REST API reference
Create a new cluster-scoped or SVM-scoped role
Creates a new role that is either cluster-scoped or SVM-scoped, depending on the specified parameters. Use this endpoint to set up roles with specific privileges tailored to your security and management needs within the cluster or SVM environment.
HTTP method and endpoint
POST /security/roles
Introduced in
ONTAP 9.6
Usage notes
Creates a new cluster-scoped role or an SVM-scoped role. For an SVM-scoped role, specify either the SVM name as the owner.name or SVM UUID as the owner.uuid in the request body along with other parameters for the role. The owner.uuid or owner.name are not required to be specified for a cluster-scoped role.
Required parameters
  • name - Name of the role to be created.
  • privileges - Array of privilege tuples. Each tuple consists of a REST API or command/command directory path and its desired access level. If the tuple refers to a command/command directory path, it could optionally contain a query.
Optional parameters
  • owner.name or owner.uuid - Name or UUID of the SVM for an SVM-scoped role.
  • security login rest-role create
  • security login role create
Learn more
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
builtin
boolean
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted.
name
string
Role name
owner
owner
Owner name and UUID that uniquely identifies the role.
privileges
array[role_privilege]
The list of privileges that this role has been granted.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "name": "admin",
  "owner": {
    "name": "svm1",
  "privileges": [
      "access": "all",
      "path": "volume move start",
      "query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
  "scope": "string"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1263347
Cannot modify pre-defined roles
2621462
The supplied SVM does not exist.
5636129
Role with given name has not been defined.
5636143
Vserver admin cannot use the API with this access level.
5636144
Invalid value specified for access level.
5636168
This role is mapped to a REST role and can only be modified by updating the REST role.
5636169
Invalid character in URI.
5636170
URI does not exist.
5636171
Role already exists in legacy role table.
5636184
Expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
5636191
The "path" parameter in a "privileges" tuple can contain only API endpoint entries or only command and command directory entries.
5636192
The query parameter cannot be specified for the privileges tuple with API endpoint entries.
5636200
The specified value of the access parameter is invalid, if a command or command directory is specified in the path parameter.
5636210
User creation failed because LDAP is not configured for the SVM or the LDAP connection is not secure.
5636259
The specified child AIDE object was not found within the specified parent AIDE object.
5636261
The specified grandchild AIDE object was not found within the specified child AIDE object that belongs to the specified parent AIDE object.
5636262
Cannot create a role with the specified role name because it is reserved by the system.
13434890
Vserver-ID failed for Vserver roles.
13434891
UUID lookup failed for Vserver roles.
13434892
Roles is a required field.
string
owner
name
string
uuid
string
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are the following
Snapshots APIs
  • /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
  • /api/storage/volumes/{volume.uuid}/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/clients
  • /api/storage/volumes/{volume.uuid}/top-metrics/directories
  • /api/storage/volumes/{volume.uuid}/top-metrics/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/users
  • /api/svm/svms/{svm.uuid}/top-metrics/clients
  • /api/svm/svms/{svm.uuid}/top-metrics/directories
  • /api/svm/svms/{svm.uuid}/top-metrics/files
  • /api/svm/svms/{svm.uuid}/top-metrics/users
  • /api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
role
A named set of privileges that defines the rights an account has when it is assigned the role.
builtin
boolean
name
string
Role name
owner
owner
privileges
scope
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
