Create a volume on an SVM and storage aggregates
Creates a new volume on a specific SVM and associated storage aggregates. Use this endpoint when you need to provision additional storage capacity within your ONTAP environment.
HTTP method and endpoint
POST /storage/volumes
Introduced in
ONTAP 9.6
Usage notes
Creates a volume on a specified SVM and storage aggregates.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the volume. -
name- Name of the volume. -
aggregates.nameoraggregates.uuid- Existing aggregates in which to create the volume.
Default property values
state- online -
size- 20MB -
style- flexvol -
type- rw -
encryption.enabled- false -
snapshot_policy.name- default -
guarantee.type- volume -
anti_ransomware.state- default
Related ONTAP commands
volume create -
volume clone create
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
activity_tracking |
aggregates |
array[aggregates] |
Aggregate hosting the volume. Required on POST. |
analytics |
anti_ransomware |
Anti-ransomware related information of the volume. |
anti_ransomware_state |
string |
The Anti-ransomware state of the volume. If no "anti_ransomware_state" property is specified, the volume inherits the value from its parent SVM's "anti_ransomware_default_volume_state" property. If this value is "disabled", Anti-ransomware is disabled on the volume. If this value is "enabled", Anti-ransomware is enabled on the volume and alerts are raised if any suspect is detected for those volumes. If this value is "dry_run", Anti-ransomware is enabled in the dry-run or learning mode on the volume. The "dry_run" state is same as the "enabled" state except that the analytics data is used here for learning. No alerts are raised for any detections or violations. If this value is "paused", Anti-ransomware is paused on the volume. Additionally, three more states are available, which are only valid for GET. If this value is "disable_in_progress", Anti-ransomware monitoring is being disabled and a cleanup operation is in effect. If this value is "enable_paused", Anti-ransomware is paused on the volume from its earlier enabled state. If this value is "dry_run_paused", Anti-ransomware monitoring is paused on the volume from its earlier dry_run state. For POST, the valid Anti-ransomware states are only "disabled", "enabled" and "dry_run", whereas for PATCH, "paused" is also valid along with the three valid states for POST. |
application |
autosize |
clone |
cloud_retrieval_policy |
string |
This parameter specifies the cloud retrieval policy for the volume. This policy determines which tiered out blocks to retrieve from the capacity tier to the performance tier. The available cloud retrieval policies are "default" policy retrieves tiered data based on the underlying tiering policy. If the tiering policy is 'auto', tiered data is retrieved only for random client driven data reads. If the tiering policy is 'none' or 'snapshot_only', tiered data is retrieved for random and sequential client driven data reads. If the tiering policy is 'all', tiered data is not retrieved. "on_read" policy retrieves tiered data for all client driven data reads. "never" policy never retrieves tiered data. "promote" policy retrieves all eligible tiered data automatically during the next scheduled scan. It is only supported when the tiering policy is 'none' or 'snapshot_only'. If the tiering policy is 'snapshot_only', the only data brought back is the data in the AFS. Data that is only in a snapshot copy stays in the cloud and if tiering policy is 'none' then all data is retrieved. |
comment |
string |
A comment for the volume. Valid in POST or PATCH. |
consistency_group |
Consistency group the volume is part of. |
constituents |
array[constituents] |
constituents_per_aggregate |
integer |
Specifies the number of times to iterate over the aggregates listed with the "aggregates.name" or "aggregates.uuid" when creating or expanding a FlexGroup volume. If a volume is being created on a single aggregate, the system creates a flexible volume if the "constituents_per_aggregate" field is not specified, or a FlexGroup volume if it is specified. If a volume is being created on multiple aggregates, the system always creates a FlexGroup volume. The root constituent of a FlexGroup volume is always placed on the first aggregate in the list. |
convert_unicode |
boolean |
Specifies whether directory Unicode format conversion is enabled when directories are accessed by NFS clients. |
create_time |
string |
Creation time of the volume. This field is generated when the volume is created. |
efficiency |
encryption |
error_state |
files |
flash_pool |
flexcache_endpoint_type |
string |
FlexCache endpoint type. none ‐ The volume is neither a FlexCache nor origin of any FlexCache. cache ‐ The volume is a FlexCache volume. origin ‐ The volume is origin of a FlexCache volume. |
flexgroup |
guarantee |
is_object_store |
boolean |
Specifies whether the volume is provisioned for an object store server. |
is_svm_root |
boolean |
Specifies whether the volume is a root volume of the SVM it belongs to. |
language |
string |
Language encoding setting for volume. If no language is specified, the volume inherits its SVM language encoding setting. |
max_dir_size |
integer |
Maximum directory size. This value sets maximum size, in bytes, to which a directory can grow. The default maximum directory size for FlexVol volumes is model-dependent, and optimized for the size of system memory. Before increasing the maximum directory size, involve technical support. |
