Create a volume efficiency policy
Creates a volume efficiency policy to define how storage resources optimize space usage through data deduplication and compression. Use this endpoint to specify parameters such as schedule and type, tailoring the policy to meet your storage efficiency needs.
HTTP method and endpoint
POST /storage/volume-efficiency-policies
Introduced in
ONTAP 9.8
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the volume efficiency policy. -
name- Name for the volume efficiency policy.
Recommended optional properties
type- Type of volume policy. -
schedule- Schedule the volume efficiency defined in minutes, hourly, daily and weekly. -
duration- Indicates the allowed duration for a session for policy type "scheduled". -
start_threshold_percent- Indicates the start threshold percentage for the policy type "threshold". It is mutually exclusive of the schedule. -
qos_policy- QoS policy for the sis operation. -
comment- A comment associated with the volume efficiency policy. -
enabled- Is the volume efficiency policy enabled?
Default property values
If not specified in POST, the following default property values are assigned:
type- scheduled -
start_threshold_percent- 20 -
enabled- true -
qos_policy- best_effort -
schedule- daily
Related ONTAP commands
volume efficiency policy create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
A comment associated with the volume efficiency policy. |
duration |
integer |
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0. |
enabled |
boolean |
Is the volume efficiency policy enabled? |
name |
string |
Name of the volume efficiency policy. |
qos_policy |
string |
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations. |
schedule |
start_threshold_percent |
integer |
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule. |
svm |
type |
string |
Type of volume efficiency policy. |
uuid |
string |
Unique identifier of volume efficiency policy. |
Example request
"comment": "string",
"name": "string",
"qos_policy": "string",
"schedule": {
"name": "string"
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
6881341 |
Specified schedule not found. |
6881344 |
Failed to queue specified job. |
6881345 |
This operation is not permitted on a node SVM. |
6881349 |
Policy name is not valid. |
6881351 |
Policy name is too long. |
6881352 |
6881362 |
Threshold percentage cannot be less than 1 percent. |
6881433 |
For "threshold" type policy, "schedule and duration" is not supported. |
6881435 |
Only a policy of type "threshold" can set the "start-threshold-percent" attribute. |
6881454 |
An efficiency policy of type "threshold" requires an effective cluster version of ONTAP 8.3 or later. |
href |
string |
_links
schedule
name |
string |
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced. |
svm
name |
string |
uuid |
string |
volume_efficiency_policy
comment |
string |
duration |
integer |
enabled |
boolean |
name |
string |
qos_policy |
string |
schedule |
integer |
svm |
type |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
