REST API reference
Create a monitored file
Creates a monitored file to track changes within a specified file path. This helps you manage and review file activities in your storage environment effectively.
HTTP method and endpoint
POST /storage/monitored-files
Introduced in
ONTAP 9.8
Required properties
The required properties take the following options:
  • path and volume.uuid or
  • path and (svm.name or svm.uuid) and volume.name
  • path - Path to the file to be monitored.
  • volume.uuid - Volume where the file to be monitored exists
  • svm.name or svm.uuid - SVM where the file to be monitored exists
  • volume.name - Volume where the file to be monitored exists.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
path
string
Path of the file to be monitored.
svm
svm
uuid
string
Unique identifier created for identifying the file that is monitored.
volume
volume
Example request
  "path": "/a/b/c/file.txt",
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "volume": {
    "name": "volume1",
Status: 201, Created
num_records
integer
Number of files provisioned for monitoring.
records
array[monitored_file]
  "records": [
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default, Error
string
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
performance_metric
Performance numbers, such as IOPS latency and throughput.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
performance_metric_raw_reference
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
monitored_file
path
string
svm
svm
uuid
string
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
