Create a monitored file
Creates a monitored file to track changes or access to specific file paths within your storage environment. Use this endpoint when you need to keep an eye on file activity for auditing or security purposes.
HTTP method and endpoint
POST /storage/monitored-files
Introduced in
ONTAP 9.8
Required properties
The required properties take the following options:
path and volume.uuid or
path and (svm.name or svm.uuid) and volume.name
path- Path to the file to be monitored. -
volume.uuid- Volume where the file to be monitored exists -
svm.nameorsvm.uuid- SVM where the file to be monitored exists -
volume.name- Volume where the file to be monitored exists.
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
path |
string |
Path of the file to be monitored. |
svm |
uuid |
string |
Unique identifier created for identifying the file that is monitored. |
volume |
Example request
"path": "/a/b/c/file.txt",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"volume": {
"name": "volume1",
Status: 201, Created
num_records |
integer |
Number of files provisioned for monitoring. |
records |
array[monitored_file] |
"records": [
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default, Error
href |
string |
_links
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
performance_metric
Performance numbers, such as IOPS latency and throughput.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
performance_metric_raw_reference
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
monitored_file
path |
string |
svm |
uuid |
string |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
