REST API reference
Create a volume efficiency policy
Creates a volume efficiency policy to manage storage efficiency operations for a specific SVM. Use this endpoint to define policies that optimize storage usage by scheduling or triggering efficiency operations based on your configurations.
HTTP method and endpoint
POST /storage/volume-efficiency-policies
Introduced in
ONTAP 9.8
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the volume efficiency policy.
  • name - Name for the volume efficiency policy.
  • type - Type of volume policy.
  • schedule - Schedule the volume efficiency defined in minutes, hourly, daily and weekly.
  • duration - Indicates the allowed duration for a session for policy type "scheduled".
  • start_threshold_percent - Indicates the start threshold percentage for the policy type "threshold". It is mutually exclusive of the schedule.
  • qos_policy - QoS policy for the sis operation.
  • comment - A comment associated with the volume efficiency policy.
  • enabled - Is the volume efficiency policy enabled?
Default property values
If not specified in POST, the following default property values are assigned:
  • type - scheduled
  • enabled - true
  • qos_policy - best_effort
  • volume efficiency policy create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
duration
integer
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0.
enabled
boolean
name
string
Name of the volume efficiency policy.
qos_policy
string
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations.
schedule
schedule
integer
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule.
svm
svm
type
string
Type of volume efficiency policy.
uuid
string
Unique identifier of volume efficiency policy.
Example request
  "comment": "string",
  "duration": 5,
  "enabled": 1,
  "name": "default",
  "qos_policy": "string",
  "schedule": {
    "name": "daily"
  "start_threshold_percent": 30,
  "svm": {
    "name": "svm1",
  "type": "string",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
6881341
Specified schedule not found.
6881344
Failed to queue specified job.
6881345
This operation is not permitted on a node SVM.
6881349
Policy name is not valid.
6881362
Threshold percentage cannot be less than 1 percent.
6881433
For "{{0}}" type policy, attribute "{{1}}" is not supported.
6881435
Only a policy of type "threshold" can set the "start-threshold-percent" attribute.
6881436
For a policy of type "scheduled", a valid "schedule" is a required attribute.
6881454
An efficiency policy of type "threshold" requires an effective cluster version of ONTAP 8.3 or later.
6881474
Duration cannot be null.
6881475
Duration is not valid.
6881476
Duration cannot be less than 1 hour.
6881477
Duration cannot be more than 999 hours.
string
schedule
name
string
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced.
svm
name
string
The name of the SVM.
uuid
string
volume_efficiency_policy
comment
string
duration
integer
enabled
boolean
name
string
qos_policy
string
schedule
schedule
integer
svm
svm
type
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