movement |
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation. Volume movement on FlexGroup constituents are not supported. |
name |
string |
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroups, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST. |
nas |
qos |
QoS information |
quota |
Quotas track the space or file usage of a user, group, or qtree in a FlexVol or a FlexGroup volume. |
scheduled_snapshot_naming_scheme |
string |
Naming Scheme for automatic Snapshot copies:
size |
integer |
Physical size of the volume, in bytes. The minimum size for a FlexVol volume is 20MB and the minimum size for a FlexGroup volume is 200MB per constituent. The recommended size for a FlexGroup volume is a minimum of 100GB per constituent. For all volumes, the default size is equal to the minimum size. |
snaplock |
snapmirror |
Specifies attributes for SnapMirror protection. |
snapshot_count |
integer |
Number of Snapshot copies in the volume. |
snapshot_policy |
This is a reference to the Snapshot copy policy. |
space |
state |
string |
Volume state. Client access is supported only when volume is online and junctioned. Taking volume to offline or restricted state removes its junction path and blocks client access. When volume is in restricted state some operations like parity reconstruction and iron on commit are allowed. The 'mixed' state applies to FlexGroup volumes only and cannot be specified as a target state. An 'error' state implies that the volume is not in a state to serve data. |
status |
array[string] |
Describes the current status of a volume. |
style |
string |
The style of the volume. If "style" is not specified, the volume type is determined based on the specified aggregates. Specifying a single aggregate, without "constituents_per_aggregate", creates a flexible volume. Specifying multiple aggregates, or a single aggregate with "constituents_per_aggregate", creates a FlexGroup. Specifying a volume "style" creates a volume of that type. For example, if the style is "flexvol" you must specify a single aggregate. If the style is "flexgroup", the system either uses the specified aggregates or automatically provisions aggregates if there are no specified aggregates. The style "flexgroup_constiutent" is not supported when creating a volume. flexvol ‐ flexible volumes and FlexClone volumes flexgroup ‐ FlexGroup volumes flexgroup_constituent ‐ FlexGroup constituents. |
svm |
SVM containing the volume. Required on POST. |
tiering |
type |
string |
Type of the volume.
rw ‐ read-write volume.
dp ‐ data-protection volume.
ls ‐ load-sharing |
use_mirrored_aggregates |
boolean |
Specifies whether mirrored aggregates are selected when provisioning a FlexGroup without specifying "aggregates.name" or "aggregates.uuid". Only mirrored aggregates are used if this parameter is set to 'true' and only unmirrored aggregates are used if this parameter is set to 'false'. Aggregate level mirroring for a FlexGroup can be changed by moving all of the constituents to the required aggregates. The default value is 'true' for a MetroCluster configuration and is 'false' for a non-MetroCluster configuration. |
uuid |
string |
Example request
"access_time_enabled": null,
"activity_tracking": {
"state": "string",
"unsupported_reason": {
"code": "124518405",
"message": "Volume activity tracking cannot be enabled on volumes that contain LUNs."
"aggregates": [
"name": "aggr1",
"analytics": {
"scan_progress": 17,
"state": "string",
"code": "111411207",
"message": "File system analytics cannot be enabled on volumes that contain LUNs."
"anti_ransomware": {
"attack_probability": "string",
"dry_run_start_time": "string",
"state": "string"
"anti_ransomware_state": "string",
"application": {
"name": "string",
"uuid": "1cd8a442-86d1-11e0-ae1d-123478563412"
"autosize": {
"mode": "string"
"clone": {
"parent_snapshot": {
"name": "this_snapshot",
"parent_svm": {
"name": "svm1",
"parent_volume": {
"name": "volume1",
"split_complete_percent": 0,
"split_estimate": 0
"cloud_retrieval_policy": "string",
"comment": "string",
"consistency_group": {
"name": "consistency_group_1",
"constituents": [
"aggregates": {
"name": "string",
"movement": {
"cutover_window": 30,
"destination_aggregate": {
"name": "aggr1",
"percent_complete": 0,
"state": "replicating",
"tiering_policy": "string"
"name": "string",
"space": {
"available": 0,
"block_storage_inactive_user_data": 0,
"capacity_tier_footprint": 0,
"footprint": 0,
"local_tier_footprint": 0,
"logical_space": {
"available": 0,
"used_by_afs": 0
"metadata": 0,
"over_provisioned": 0,
"performance_tier_footprint": 0,
"snapshot": {
"used": 0
"total_footprint": 0,
"used": 0
"create_time": "2018-06-04T19:00:00Z",
"efficiency": {
"application_io_size": "string",
"compaction": "string",
"compression": "string",
"cross_volume_dedupe": "string",
"dedupe": "string",
"last_op_begin": "string",
"last_op_end": "string",
"last_op_err": "string",
"last_op_size": 0,
"last_op_state": "string",
"op_state": "string",
"path": "string",
"progress": "string",
"schedule": "string",
"state": "string",
"storage_efficiency_mode": "string",
"type": "string"
"encryption": {
"key_id": "string",
"key_manager_attribute": "CRN=v1:bluemix:public:containers-kubernetes:us-south:a/asdfghjkl1234:asdfghjkl1234:worker:kubernetes-asdfghjkl-worker1",
"rekey": null,
"state": "string",
"status": {
"code": "string",
"message": "string"
"type": "string"
"files": {
