REST API reference
Create a SnapMirror policy
Creates a SnapMirror policy to define how data is replicated between source and destination storage systems. This configuration helps you manage data protection and disaster recovery across your ONTAP environment.
HTTP method and endpoint
POST /snapmirror/policies
Introduced in
ONTAP 9.6
Usage notes
The property "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
It takes the following values:
  • full - indicates that the source SVM configuration is replicated to the destination SVM endpoint.
  • exclude_network_config - indicates that the source SVM configuration other than network configuration is replicated to the destination SVM endpoint.
  • exclude_network_and_protocol_config - indicates that the source SVM configuration is not replicated to the destination SVM endpoint.
Important notes
  • The property "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
  • The properties "identity_preservation" and "transfer_schedule" are not applicable for "sync" type policies.
  • The properties "copy_all_source_snapshots", "copy_latest_source_snapshot", and "create_snapshot_on_source" are mutually exclusive.
  • The properties "copy_all_source_snapshots", "copy_latest_source_snapshot", and "create_snapshot_on_source" are not applicable for "sync" type policies.
  • No "retention" properties can be specified if "copy_all_source_snapshots" or 'copy_latest_source_snapshot' is specified.
  • The properties "retention.creation_schedule" and "retention.prefix" are not applicable for "sync" type policies.
  • The property "retention.creation_schedule" is not applicable for "async" policies with "create_snapshot_on_source" set to "false".
  • The property "sync_common_snapshot_schedule" is not applicable for an "async" type policy.
  • The property "retention.count" specifies the maximum number of snapshots that are retained on the SnapMirror destination volume.
  • When the property "retention.label" is specified, the snapshots that have a SnapMirror label matching this property is transferred to the SnapMirror destination.
  • When the property "retention.creation_schedule" is specified, snapshots are directly created on the SnapMirror destination. The snapshots created have the same content as the latest snapshot already present on the SnapMirror destination.
  • The property "transfer_schedule" cannot be set to null (no-quotes) during SnapMirror policy POST.
  • The properties "retention.label" and "retention.count" must be specified for "async" policies with "create_snapshot_on_source" set to "false".
  • The property "retention.warn" is not supported for a policy when the "retention.preserve" property is false.
  • The property "retention.warn" value must be less than the property "retention.count" value for a rule in a policy.
Required properties
  • name - Name of the new SnapMirror policy.
  • svm.name or svm.uuid - Name or UUID of the SVM that owns the SnapMirror policy.
Default property values
If not specified in POST, the following default property values are assigned:
  • type - async
  • sync_type - sync (when type is sync)
  • network_compression_enabled - false
  • throttle - 0
  • identity_preservation - exclude_network_and_protocol_config
  • snapmirror policy create
Creating a SnapMirror policy of type "sync"
 POST "/api/snapmirror/policies/" '{"name": "policy1", "svm.name": "VS0", "type": "sync", "sync_type": "sync"}'
Creating a SnapMirror policy of type "async" with two sets of retention values, one with a creation_schedule
 POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": [{"label": "weekly", "count": "2", "creation_schedule": {"name": "weekly"}}, {"label":"daily", "count":"7"}]}'
 POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async"}'
Creating a SnapMirror policy of type "async" which replicates all snapshots
 POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async", "copy_all_source_snapshots": "true"}'
Creating a SnapMirror policy of type "async" which replicates latest snapshot
 POST "/api/snapmirror/policies" '{"name": "newPolicy2", "svm":{"name" : "vs1"}, "type": "async", "copy_latest_source_snapshot": "true"}'
Creating a SnapMirror policy of type "async" which does not create snapshots on source
 POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async", "create_snapshot_on_source": "false", "retention": [{"label": "daily", "count": 7}]}'
Creating a SnapMirror policy of type "sync" with sync_type as "automated_failover"
 POST "/api/snapmirror/policies/" '{"name": "policy1", "svm.name": "VS0", "type": "sync", "sync_type": "automated_failover" }'
Creating a SnapMirror policy of type "sync" with sync_type as "automated_failover_duplex"
 POST "/api/snapmirror/policies/" '{"name": "policy_afd", "svm.name": "VS0", "type": "sync", "sync_type": "automated_failover_duplex" }'
Creating a SnapMirror policy of type "async" with two sets of retention values and retention periods
 POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": [{"label": "weekly", "count": "2", "period": "P7D"}, {"label":"daily", "count":"7", "period": "PT3H"}]}'
Creating a SnapMirror policy of type "async" with retention value as "infinite"
 POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": [{"label": "weekly", "count": "5", "period": "infinite"}]}'
Creating a SnapMirror policy of type "async" with properties retention preserve as true and retention warn as 3.
 POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": [{"label": "weekly", "count": "5", "preserve": true, "warn": 3}]}'
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
comment
string
Comment associated with the policy.
boolean
Specifies that all the source snapshots (including the one created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
boolean
Specifies that the latest source snapshot (created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
boolean
Specifies whether a new snapshot should be created on the source at the beginning of an update or resync operation. This is applicable only to async policies. Property can only be set to 'false'.
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type.
name
string
Name of the policy.
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async".
retention
array[snapmirror_policy_rule]
Rules for snapshot retention.
rpo
integer
Specifies the duration of time for which a change to be propagated to a mirror should be delayed, in seconds. This is an intentional propagation delay between mirrors and is configurable down to zero, which means an immediate propagation. This is supported for policies of type 'continuous'.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
svm
svm
Schedule used to create common snapshots for synchronous relationships.
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
The schedule used to update asynchronous relationships. Only cron schedules are supported for SnapMirror.
type
string
uuid
string
Unique identifier of the SnapMirror policy.
