Create a volume efficiency policy
Creates a volume efficiency policy to optimize storage utilization and improve overall system performance. Use this endpoint to define efficiency parameters and schedules for managing data compression and deduplication on volumes.
HTTP method and endpoint
POST /storage/volume-efficiency-policies
Introduced in
ONTAP 9.8
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the volume efficiency policy. -
name- Name for the volume efficiency policy.
Recommended optional properties
type- Type of volume policy. -
schedule- Schedule the volume efficiency defined in minutes, hourly, daily and weekly. -
duration- Indicates the allowed duration for a session for policy type "threshold" and "auto". -
start_threshold_percent- Indicates the start threshold percentage for the policy type "threshold". It is mutually exclusive of the schedule. -
qos_policy- QoS policy for the sis operation. -
comment- A comment associated with the volume efficiency policy. -
enabled- Is the volume efficiency policy enabled?
Default property values
If not specified in POST, the following default property values are assigned:
type- auto -
enabled- true -
qos_policy- best_effort
Related ONTAP commands
volume efficiency policy create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
A comment associated with the volume efficiency policy. |
duration |
integer |
This field is used with the policy types "scheduled" and "auto" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0. |
enabled |
boolean |
Is the volume efficiency policy enabled? |
name |
string |
Name of the volume efficiency policy. |
qos_policy |
string |
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations. |
schedule |
start_threshold_percent |
integer |
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule. |
svm |
type |
string |
Type of volume efficiency policy. |
uuid |
string |
Unique identifier of volume efficiency policy. |
Example request
"comment": "string",
"duration": "5",
"enabled": 1,
"name": "default",
"qos_policy": "string",
"schedule": {
"name": "daily"
"start_threshold_percent": "30",
"svm": {
"name": "svm1",
"type": "string",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
6881341 |
Specified schedule not found. |
6881344 |
Failed to queue specified job. |
6881345 |
This operation is not permitted on a node SVM. |
6881349 |
Policy name is not valid. |
6881362 |
Threshold percentage cannot be less than 1 percent. |
6881433 |
For "{{0}}" type policy, attribute "{{1}}" is not supported. |
6881435 |
Only a policy of type "threshold" can set the "start-threshold-percent" attribute. |
6881436 |
For a policy of type "scheduled", a valid "schedule" is a required attribute. |
6881454 |
An efficiency policy of type "threshold" requires an effective cluster version of ONTAP 8.3 or later. |
6881474 |
Duration cannot be null. |
6881475 |
Duration is not valid. |
6881476 |
Duration cannot be less than 1 hour. |
6881477 |
Duration cannot be more than 999 hours. |
href |
string |
_links
schedule
name |
string |
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume_efficiency_policy
comment |
string |
duration |
integer |
enabled |
boolean |
name |
string |
qos_policy |
string |
schedule |
integer |
svm |
type |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