"used": 0
"flash_pool": {
"cache_eligibility": "string",
"cache_retention_priority": "string",
"caching_policy": "string"
"flexcache_endpoint_type": "string",
"flexgroup": {
"name": "my_flexgroup",
"uuid": "75c9cfb0-3eb4-11eb-9fb4-005056bb088a"
"guarantee": {
"type": "string"
"language": "string",
"movement": {
"name": "aggr1",
"start_time": "2020-12-07T03:45:12-05:00",
"name": "vol_cs_dept",
"nas": {
"export_policy": {
"id": 100,
"name": "default"
"junction_parent": {
"name": "vs1_root",
"path": "/user/my_volume",
"security_style": "string",
"unix_permissions": 755
"qos": {
"policy": {
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"queue_for_encryption": null,
"quota": {
"state": "string"
"scheduled_snapshot_naming_scheme": "string",
"snaplock": {
"append_mode_enabled": "",
"autocommit_period": "P30M",
"compliance_clock_time": "2018-06-04T19:00:00Z",
"expiry_time": "Wed Sep 5 11:02:42 GMT 2018",
"is_audit_log": 1,
"litigation_count": 10,
"privileged_delete": "enabled",
"retention": {
"default": "P30Y",
"maximum": "P30Y",
"minimum": "P30Y"
"type": "enterprise",
"unspecified_retention_file_count": 10
"snapshot_count": 0,
"snapshot_policy": {
"name": "default",
"space": {
"available": 0,
"block_storage_inactive_user_data_percent": 0,
"cross_volume_dedupe_metafiles_footprint": 0,
"cross_volume_dedupe_metafiles_temporary_footprint": 0,
"dedupe_metafiles_footprint": 0,
"dedupe_metafiles_temporary_footprint": 0,
"delayed_free_footprint": 0,
"file_operation_metadata": 0,
"filesystem_size": 0,
"footprint": 0,
"logical_space": {
"available": 0,
"used": 0,
"used_by_afs": 0,
"used_by_snapshots": 0,
"used_percent": 0
"metadata": 0,
"overwrite_reserve": 0,
"overwrite_reserve_used": 0,
"percent_used": 0,
"size_available_for_snapshots": 0,
"snapmirror_destination_footprint": 0,
"snapshot": {
"reserve_available": 0,
"reserve_size": 0,
"space_used_percent": 0,
"used": 0
"snapshot_reserve_unusable": 0,
"snapshot_spill": 0,
"used": 0,
"user_data": 0,
"volume_guarantee_footprint": 0
"state": "string",
"status": [
"string"
"style": "string",
"svm": {
"name": "svm1",
"tiering": {
"object_tags": [
"string"
"policy": "string"
"type": "string",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
787140 |
One of "aggregates.uuid", "aggregates.name", or "style" must be provided. |
787141 |
The specified "aggregates.name" and "aggregates.uuid" refer to different aggregates. |
917526 |
The volume name specified is a duplicate. |
917829 |
Volume autosize grow threshold must be larger than autosize shrink threshold. |
917831 |
Volume minimum autosize must be smaller than the maximum autosize. |
917835 |
Maximum allowed snapshot.reserve_percent value during a volume creation is 90. Use PATCH to set it to a higher value after the volume has been created. |
918191 |
Flexvol tiering min cooling days requires an effective cluster version of ONTAP 9.4 or later. |
918194 |
Tiering min cooling days not supported for SVMDR. |
918195 |
Tiering min cooling days not supported for non data volumes. |
918196 |
Tiering min cooling days not allowed for the provided tiering policy. |
918215 |
FlexGroup tiering min cooling days requires an effective cluster version of ONTAP 9.5 or later. |
918233 |
The target field cannot be specified for this operation. |
918236 |
The specified "parent_volume.uuid" and "parent_volume.name" do not refer to the same volume. |
918240 |
The target style is an invalid volume style. |
918241 |
The target style is an unsupported volume style for volume creation. |
918242 |
When creating a flexible volume, exactly one aggregate must be specified via either "aggregates.name" or "aggregates.uuid". |
918243 |
The specified Snapshot copy UUID is not correct for the specified Snapshot copy name. |
918244 |
Invalid "volume.type" for clone volume. |
918246 |
"volume.clone.parent_volume.name" or "volume.clone.parent_volume.uuid" must be provided. |
918247 |
Specifying a value is not valid for a volume FlexClone creation. |
918252 |
"nas.path" is invalid. |
918290 |
cloud retrieval policy requires an effective cluster version of 9.8 or later. |
918291 |
Invalid volume cloud retrieval policy for the provided tiering policy. |
918292 |
cloud retrieval policy not supported for non data volume. |
918521 |
The volume maximum autosize must be smaller than or equal to the maximum volume size. |
918524 |
Volume minimum autosize must be less than or equal to the current volume size. |
2621706 |
The specified "svm.uuid" and "svm.name" do not refer to the same SVM. |
2621707 |
No SVM was specified. Either "svm.name" or "svm.uuid" must be supplied. |
111411205 |
File system analytics requires an effective cluster version of 9.8 or later. |
111411206 |
The specified "analytics.state" is invalid. |
111411207 |
File system analytics cannot be enabled on volumes that contain LUNs. |
href |
string |
_links
unsupported_reason
code |
string |
If volume activity tracking is not supported on the volume, this field provides an appropriate error code. |
message |
string |
If volume activity tracking is not supported on the volume, this field provides an error message detailing why this is the case. |
activity_tracking
state |
string |
Activity tracking state of the volume. If this value is "on", ONTAP collects top metrics information for the volume in real time. There is a slight impact to I/O performance in order to collect this information. If this value is "off", no activity tracking information is collected or available to view.
