REST API reference
Create a SnapMirror policy
Creates a SnapMirror policy to define how data is mirrored between source and destination storage virtual machines (SVMs). This policy helps manage the replication settings, such as identity preservation and retention, tailored to your data protection needs.
HTTP method and endpoint
POST /snapmirror/policies
Introduced in
ONTAP 9.6
Usage notes
The property "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
It takes the following values:
  • full - indicates that the source SVM configuration is replicated to the destination SVM endpoint.
  • exclude_network_config - indicates that the source SVM configuration other than network configuration is replicated to the destination SVM endpoint.
  • exclude_network_and_protocol_config - indicates that the source SVM configuration is not replicated to the destination SVM endpoint.
Important note
  • The property "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
  • The properties "identity_preservation" and "transfer_schedule" are not applicable for "sync" type policies.
  • The property "copy_all_source_snapshots" is not applicable for "sync" type policies.
  • No "retention" properties can be specified if "copy_all_source_snapshots" is specified.
  • The properties "retention.creation_schedule" and "retention.prefix" are not applicable for "sync" type policies.
  • The property "sync_common_snapshot_schedule" is not applicable for an "async" type policy.
  • The property "retention.count" specifies the maximum number of Snapshot copies that are retained on the SnapMirror destination volume.
  • When the property "retention.label" is specified, the Snapshot copies that have a SnapMirror label matching this property is transferred to the SnapMirror destination.
  • When the property "retention.creation_schedule" is specified, Snapshot copies are directly created on the SnapMirror destination. The Snapshot copies created have the same content as the latest Snapshot copy already present on the SnapMirror destination.
Required properties
  • name - Name of the new SnapMirror policy.
  • svm.name or svm.uuid - Name or UUID of the SVM that owns the SnapMirror policy.
Default property values
If not specified in POST, the following default property values are assigned:
  • type - async
  • sync_type - sync (when type is sync)
  • copy_all_source_snapshots - false {when 'type' is async)
  • network_compression_enabled - false
  • throttle - 0
  • identity_preservation - exclude_network_and_protocol_config
  • snapmirror policy create
Creating a SnapMirror policy of type "sync"
 POST "/api/snapmirror/policies/" '{"name": "policy1", "svm.name": "VS0", "type": "sync", "sync_type": "sync"}'
Creating a SnapMirror policy of type "async" with two sets of retention values, one with a creation_schedule
 POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": [{"label": "weekly", "count": "2", "creation_schedule": {"name": "weekly"}}, {"label":"daily", "count":"7"}]}'
 POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async"}'
Creating a SnapMirror policy of type "async" which replicates all Snapshot copies
 POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async", "copy_all_source_snapshots": "true"}'
Creating a SnapMirror policy of type "sync" with sync_type as "automated_failover"
 POST "/api/snapmirror/policies/" '{"name": "policy1", "svm.name": "VS0", "type": "sync", "sync_type": "automated_failover" }'
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
comment
string
Comment associated with the policy.
boolean
Specifies whether all source Snapshot copies should be copied to the destination on a transfer rather than specifying specific retentions. This is applicable only to async policies.
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type.
name
string
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async".
retention
array[snapmirror_policy_rule]
Rules for Snapshot copy retention.
rpo
integer
Specifies the duration of time for which a change to be propogated to a mirror should be delayed, in seconds. This is an intentional propagation delay between mirrors and is configurable down to zero, which means an immediate propogation. This is supported for policies of type 'continuous'.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
svm
svm
Schedule used to create common Snapshot copies for synchronous relationships.
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
The schedule used to update asynchronous relationships. Only cron schedules are supported for SnapMirror.
type
string
uuid
string
Example request
  "comment": "string",
  "identity_preservation": "string",
  "name": "Asynchronous",
  "retention": [
      "count": 7,
        "name": "weekly",
      "label": "hourly",
      "prefix": "string"
  "rpo": 0,
  "scope": "string",
  "svm": {
    "name": "svm1",
  "sync_common_snapshot_schedule": {
    "name": "weekly",
  "sync_type": "string",
  "throttle": 0,
  "transfer_schedule": {
    "name": "weekly",
  "type": "string",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
6619714
Schedule specified is an interval schedule. SnapMirror does not support interval schedules.
13303850
Invalid input parameter
13303887
Failed to create SnapMirror policy. Reason: Maximum number of allowed retention rules reached
string
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention. Only cron schedules are supported for SnapMirror.
name
string
Job schedule name
uuid
string
Job schedule UUID
SnapMirror policy rule for retention.
count
integer
Number of Snapshot copies to be kept for retention.
creation_schedule
creation_schedule
label
string
Snapshot copy label
prefix
string
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
svm
name
string
The name of the SVM.
uuid
string
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy
SnapMirror policy information. SnapMirror policy can either be of type "async", "sync" or "continuous". The policy type "async" can be associated with a SnapMirror relationship that has either the FlexVol volume or FlexGroup volume or SVM as the endpoint. The policy type "sync" along with "sync_type" as "sync" or "strict_sync" can be associated with a SnapMirror relationship that has FlexVol volume as the endpoint. The policy type "sync" can have a "sync_type" of either "sync", "strict_sync" or "automated_failover". If the "sync_type" is "sync" then a write success is returned to the client after writing the data to the source endpoint and before writing the data to the destination endpoint. If the "sync_type" is "strict_sync" then a write success is returned to the client after writing the data to the both source and destination endpoints. If the "sync_type" is "automated_failover" then the policy can be associated with a SnapMirror relationship that has Consistency Group as the endpoint. Use the "sync" policy with "sync_type" as "automated_failover" to establish SnapMirror relationships for business continuity usecases. SnapMirror relationships with policy type as "sync" and "sync_type" as "automated_failover" can be monitored by the Mediator, if configured. In case the source Consistency Group endpoint is not reachable, the Mediator may trigger a failover to the destination Consistency Group endpoint. A policy of type "continuous" can be associated with SnapMirror relationships that have either ONTAP S3 buckets or NON-ONTAP object stores as endpoints. This type of policy is used for FabricLink owned targets.
comment
string
boolean
string
name
string
boolean
retention
rpo
integer
scope
string
svm
svm
sync_type
string
throttle
integer
transfer_schedule
transfer_schedule
type
string
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
