Create a SnapMirror policy
Creates a SnapMirror policy to define the replication configuration for SnapMirror relationships. Use this endpoint to specify options such as retention, transfer schedules, and identity preservation for efficient data replication between source and destination storage virtual machines (SVMs).
HTTP method and endpoint
POST /snapmirror/policies
Introduced in
ONTAP 9.6
Usage notes
The property "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
It takes the following values:
full- indicates that the source SVM configuration is replicated to the destination SVM endpoint. -
exclude_network_config- indicates that the source SVM configuration other than network configuration is replicated to the destination SVM endpoint. -
exclude_network_and_protocol_config- indicates that the source SVM configuration is not replicated to the destination SVM endpoint.
Important notes
The properties "identity_preservation" and "transfer_schedule" are not applicable for "sync" type policies.
The properties "copy_all_source_snapshots", "copy_latest_source_snapshot", and "create_snapshot_on_source" are mutually exclusive.
The properties "copy_all_source_snapshots", "copy_latest_source_snapshot", and "create_snapshot_on_source" are not applicable for "sync" type policies.
No "retention" properties can be specified if "copy_all_source_snapshots" or 'copy_latest_source_snapshot' is specified.
The properties "retention.creation_schedule" and "retention.prefix" are not applicable for "sync" type policies.
The property "retention.creation_schedule" is not applicable for "async" policies with "create_snapshot_on_source" set to "false".
The property "sync_common_snapshot_schedule" is not applicable for an "async" type policy.
The property "retention.count" specifies the maximum number of Snapshot copies that are retained on the SnapMirror destination volume.
When the property "retention.label" is specified, the Snapshot copies that have a SnapMirror label matching this property is transferred to the SnapMirror destination.
When the property "retention.creation_schedule" is specified, Snapshot copies are directly created on the SnapMirror destination. The Snapshot copies created have the same content as the latest Snapshot copy already present on the SnapMirror destination.
The property "transfer_schedule" cannot be set to null (no-quotes) during SnapMirror policy POST.
The properties "retention.label" and "retention.count" must be specified for "async" policies with "create_snapshot_on_source" set to "false".
Required properties
name- Name of the new SnapMirror policy.
Recommended optional properties
svm.nameorsvm.uuid- Name or UUID of the SVM that owns the SnapMirror policy.
Default property values
If not specified in POST, the following default property values are assigned:
type- async -
sync_type- sync (whentypeis sync) -
network_compression_enabled- false -
throttle- 0 -
identity_preservation-exclude_network_and_protocol_config
Related ONTAP commands
snapmirror policy create
Creating a SnapMirror policy of type "sync"
POST "/api/snapmirror/policies/" '{"name": "policy1", "svm.name": "VS0", "type": "sync", "sync_type": "sync"}'
Creating a SnapMirror policy of type "async" with two sets of retention values, one with a creation_schedule
POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": [{"label": "weekly", "count": "2", "creation_schedule": {"name": "weekly"}}, {"label":"daily", "count":"7"}]}'
POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async"}'
Creating a SnapMirror policy of type "async" which replicates all Snapshot copies
POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async", "copy_all_source_snapshots": "true"}'
Creating a SnapMirror policy of type "async" which replicates latest Snapshot copy
POST "/api/snapmirror/policies" '{"name": "newPolicy2", "svm":{"name" : "vs1"}, "type": "async", "copy_latest_source_snapshot": "true"}'
Creating a SnapMirror policy of type "async" which does not create Snapshot copies on source
POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async", "create_snapshot_on_source": "false", "retention": [{"label": "daily", "count": 7}]}'
Creating a SnapMirror policy of type "sync" with sync_type as "automated_failover"
POST "/api/snapmirror/policies/" '{"name": "policy1", "svm.name": "VS0", "type": "sync", "sync_type": "automated_failover" }'
Creating a SnapMirror policy of type "async" with two sets of retention values and retention periods
POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": [{"label": "weekly", "count": "2", "period": "P7D"}, {"label":"daily", "count":"7", "period": "PT3H"}]}'
Creating a SnapMirror policy of type "async" with retention value as "inifnite"
POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": [{"label": "weekly", "count": "5", "period": "infinite"}]}'
Learn more
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Comment associated with the policy. |
copy_all_source_snapshots |
boolean |
Specifies that all the source Snapshot copies (including the one created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'. |
copy_latest_source_snapshot |
boolean |
Specifies that the latest source Snapshot copy (created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'. |
create_snapshot_on_source |
boolean |
Specifies whether a new Snapshot copy should be created on the source at the beginning of an update or resync operation. This is applicable only to async policies. Property can only be set to 'false'. |