supported |
boolean |
This field indicates whether or not volume activity tracking is supported on the volume. If volume activity tracking is not supported, the reason why is provided in the "activity_tracking.unsupported_reason" field. |
unsupported_reason |
aggregates
Aggregate
name |
string |
uuid |
string |
unsupported_reason
code |
string |
If file system analytics is not supported on the volume, this field provides the error code explaining why. |
message |
string |
If file system analytics is not supported on the volume, this field provides the error message explaining why. |
analytics
scan_progress |
integer |
Percentage of files in the volume that the file system analytics initialization scan has processed. Only returned when the state is |
state |
string |
File system analytics state of the volume. If this value is "on", ONTAP collects extra file system analytics information for all directories on the volume. There will be a slight impact to I/O performance to collect this information. If this value is "off", file system analytics information is not collected and not available to be viewed. If this value is "initializing", that means file system analytics was recently turned on, and the initialization scan to gather information all all existing files and directories is currently running. If this value is 'unknown' that means there was an internal error when determining the file system analytics state for the volume.
supported |
boolean |
This field indicates whether or not file system analytics is supported on the volume. If file system analytics is not supported, the reason will be specified in the "analytics.unsupported_reason" field. |
anti_ransomware_attack_report
_links |
time |
string |
Timestamp at which ransomware attack is observed. |
space
snapshot_count |
integer |
Total number of Anti-ransomware backup Snapshot copies. |
used |
integer |
Total space in bytes used by the Anti-ransomware feature. |
used_by_logs |
integer |
Space in bytes used by the Anti-ransomware analytics logs. |
used_by_snapshots |
integer |
Space in bytes used by the Anti-ransomware backup Snapshot copies. |
suspect_files
count |
integer |
Total number of |
format |
string |
File formats observed by the Anti-ransomware analytics engine on the volume. |
anti_ransomware
attack_probability |
string |
Probability of a ransomware attack.
dry_run_start_time |
string |
Time when Anti-ransomware monitoring |
state |
string |
Anti-ransomware state.
application
name |
string |
Name of the application to which the volume belongs. Available only when the volume is part of an application. |
uuid |
string |
UUID of the application to which the volume belongs. Available only when the volume is part of an application. |
autosize
grow_threshold |
integer |
Used space threshold size, in percentage, for the automatic growth of the volume. When the amount of used space in the volume becomes greater than this threhold, the volume automatically grows unless it has reached the maximum size. The volume grows when 'space.used' is greater than this percent of 'space.size'. The 'grow_threshold' size cannot be less than or equal to the 'shrink_threshold' size.. |
maximum |
integer |
Maximum size in bytes up to which a volume grows automatically. This size cannot be less than the current volume size, or less than or equal to the minimum size of volume. |
minimum |
integer |
Minimum size in bytes up to which the volume shrinks automatically. This size cannot be greater than or equal to the maximum size of volume. |
mode |
string |
Autosize mode for the volume. grow ‐ Volume automatically grows when the amount of used space is above the 'grow_threshold' value. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled. |
shrink_threshold |
integer |
Used space threshold size, in percentage, for the automatic shrinkage of the volume. When the amount of used space in the volume drops below this threshold, the volume automatically shrinks unless it has reached the minimum size. The volume shrinks when the 'space.used' is less than the 'shrink_threshold' percent of 'space.size'. The 'shrink_threshold' size cannot be greater than or equal to the 'grow_threshold' size. |
snapshot_reference
name |
string |
uuid |
string |
parent_svm
name |
string |
The name of the SVM. |
uuid |
string |
parent_volume
name |
string |
The name of the volume. |
uuid |
string |
clone
is_flexclone |
boolean |
Specifies if this volume is a normal FlexVol or FlexClone. This field needs to be set when creating a FlexClone. Valid in POST. |
parent_snapshot |
parent_svm |
parent_volume |
split_complete_percent |
integer |
Percentage of FlexClone blocks split from its parent volume. |
split_estimate |
integer |
Space required by the containing-aggregate to split the FlexClone volume. |
split_initiated |
boolean |
This field is set when split is executed on any FlexClone, that is when the FlexClone volume is split from its parent FlexVol. This field needs to be set for splitting a FlexClone form FlexVol. Valid in PATCH. |
consistency_group
name |
string |
The name of the consistency group to which the volume belongs. Available only when the volume is part of a consistency group. If this volume belongs to a child consistency group, then this will be the UUID of the parent consistency group. |
uuid |
string |
The UUID of the consistency group to which the volume belongs. Available only when the volume is part of a consistency group. If this volume belongs to a child consistency group, then this will be the UUID of the parent consistency group. |
aggregates
name |
string |
Name of the aggregate hosting the FlexGroup Constituent. |
uuid |
string |
Unique identifier for the aggregate. |
Aggregate
name |
string |
uuid |
string |
movement
cutover_window |
integer |
Time window in seconds for cutover. The allowed range is between 30 to 300 seconds. |
destination_aggregate |
Aggregate |
percent_complete |
integer |
Completion percentage |
state |
string |
