Create an EBR policy
POST /storage/snaplock/event-retention/operations
Introduced In: 9.7
Start an EBR operation. This operation applies an EBR policy to a specific volume or to a path within the volume.
Required properties
path- Path of the file. -
policy.name- Name of the EBR policy. Either volume.name or volume.uuid must be specified when applying EBR policy to the volume or a path within the volume. -
volume.name- Volume name. -
volume.uuid- Volume uuid.
Related ONTAP commands
snaplock event-retention apply
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
id  |
integer  |
Operation ID  |
num_files_failed  |
integer  |
Specifies the number of files on which the application of EBR policy failed.  |
num_files_processed  |
integer  |
Specifies the number of files on which EBR policy was applied successfully.  |
num_files_skipped  |
integer  |
Specifies the number of files on which the application of EBR policy was skipped.  |
num_inodes_ignored  |
integer  |
Specifies the number of inodes on which the application of EBR policy was not attempted because they were not regular files.  |
path  |
string  |
The path for the EBR operation. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.  |
policy  |
state  |
string  |
Specifies the operation status of an EBR operation.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
volume  |
Example request
  "id": 16842759,
  "num_files_failed": 0,
  "num_files_processed": 50,
  "num_files_skipped": 2,
  "num_inodes_ignored": 2,
  "path": "/dir1/file",
  "policy": {
    "name": "string",
    "retention_period": "P30M"
  "state": "completed",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: 201, Created
id  |
integer  |
Operation ID  |
num_files_failed  |
integer  |
integer  |
num_files_skipped  |
integer  |
integer  |
path  |
string  |
policy  |
state  |
string  |
svm  |
volume  |
  "id": 16842759,
  "policy": {
    "name": "string",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response codes
| Error code | Description |
918236  |
The specified volume uuid and volume name refer to different volumes.  |
13763372  |
Path should be given in the format "\/<dir path>".  |
14090242  |
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation.  |
href  |
string  |
_links
policy
name  |
string  |
Specifies the EBR policy name  |
retention_period  |
string  |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P  |
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
volume
name  |
string  |
The name of the volume. This field cannot be specified in a POST or PATCH method.  |
uuid  |
string  |
ebr_operation
id  |
integer  |
Operation ID  |
num_files_failed  |
integer  |
integer  |
num_files_skipped  |
integer  |
integer  |
path  |
string  |
policy  |
state  |
string  |
svm  |
volume  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