identity_preservation |
string |
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type. |
name |
string |
Name of the policy. |
network_compression_enabled |
boolean |
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async". |
retention |
array[snapmirror_policy_rule] |
Rules for Snapshot copy retention. |
rpo |
integer |
Specifies the duration of time for which a change to be propogated to a mirror should be delayed, in seconds. This is an intentional propagation delay between mirrors and is configurable down to zero, which means an immediate propogation. This is supported for policies of type 'continuous'. |
scope |
string |
Set to "svm" for policies owned by an SVM, otherwise set to "cluster". |
svm |
sync_common_snapshot_schedule |
Schedule used to create common Snapshot copies for synchronous relationships. |
sync_type |
string |
throttle |
integer |
Throttle in KB/s. Default to unlimited. |
transfer_schedule |
The schedule used to update asynchronous relationships. Only cron schedules are supported for SnapMirror. |
type |
string |
uuid |
string |
Example request
"comment": "string",
"copy_all_source_snapshots": 1,
"copy_latest_source_snapshot": 1,
"create_snapshot_on_source": "",
"identity_preservation": "string",
"name": "Asynchronous",
"retention": [
"count": 7,
"name": "weekly",
"label": "hourly",
"period": "P30D",
"prefix": "string"
"rpo": 0,
"scope": "string",
"svm": {
"name": "svm1",
"sync_common_snapshot_schedule": {
"name": "weekly",
"sync_type": "string",
"throttle": 0,
"transfer_schedule": {
"name": "weekly",
"type": "string",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response codes
| Error code | Description |
6619714 |
Schedule specified is an interval schedule. SnapMirror does not support interval schedules. |
13303850 |
Invalid input parameter |
13303887 |
Failed to create SnapMirror policy. Reason: Maximum number of allowed retention rules reached |
13304083 |
The specified property is not supported because all nodes in the cluster are not capable of supporting this property. |
13304084 |
Properties specified are mutually exclusive. Provide only one property. |
13304085 |
The specified property does not support the specified value. |
13304092 |
Input value of the retention period property is invalid. For relationships with FlexVol volume or FlexGroup volume destinations, the duration must be in ISO 6801 format or can be infinite. For relationships with object store destinations, only duration values with Y, M or D and supported and must be in the specified range. |
href |
string |
_links
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention. Only cron schedules are supported for SnapMirror.
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
SnapMirror policy rule for retention.
count |
integer |
Number of Snapshot copies to be kept for retention. |
creation_schedule |
Schedule used to create Snapshot copies on the destination for long term retention. Only cron schedules are supported for SnapMirror. |
label |
string |
Snapshot copy label |
period |
string |
Specifies the duration for which the Snapshot copies are locked. The retention period value represents a duration and must be in the ISO-8601 duration format. Years, months, days, hours, minutes, and seconds are represented as "P |
prefix |
string |
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
transfer_schedule
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapmirror_policy
SnapMirror policy information. SnapMirror policy can either be of type "async", "sync" or "continuous". The policy type "async" can be associated with a SnapMirror relationship that has either the FlexVol volume or FlexGroup volume or SVM as the endpoint. The policy type "sync" along with "sync_type" as "sync" or "strict_sync" can be associated with a SnapMirror relationship that has FlexVol volume as the endpoint. The policy type "sync" can have a "sync_type" of either "sync", "strict_sync" or "automated_failover". If the "sync_type" is "sync" then a write success is returned to the client after writing the data to the source endpoint and before writing the data to the destination endpoint. If the "sync_type" is "strict_sync" then a write success is returned to the client after writing the data to the both source and destination endpoints. If the "sync_type" is "automated_failover" then the policy can be associated with a SnapMirror relationship that has Consistency Group as the endpoint. Use the "sync" policy with "sync_type" as "automated_failover" to establish SnapMirror relationships for business continuity usecases. SnapMirror relationships with policy type as "sync" and "sync_type" as "automated_failover" can be monitored by the Mediator, if configured. In case the source Consistency Group endpoint is not reachable, the Mediator may trigger a failover to the destination Consistency Group endpoint. A policy of type "continuous" can be associated with SnapMirror relationships that have either ONTAP S3 buckets or NON-ONTAP object stores as endpoints. This type of policy is used for FabricLink owned targets.
comment |
string |
boolean |
boolean |
boolean |
string |
name |
string |
boolean |
retention |
rpo |
integer |
scope |
string |
svm |
sync_type |
string |
throttle |
integer |
transfer_schedule |
type |
string |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