State of volume move operation. PATCH the state to "aborted" to abort the move operation. PATCH the state to "cutover" to trigger cutover. PATCH the state to "paused" to pause the volume move operation in progress. PATCH the state to "replicating" to resume the paused volume move operation. PATCH the state to "cutover_wait" to go into cutover manually. When volume move operation is waiting to go into "cutover" state, this is indicated by the "cutover_pending" state. A change of state is only supported if volume movement is in progress. |
tiering_policy |
string |
Tiering policy for FabricPool |
logical_space
available |
integer |
The amount of space available in this volume with storage efficiency space considered used, in bytes. |
enforcement |
boolean |
Specifies whether space accounting for operations on the volume is done along with storage efficiency. |
reporting |
boolean |
Specifies whether space reporting on the volume is done along with storage efficiency. |
used_by_afs |
integer |
The virtual space used by AFS alone (includes volume reserves) and along with storage efficiency, in bytes. |
snapshot
autodelete_enabled |
boolean |
Specifies whether Snapshot copy autodelete is currently enabled on this volume. |
reserve_percent |
integer |
The space that has been set aside as a reserve for Snapshot copy usage, in percent. |
used |
integer |
The total space used by Snapshot copies in the volume, in bytes. |
space
afs_total |
integer |
Total size of AFS, excluding snap-reserve, in bytes. |
available |
integer |
The available space, in bytes. |
available_percent |
integer |
The space available, as a percent. |
block_storage_inactive_user_data |
integer |
The size that is physically used in the block storage of the volume and has a cold temperature. In bytes. This parameter is only supported if the volume is in an aggregate that is either attached to a cloud store or could be attached to a cloud store. |
capacity_tier_footprint |
integer |
Space used by capacity tier for this volume in the FabricPool aggregate, in bytes. |
footprint |
integer |
Data used for this volume in the aggregate, in bytes. |
local_tier_footprint |
integer |
Space used by the local tier for this volume in the aggregate, in bytes. |
logical_space |
metadata |
integer |
Space used by the volume metadata in the aggregate, in bytes. |
over_provisioned |
integer |
The amount of space not available for this volume in the aggregate, in bytes. |
performance_tier_footprint |
integer |
Space used by the performance tier for this volume in the FabricPool aggregate, in bytes. |
size |
integer |
Total provisioned size. The default size is equal to the minimum size of 20MB, in bytes. |
snapshot |
total_footprint |
integer |
Data and metadata used for this volume in the aggregate, in bytes. |
used |
integer |
The virtual space used (includes volume reserves) before storage efficiency, in bytes. |
used_by_afs |
integer |
The space used by Active Filesystem, in bytes. |
used_percent |
integer |
The virtual space used (includes volume reserves) before storage efficiency, as a percent. |
constituents
aggregates |
movement |
name |
string |
FlexGroup Constituents name |
space |
policy
name |
string |
Specifies the name of the efficiency policy. Valid for PATCH. |
efficiency
application_io_size |
string |
Block size to use by compression. Valid for POST. |
compaction |
string |
The system can be enabled/disabled compaction. inline ‐ Data will be compacted first and written to the volume. none ‐ None mixed ‐ Read only field for FlexGroups, where some of the constituent volumes are compaction enabled and some are disabled. |
compression |
string |
The system can be enabled/disabled compression. inline ‐ Data will be compressed first and written to the volume. background ‐ Data will be written to the volume and compressed later. both ‐ Inline compression compresses the data and write to the volume, background compression compresses only the blocks on which inline compression is not run. none ‐ None mixed ‐ Read only field for FlexGroups, where some of the constituent volumes are compression enabled and some are disabled. |
cross_volume_dedupe |
string |
The system can be enabled/disabled cross volume dedupe. it can be enabled only when dedupe is enabled. inline ‐ Data will be cross volume deduped first and written to the volume. background ‐ Data will be written to the volume and cross volume deduped later. both ‐ Inline cross volume dedupe dedupes the data and write to the volume, background cross volume dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroups, where some of the constituent volumes are cross volume dedupe enabled and some are disabled. |
dedupe |
string |
The system can be enabled/disabled dedupe. inline ‐ Data will be deduped first and written to the volume. background ‐ Data will be written to the volume and deduped later. both ‐ Inline dedupe dedupes the data and write to the volume, background dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroups, where some of the constituent volumes are dedupe enabled and some are disabled. |
last_op_begin |
string |
Last sis operation begin timestamp. |
last_op_end |
string |
Last sis operation end timestamp. |
last_op_err |
string |
Last sis operation error text. |
last_op_size |
integer |
Last sis operation size. |
last_op_state |
string |
Last sis operation state. |
op_state |
string |
Sis status of the volume. |
path |
string |
Absolute volume path of the volume. |
progress |
string |
Sis progress of the volume. |
schedule |
string |
Schedule associated with volume. |
state |
string |
Storage efficiency state of the volume. Currently, this field supports POST/PATCH only for RW (Read-Write) volumes on FSx for ONTAP. disabled ‐ All storage efficiency features are disabled. mixed ‐ Read-only field for FlexGroup volumes, storage efficiency is enabled on certain constituents and disabled on others. On FSx for ONTAP ‐ enabled ‐ All supported storage efficiency features for the volume are enabled. custom ‐ Read-only field currently only supported for the FSx for ONTAP, user-defined storage efficiency features are enabled. For other platforms ‐ enabled ‐ At least one storage efficiency feature for the volume is enabled.
