REST API reference
Create an EBR policy
Creates an EBR policy to define rules and parameters for managing event-based retention in ONTAP. Use this endpoint when you need to establish criteria for retaining specific data according to your organizational requirements.
HTTP method and endpoint
POST /storage/snaplock/event-retention/operations
Introduced in
ONTAP 9.7
Required properties
  • path - Path of the file.
  • policy.name - Name of the EBR policy.
  • snaplock event-retention apply
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
id
integer
Operation ID
num_files_failed
integer
Specifies the number of files on which the application of EBR policy failed.
num_files_processed
integer
Specifies the number of files on which EBR policy was applied successfully.
num_files_skipped
integer
Specifies the number of files on which the application of EBR policy was skipped.
num_inodes_ignored
integer
Specifies the number of inodes on which the application of EBR policy was not attempted because they were not regular files.
path
string
The path for the EBR operation. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.
policy
policy
state
string
Specifies the operation status of an EBR operation.
svm
svm
volume
volume
Example request
  "id": 16842759,
  "num_files_failed": 0,
  "num_files_processed": 50,
  "num_files_skipped": 2,
  "num_inodes_ignored": 2,
  "path": "/dir1/file",
  "policy": {
    "name": "string",
    "retention_period": "P30M",
    "svm": {
      "name": "svm1",
  "state": "completed",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: 201, Created
_links
_links
id
integer
Operation ID
num_files_failed
integer
num_files_processed
integer
num_files_skipped
integer
num_inodes_ignored
integer
path
string
policy
policy
state
string
svm
svm
volume
volume
  "id": 16842759,
  "policy": {
    "name": "string",
    "svm": {
      "name": "svm1",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default, Error
string
svm
name
string
The name of the SVM.
uuid
string
policy
_links
_links
name
string
Specifies the EBR policy name
retention_period
string
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. Similarly, a duration in hours, minutes is represented by "PTH", "PTM" respectively. The period string must contain only a single time element i.e. either years, months, days, hours or minutes. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the strings "infinite" and "unspecified".
svm
svm
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
ebr_operation
_links
_links
id
integer
Operation ID
num_files_failed
integer
num_files_processed
integer
num_files_skipped
integer
num_inodes_ignored
integer
path
string
policy
policy
state
string
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
