boolean |
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted. |
name |
string |
Role name |
owner |
Owner name and UUID that uniquely identifies the role. |
privileges |
array[role_privilege] |
The list of privileges that this role has been granted. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
Example request
"name": "admin",
"owner": {
"name": "svm1",
"privileges": [
"access": "readonly",
"path": "/api/storage/volumes"
"scope": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
The supplied SVM does not exist. |
5636129 |
Role with given name has not been defined. |
5636143 |
Vserver admin cannot use the API with this access level. |
5636144 |
Invalid value specified for access level. |
5636169 |
Invalid character in URI. |
5636170 |
URI does not exist. |
5636171 |
Role already exists in legacy role table. |
5636184 |
Expanded REST roles for granular resource control feature is currently disabled. |
5636185 |
The specified UUID was not found. |
5636186 |
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later. |
13434890 |
Vserver-ID failed for Vserver roles. |
13434891 |
UUID lookup failed for Vserver roles. |
13434892 |
Roles is a required field. |
href |
string |
_links
owner
name |
string |
The name of the SVM. |
uuid |
string |
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
access |
string |
Access level for the REST endpoint. |
path |
string |
REST URI/endpoint |
role
A named set of privileges that defines the rights an account has when it is assigned the role.
builtin |
boolean |
name |
string |
Role name |
owner |
privileges |
scope |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