storage_efficiency_mode |
string |
Storage efficiency mode used by volume. This parameter is supported only on AFF platform. |
type |
string |
Sis Type of the volume. |
status
code |
string |
Encryption progress message code. |
message |
string |
Encryption progress message. |
encryption
enabled |
boolean |
Creates an encrypted or an unencrypted volume. For POST, when set to 'true', a new key is generated and used to encrypt the given volume. In that case, the underlying SVM must be configured with the key manager. When set to 'false', the volume created will be unencrypted. For PATCH, when set to 'true', it encrypts an unencrypted volume. Specifying the parameter as 'false' in a PATCH operation for an encrypted volume is only supported when moving the volume to another aggregate. |
key_id |
string |
The key ID used for creating encrypted volume. A new key-id is generated for creating an encrypted volume. This key-id is associated with the generated key. |
key_manager_attribute |
string |
Specifies an additional key manager attribute that is an identifier-value pair, separated by '='. For example, CRN=unique-value. This parameter is required when using the POST method and an IBM Key Lore key manager is configured on the SVM. |
state |
string |
Volume encryption state. encrypted ‐ The volume is completely encrypted. encrypting ‐ Encryption operation is in progress. partial ‐ Some constituents are encrypted and some are not. Applicable only for FlexGroup volume. rekeying. Encryption of volume with a new key is in progress. unencrypted ‐ The volume is a plain-text one. |
status |
type |
string |
Volume encryption type. none ‐ The volume is a plain-text one. volume ‐ The volume is encrypted with NVE (NetApp Volume Encryption). aggregate ‐ The volume is encrypted with NAE (NetApp Aggregate Encryption). |
error_state
has_bad_blocks |
boolean |
Indicates whether the volume has any corrupt data blocks. If the damaged data block is accessed, an IO error, such as EIO for NFS or STATUS_FILE_CORRUPT for CIFS, is returned. |
is_inconsistent |
boolean |
Indicates whether the file system has any inconsistencies. true ‐ File system is inconsistent. false ‐ File system in not inconsistent. |
files
maximum |
integer |
The maximum number of files (inodes) for user-visible data allowed on the volume. This value can be increased or decreased. Increasing the maximum number of files does not immediately cause additional disk space to be used to track files. Instead, as more files are created on the volume, the system dynamically increases the number of disk blocks that are used to track files. The space assigned to track files is never freed, and this value cannot be decreased below the current number of files that can be tracked within the assigned space for the volume. Valid in PATCH. |
used |
integer |
Number of files (inodes) used for user-visible data permitted on the volume. This field is valid only when the volume is online. |
flash_pool
cache_eligibility |
string |
If this parameter is specified, the command displays information only about the volume or volumes with the specified Flash Pool caching attributes. |
cache_retention_priority |
string |
If this parameter is specified, the command displays the volumes that match the specified cache retention priority policy. A cache retention priority defines how long the blocks of a volume will be cached in the Flash Pool once they become cold. |
caching_policy |
string |
This optionally specifies the caching policy to apply to the volume. A caching policy defines how the system caches a volume's data in Flash Cache modules. If a caching policy is not assigned to a volume, the system uses the caching policy that is assigned to the containing SVM. If a caching policy is not assigned to the containing SVM, the system uses the default cluster-wide policy. |
flexgroup
name |
string |
Name of the FlexGroup volume that the constituent is part of. |
uuid |
string |
Unique identifier for the FlexGroup volume that the constituent is part of. |
guarantee
honored |
boolean |
Is the space guarantee of this volume honored in the aggregate? |
type |
string |
The type of space guarantee of this volume in the aggregate. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
cloud
Performance numbers (IOPS and latency) for cloud store. These numbers are relevant only for volumes hosted on FabricPools.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
timestamp |
string |
The timestamp of the performance data. |
flexcache
Performance number for FlexCache used to measure cache effectiveness.
bandwidth_savings |
integer |
Bandwidth savings denoting the amount of data served locally by the cache, in bytes. |
cache_miss_percent |
integer |
Cache miss percentage. |
duration |
string |
status |
string |
timestamp |
string |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS, latency and throughput.
