REST API reference
Create a new cluster-scoped or SVM-scoped role
Creates a new role that can be scoped to either the entire cluster or a specific Storage Virtual Machine (SVM). Use this operation to define role-based access controls by specifying the desired privileges and, if applicable, the SVM to which the role applies.
HTTP method and endpoint
POST /security/roles
Introduced in
ONTAP 9.6
Usage notes
Creates a new cluster-scoped role or an SVM-scoped role. For an SVM-scoped role, specify either the SVM name as the owner.name or SVM UUID as the owner.uuid in the request body along with other parameters for the role. The owner.uuid or owner.name are not required to be specified for a cluster-scoped role.
Required parameters
  • name - Name of the role to be created.
  • privileges - Array of privilege tuples. Each tuple consists of a REST API or command/command directory path and its desired access level. If the tuple refers to a command/command directory path, it could optionally contain a query.
Optional parameters
  • owner.name or owner.uuid - Name or UUID of the SVM for an SVM-scoped role.
  • security login rest-role create
  • security login role create
Learn more
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
builtin
boolean
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted.
comment
string
Comment
name
string
Role name
owner
owner
Owner name and UUID that uniquely identifies the role.
privileges
array[role_privilege]
The list of privileges that this role has been granted.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "comment": "string",
  "name": "admin",
  "owner": {
    "name": "svm1",
  "privileges": [
      "access": "readonly",
      "path": [
        "/api/cluster/jobs",
        "/api/storage/volumes",
        "job schedule interval",
        "volume move"
      "query": [
        "-days <1 -hours >12",
        "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
  "scope": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The supplied SVM does not exist.
5636129
Role with given name has not been defined.
5636143
Vserver admin cannot use the API with this access level.
5636144
Invalid value specified for access level.
5636169
Invalid character in URI.
5636170
URI does not exist.
5636171
Role already exists in legacy role table.
5636184
Expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
13434890
Vserver-ID failed for Vserver roles.
13434891
UUID lookup failed for Vserver roles.
13434892
Roles is a required field.
string
owner
name
string
The name of the SVM.
uuid
string
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
role
A named set of privileges that defines the rights an account has when it is assigned the role.
builtin
boolean
comment
string
Comment
name
string
Role name
owner
owner
privileges
scope
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
