Create an EBR policy
Creates an EBR policy to define rules for event-based retention of data within your storage environment. This is useful for ensuring compliance with data retention requirements.
HTTP method and endpoint
POST /storage/snaplock/event-retention/operations
Introduced in
ONTAP 9.7
Required properties
path- Path of the file. -
policy.name- Name of the EBR policy.
Related ONTAP commands
snaplock event-retention apply
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
id |
integer |
Operation ID |
num_files_failed |
integer |
Specifies the number of files on which the application of EBR policy failed. |
num_files_processed |
integer |
Specifies the number of files on which EBR policy was applied successfully. |
num_files_skipped |
integer |
Specifies the number of files on which the application of EBR policy was skipped. |
num_inodes_ignored |
integer |
Specifies the number of inodes on which the application of EBR policy was not attempted because they were not regular files. |
path |
string |
The path for the EBR operation. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory. |
policy |
state |
string |
Specifies the operation status of an EBR operation. |
svm |
volume |
Example request
"id": 16842759,
"num_files_failed": 0,
"num_files_processed": 50,
"num_files_skipped": 2,
"num_inodes_ignored": 2,
"path": "/dir1/file",
"policy": {
"name": "string",
"retention_period": "P30M",
"svm": {
"name": "svm1",
"state": "completed",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: 201, Created
id |
integer |
Operation ID |
num_files_failed |
integer |
integer |
num_files_skipped |
integer |
integer |
path |
string |
policy |
state |
string |
svm |
volume |
"id": 16842759,
"policy": {
"name": "string",
"svm": {
"name": "svm1",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default, Error
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
policy
name |
string |
Specifies the EBR policy name |
retention_period |
string |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P |
svm |
svm
name |
string |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
ebr_operation
id |
integer |
Operation ID |
num_files_failed |
integer |
integer |
num_files_skipped |
integer |
integer |
path |
string |
policy |
state |
string |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