cloud |
Performance numbers (IOPS and latency) for cloud store. These numbers are relevant only for volumes hosted on FabricPools. |
duration |
string |
flexcache |
Performance number for FlexCache used to measure cache effectiveness. |
iops |
latency |
status |
string |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
movement
cutover_window |
integer |
Aggregate |
percent_complete |
integer |
start_time |
string |
Start time of volume move. |
state |
string |
tiering_policy |
string |
export_policy
Export Policy
id |
integer |
name |
string |
junction_parent
name |
string |
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume. |
uuid |
string |
Unique identifier for the parent volume. |
nas
export_policy |
Export Policy |
gid |
integer |
The UNIX group ID of the volume. Valid in POST or PATCH. |
junction_parent |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the volume is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one volume can be mounted at any given junction path. An empty path in POST creates an unmounted volume. An empty path in PATCH deactivates and unmounts the volume. Taking a volume offline or restricted state removes its junction path. This attribute is reported in GET only when the volume is mounted. |
security_style |
string |
Security style associated with the volume. Valid in POST or PATCH. mixed ‐ Mixed-style security ntfs ‐ NTFS/WIndows-style security unified ‐ Unified-style security, unified UNIX, NFS and CIFS permissions unix ‐ Unix-style security. |
uid |
integer |
The UNIX user ID of the volume. Valid in POST or PATCH. |
unix_permissions |
integer |
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write) and 1 (execute). First digit selects the set user ID(4), set group ID (2) and sticky (1) attributes. The second digit selects permission for the owner of the file; the third selects permissions for other users in the same group; the fourth for other users not in the group. Valid in POST or PATCH. For security style "mixed" or "unix", the default setting is 0755 in octal (493 in decimal) and for security style "ntfs", the default setting is 0000. In cases where only owner, group and other permissions are given (as in 755, representing the second, third and fourth dight), first digit is assumed to be zero. |
policy
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
qos
QoS information
policy |
quota
enabled |
boolean |
This option is used to enable or disable the quota for the volume. This option is valid only in PATCH. Quotas are enabled for FlexVols or FlexGroup volumes when the quota state is "on". Quotas are disabled for FlexVols or FlexGroup volumes when the quota state is "off". |
state |
string |
Quota state of the volume |
retention
default |
string |
Specifies the default retention period that is applied to files while committing them to the WORM state without an associated retention period. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "P |
maximum |
string |
Specifies the maximum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "P |
minimum |
string |
Specifies the minimum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, month,s and days is represented in the ISO-8601 format as "P |
snaplock
append_mode_enabled |
boolean |
Specifies if the volume append mode is enabled or disabled. When it is enabled, all the files created with write permissions on the volume are, by default, WORM appendable files. The user can append the data to a WORM appendable file but cannot modify the existing contents of the file nor delete the file until it expires. |
autocommit_period |
string |
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater than the autocommit period of the volume are committed to the WORM state. The autocommit period value represents a duration and must be specified in the ISO-8601 duration format. The autocommit period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "P |
compliance_clock_time |
string |
This is the volume compliance clock time which is used to manage the SnapLock objects in the volume. |
expiry_time |
string |
Expiry time of the volume. |
is_audit_log |
boolean |
Indicates if this volume has been configured as SnapLock audit log volume for the SVM . |
litigation_count |
integer |
Litigation count indicates the number of active legal-holds on the volume. |
privileged_delete |
string |
Specifies the privileged-delete attribute of a SnapLock volume. On a SnapLock Enterprise (SLE) volume, a designated privileged user can selectively delete files irrespective of the retention time of the file. SLE volumes can have privileged delete as disabled, enabled or permanently_disabled and for SnapLock Compliance (SLC) volumes it is always permanently_disabled. |
retention |
type |
string |
The SnapLock type of the volume. compliance ‐ A SnapLock Compliance(SLC) volume provides the highest level of WORM protection and an administrator cannot destroy a SLC volume if it contains unexpired WORM files. enterprise ‐ An administrator can delete a SnapLock Enterprise(SLE) volume. non_snaplock ‐ Indicates the volume is non-snaplock. |
unspecified_retention_file_count |
integer |
Indicates the number of files with an unspecified retention time in the volume. |
destinations
is_cloud |
boolean |
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to a cloud destination. |
is_ontap |
boolean |
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to an ONTAP destination.
snapmirror
destinations |
is_protected |
boolean |
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data. |
snapshot_policy
name |
string |
uuid |
string |
logical_space
available |
integer |
enforcement |
boolean |
reporting |
boolean |
used |
integer |
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), in bytes. |
used_by_afs |
integer |
used_by_snapshots |
integer |
Size that is logically used across all Snapshot copies in the volume, in bytes. |
used_percent |
integer |
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), as a percentage. |
snapshot
boolean |
reserve_available |
integer |
Size available for Snapshot copies within the Snapshot copy reserve, in bytes. |
reserve_percent |
integer |
reserve_size |
integer |
Size in the volume that has been set aside as a reserve for Snapshot copy usage, in bytes. |
space_used_percent |
integer |
Percentage of snapshot reserve size that has been used. |
used |
integer |
space
afs_total |
integer |
available |
integer |
available_percent |
integer |
integer |
block_storage_inactive_user_data_percent |
integer |
Percentage of size that is physically used in the performance tier of the volume. |
integer |
cross_volume_dedupe_metafiles_footprint |
integer |
Cross volume deduplication metadata footprint, in bytes. |