Example request
  "comment": "string",
  "copy_all_source_snapshots": 1,
  "copy_latest_source_snapshot": 1,
  "create_snapshot_on_source": "",
  "identity_preservation": "string",
  "name": "Asynchronous",
  "retention": [
      "count": 7,
        "name": "weekly",
      "label": "hourly",
      "period": "P30D",
      "prefix": "string",
      "preserve": 1,
      "warn": 4
  "rpo": 0,
  "scope": "string",
  "svm": {
    "name": "svm1",
  "sync_common_snapshot_schedule": {
    "name": "weekly",
  "sync_type": "string",
  "throttle": 0,
  "transfer_schedule": {
    "name": "weekly",
  "type": "string",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response codes
Error code Description
6619714
Schedule specified is an interval schedule. SnapMirror does not support interval schedules.
13304126
Enter a value for "count" in the range indicated in the error message.
13303887
Failed to create SnapMirror policy. Reason: Maximum number of allowed retention rules reached
13304083
The specified property is not supported because all nodes in the cluster are not capable of supporting this property.
13304084
Properties specified are mutually exclusive. Provide only one property.
13304085
The specified property does not support the specified value.
13304092
Input value of the retention period property is invalid. For relationships with FlexVol volume or FlexGroup volume destinations, the duration must be in ISO 6801 format or can be infinite. For relationships with object store destinations, only duration values with Y, M or D and supported and must be in the specified range.
| 6621045 | The property retention.warn is not supported for a policy when the retention.preserve property is false. | 13304129 | The property retention.warn value must be less than the property retention.count value for a rule in a policy. | 13304130 | The total retention.count value for all rules in a policy cannot exceed the value indicated in the error message. | 6621060 | Failed to create specified policy. Reason: A policy with this name already exists. | | 13304118 | The specified properties cannot be both set at the same time: retention.creation_schedule and retention.period | | 6621972 | Schedule specified is not supported by SnapMirror Synchronous. The allowed time interval for the creation of common snapshots can range between 30 minutes and 24 hours. | | 13304011 | Failed to create or modify the specified SnapMirror policy. Reason: The property retention.count cannot have a value greater than 1. | | 6621091 | The specified SnapMirror policy cannot have a rule with a preserve value of true. | | 6621088 | The specified SnapMirror policy must have at least one rule without a schedule. |
string
creation_schedule
Schedule used to create snapshots on the destination for long term retention. Only cron schedules are supported for SnapMirror.
name
string
Job schedule name
uuid
string
Job schedule UUID
SnapMirror policy rule for retention.
count
integer
Number of snapshots to be kept for retention. Maximum value will differ based on type of relationship and scaling factor.
creation_schedule
creation_schedule
label
string
Snapshot label
period
string
Specifies the duration for which the snapshots are locked. The retention period value represents a duration and must be in the ISO-8601 duration format. Years, months, days, hours, minutes, and seconds are represented as "PY","PM","PD","PTH","PTM" and "PTS". Value "infinite" is also a valid input for Flexvol volumes and FlexGroup volumes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. The range of supported retention period values is between 1 second to infinite.
prefix
string
Specifies the prefix for the snapshot name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
preserve
boolean
Specifies the behavior when the snapshot retention count is reached on the SnapMirror destination for the rule. The default value is false, which means that the oldest snapshot is deleted to make room for new ones but only if the number of snapshots has exceeded the retention count specified in the 'count' property. When set to true and where the snapshots have reached the retention count, an incremental SnapMirror transfer will fail or if the rule has a schedule, snapshots will be no longer be created on the SnapMirror destination.
warn
integer
Specifies the warning threshold count for the rule. The default value is zero. When set to a value greater than zero, an event is generated after the number of snapshots (for the particular rule) retained on a SnapMirror destination reaches the specified warning limit. The preserve property for the rule must be true in order to set the warn property to a value greater than zero.
svm
name
string
uuid
string
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy
SnapMirror policy information. SnapMirror policy can either be of type "async", "sync" or "continuous". The policy type "async" can be associated with a SnapMirror relationship that has either a FlexVol volume, FlexGroup volume or SVM as the endpoint. The policy type "sync" along with "sync_type" as "sync" or "strict_sync" can be associated with a SnapMirror relationship that has a FlexVol volume as the endpoint. The policy type "sync" can have a "sync_type" of either "sync", "strict_sync", "automated_failover" or "automated_failover_duplex". If the "sync_type" is "sync", a write success is returned to the client after writing the data to the source endpoint and before writing the data to the destination endpoint. If the "sync_type" is "strict_sync", a write success is returned to the client after writing the data to both source and destination endpoints. If the "sync_type" is "automated_failover", the policy can be associated with a SnapMirror active sync relationship that has a consistency group as the endpoint and provides asymmetric active active access to the two storage copies. If the "sync_type" is "automated_failover_duplex", the policy can be associated with a SnapMirror active sync relationship that has a consistency group as the endpoint and provides symmetric active active access to the two storage copies. Use the "sync" policy with "sync_type" as "automated_failover" or "automated_failover_duplex" to establish SnapMirror active sync relationships for business continuity use cases. SnapMirror relationships with policy types as "sync" and "sync_type" as "automated_failover" or "automated_failover_duplex" can be monitored by the Mediator, if configured. If the source Consistency Group endpoint is not reachable, the Mediator might trigger a failover to the destination consistency group endpoint. A policy type of "continuous" can be associated with SnapMirror relationships that have either ONTAP S3 buckets or non-ONTAP object stores as endpoints. This type of policy is used for FabricLink owned targets.
comment
string
boolean
boolean
boolean
string
name
string
Name of the policy.
boolean
retention
rpo
integer
scope
string
svm
svm
sync_type
string
throttle
integer
transfer_schedule
transfer_schedule
type
string
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