cross_volume_dedupe_metafiles_temporary_footprint |
integer |
Cross volume temporary deduplication metadata footprint, in bytes. |
integer |
Deduplication metadata footprint, in bytes. |
integer |
Temporary deduplication metadata footprint, in bytes. |
delayed_free_footprint |
integer |
Delayed free blocks footprint, in bytes. |
expected_available |
integer |
Size that should be available for the volume, irrespective of available size in the aggregate, in bytes. |
file_operation_metadata |
integer |
File operation metadata footprint, in bytes. |
filesystem_size |
integer |
Total usable size of the volume, in bytes. |
filesystem_size_fixed |
boolean |
Specifies whether the file system is to remain of the same size when set to true or to grow when set to false. This option is automatically set to true when a volume becomes SnapMirrored. |
footprint |
integer |
fractional_reserve |
integer |
Used to change the amount of space reserved for overwrites of reserved objects in a volume. |
full_threshold_percent |
integer |
Volume full threshold percentage at which EMS warnings can be sent. |
integer |
logical_space |
metadata |
integer |
nearly_full_threshold_percent |
integer |
Volume nearly full threshold percentage at which EMS warnings can be sent. |
over_provisioned |
integer |
overwrite_reserve |
integer |
Reserved space for overwrites, in bytes. |
overwrite_reserve_used |
integer |
Overwrite logical reserve space used, in bytes. |
percent_used |
integer |
Percentage of the volume size that is used. |
integer |
physical_used |
integer |
Size that is physically used in the volume, in bytes. |
physical_used_percent |
integer |
Size that is physically used in the volume, as a percentage. |
size |
integer |
size_available_for_snapshots |
integer |
Available space for Snapshot copies from snap-reserve, in bytes. |
snapmirror_destination_footprint |
integer |
SnapMirror destination footprint, in bytes. |
snapshot |
snapshot_reserve_unusable |
integer |
Snapshot reserve that is not available for Snapshot copy creation, in bytes. |
snapshot_spill |
integer |
Space used by the snapshot copies beyond the snap-reserve, in bytes. |
total_footprint |
integer |
used |
integer |
used_by_afs |
integer |
user_data |
integer |
User data, in bytes. |
volume_guarantee_footprint |
integer |
Space reserved for future writes in the volume, in bytes. |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
cloud
These are raw performance numbers (IOPS and latency) for the cloud store. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. These numbers are relevant only for volumes hosted on FabricPools.
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
timestamp |
string |
flexcache_raw
Performance numbers for FlexCache used to measure cache effectiveness.
cache_miss_blocks |
integer |
Blocks retrieved from origin in case of a cache miss. This can be divided by the raw client_requested_blocks and multiplied by 100 to calculate the cache miss percentage. |
client_requested_blocks |
integer |
Total blocks requested by the client. |
status |
string |
timestamp |
string |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
cloud |
These are raw performance numbers (IOPS and latency) for the cloud store. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. These numbers are relevant only for volumes hosted on FabricPools. |
flexcache_raw |
Performance numbers for FlexCache used to measure cache effectiveness. |
iops_raw |
latency_raw |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
name |
string |
uuid |
string |
tiering
min_cooling_days |
integer |
This parameter specifies the minimum number of days that user data blocks of the volume must be cooled before they can be considered cold and tiered out to the cloud tier. Note that this parameter is only used for tiering purposes and does not affect the reporting of inactive data. The value specified should be greater than the frequency with which applications in the volume shift between different sets of data. This parameter cannot be set when volume tiering policy is either "none" or "all". The default value of this parameter depends on the volume's tiering policy. See the tiering policy section of this documentation for corresponding default values. If the tiering policy on the volume gets changed, then this parameter will be reset to the default value corresponding to the new tiering policy. |
object_tags |
array[string] |
This parameter specifies tags of a volume for objects stored on a FabricPool-enabled aggregate. Each tag is a key,value pair and should be in the format "key=value". |
policy |
string |
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH. all ‐ This policy allows tiering of both Snapshot copies and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks. auto ‐ This policy allows tiering of both snapshot and active file system user data to the cloud store none ‐ Volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the volume Snapshot copies not associated with the active file system. The default tiering policy is "snapshot-only" for a FlexVol and "none" for a FlexGroup. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy is 31 days. |
supported |
boolean |
This parameter specifies whether or not FabricPools are selected when provisioning a FlexGroup without specifying "aggregates.name" or "aggregates.uuid". Only FabricPool aggregates are used if this parameter is set to true and only non FabricPool aggregates are used if this parameter is set to false. Tiering support for a FlexGroup can be changed by moving all of the constituents to the required aggregates. Note that in order to tier data, not only does the volume need to support tiering by using FabricPools, the tiering "policy" must not be 'none'. A volume that uses FabricPools but has a tiering "policy" of 'none' supports tiering, but will not tier any data. |
volume
activity_tracking |
aggregates |
array[aggregates] |
analytics |
anti_ransomware |
string |
application |
autosize |
clone |
string |
comment |
string |
consistency_group |
constituents |
integer |
convert_unicode |
boolean |
create_time |
string |
efficiency |
encryption |
error_state |
files |
flash_pool |
string |
flexgroup |
guarantee |
is_object_store |
boolean |
is_svm_root |
boolean |
language |
string |
max_dir_size |
integer |
movement |
name |
string |
nas |
qos |
QoS information |
quota |
string |
size |
integer |
snaplock |
snapmirror |
snapshot_count |
integer |
snapshot_policy |
space |
state |
string |
status |
array[string] |
style |
string |
svm |
tiering |
type |
string |
Type of the volume.
ls ‐ load-sharing |
boolean |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
