REST API reference
Create a volume on an SVM and storage aggregates
Creates a volume on a specified SVM and storage aggregates. Use this endpoint when you need to allocate new storage resources within your existing infrastructure.
HTTP method and endpoint
POST /storage/volumes
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the volume.
  • name - Name of the volume.
  • aggregates.name or aggregates.uuid - Existing aggregates in which to create the volume.
Default property values
  • state - online
  • size - 20MB
  • style - flexvol
  • type - rw
  • encryption.enabled - false
  • snapshot_policy.name - default
  • guarantee.type - volume
  • volume create
  • volume clone create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
aggregates
array[aggregates]
Aggregate hosting the volume. Required on POST.
analytics
analytics
application
application
autosize
autosize
clone
clone
cloud_retrieval_policy
string
This parameter specifies the cloud retrieval policy for the volume. This policy determines which tiered out blocks to retrieve from the capacity tier to the performance tier. The available cloud retrieval policies are "default" policy retrieves tiered data based on the underlying tiering policy. If the tiering policy is 'auto', tiered data is retrieved only for random client driven data reads. If the tiering policy is 'none' or 'snapshot_only', tiered data is retrieved for random and sequential client driven data reads. If the tiering policy is 'all', tiered data is not retrieved. "on_read" policy retrieves tiered data for all client driven data reads. "never" policy never retrieves tiered data. "promote" policy retrieves all eligible tiered data automatically during the next scheduled scan. It is only supported when the tiering policy is 'none' or 'snapshot_only'. If the tiering policy is 'snapshot_only', the only data brought back is the data in the AFS. Data that is only in a snapshot copy stays in the cloud and if tiering policy is 'none' then all data is retrieved.
comment
string
A comment for the volume. Valid in POST or PATCH.
consistency_group
consistency_group
Consistency group the volume is part of.
constituents
array[constituents]
constituents_per_aggregate
integer
Specifies the number of times to iterate over the aggregates listed with the "aggregates.name" or "aggregates.uuid" when creating or expanding a FlexGroup. If a volume is being created on a single aggregate, the system will create a flexible volume if the "constituents_per_aggregate" field is not specified, and a FlexGroup if it is specified. If a volume is being created on multiple aggregates, the system will always create a FlexGroup.
create_time
string
Creation time of the volume. This field is generated when the volume is created.
efficiency
efficiency
encryption
encryption
error_state
error_state
files
files
flexcache_endpoint_type
string
FlexCache endpoint type. none ‐ The volume is neither a FlexCache nor origin of any FlexCache. cache ‐ The volume is a FlexCache volume. origin ‐ The volume is origin of a FlexCache volume.
guarantee
guarantee
is_object_store
boolean
Specifies whether the volume is provisioned for an object store server.
is_svm_root
boolean
Specifies whether the volume is a root volume of the SVM it belongs to.
language
string
Language encoding setting for volume. If no language is specified, the volume inherits its SVM language encoding setting.
movement
movement
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation. Volume movement on FlexGroup constituents are not supported.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroups, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
nas
nas
qos
qos
QoS information
quota
quota
Quotas track the space or file usage of a user, group, or qtree in a FlexVol or a FlexGroup volume.
size
integer
Physical size of the volume, in bytes. The minimum size for a FlexVol volume is 20MB and the minimum size for a FlexGroup volume is 200MB per constituent. The recommended size for a FlexGroup volume is a minimum of 100GB per constituent. For all volumes, the default size is equal to the minimum size.
snaplock
snaplock
snapmirror
snapmirror
Specifies attributes for SnapMirror protection.
snapshot_policy
snapshot_policy
This is a reference to the Snapshot copy policy.
space
space
state
string
Volume state. A volume can only be brought online if it is offline. Taking a volume offline removes its junction path. The 'mixed' state applies to FlexGroup volumes only and cannot be specified as a target state. An 'error' state implies that the volume is not in a state to serve data.
status
array[string]
Describes the current status of a volume.
style
string
The style of the volume. If "style" is not specified, the volume type is determined based on the specified aggregates. Specifying a single aggregate, without "constituents_per_aggregate", creates a flexible volume. Specifying multiple aggregates, or a single aggregate with "constituents_per_aggregate", creates a FlexGroup. Specifying a volume "style" creates a volume of that type. For example, if the style is "flexvol" you must specify a single aggregate. If the style is "flexgroup", the system either uses the specified aggregates or automatically provisions aggregates if there are no specified aggregates. flexvol ‐ flexible volumes and FlexClone volumes flexgroup ‐ FlexGroups.
svm
svm
SVM containing the volume. Required on POST.
tiering
tiering
type
string
Type of the volume. rw ‐ read-write volume. dp ‐ data-protection volume. ls ‐ load-sharing dp volume. Valid in GET.
use_mirrored_aggregates
boolean
Specifies whether mirrored aggregates are selected when provisioning a FlexGroup without specifying "aggregates.name" or "aggregates.uuid". Only mirrored aggregates are used if this parameter is set to 'true' and only unmirrored aggregates are used if this parameter is set to 'false'. Aggregate level mirroring for a FlexGroup can be changed by moving all of the constituents to the required aggregates. The default value is 'true' for a MetroCluster configuration and is 'false' for a non-MetroCluster configuration.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.6
Example request
  "access_time_enabled": null,
  "aggregates": [
      "name": "aggr1",
  "analytics": {
    "scan_progress": "17",
    "state": "string",
    "unsupported_reason": {
      "code": "111411207",
      "message": "File system analytics cannot be enabled on volumes that contain LUNs."
  "application": {
    "name": "string",
    "uuid": "1cd8a442-86d1-11e0-ae1d-123478563412"
  "autosize": {
    "mode": "string"
  "clone": {
    "parent_snapshot": {
      "name": "this_snapshot",
    "parent_svm": {
      "name": "svm1",
    "parent_volume": {
      "name": "volume1",
    "split_complete_percent": 0,
    "split_estimate": 0
  "cloud_retrieval_policy": "string",
  "comment": "string",
  "consistency_group": {
    "name": "consistency_group_1"
  "constituents": [
      "aggregates": {
        "name": "string",
      "movement": {
        "cutover_window": "30",
        "destination_aggregate": {
          "name": "aggr1",
        "percent_complete": 0,
        "state": "replicating",
        "tiering_policy": "string"
      "name": "string",
      "space": {
        "available": 0,
        "block_storage_inactive_user_data": 0,
        "capacity_tier_footprint": 0,
        "footprint": 0,
        "local_tier_footprint": 0,
        "logical_space": {
          "available": 0,
          "used_by_afs": 0
        "metadata": 0,
        "over_provisioned": 0,
        "performance_tier_footprint": 0,
        "snapshot": {
          "used": 0
        "total_footprint": 0,
        "used": 0
  "create_time": "2018-06-04T19:00:00Z",
  "efficiency": {
    "application_io_size": "string",
    "compaction": "string",
    "compression": "string",
    "cross_volume_dedupe": "string",
    "dedupe": "string",
    "last_op_begin": "string",
    "last_op_end": "string",
    "last_op_err": "string",
    "last_op_state": "string",
    "op_state": "string",
    "path": "string",
    "progress": "string",
    "schedule": "string",
    "state": "string",
    "type": "string"
  "encryption": {
    "key_id": "string",
    "key_manager_attribute": "CRN=v1:bluemix:public:containers-kubernetes:us-south:a/asdfghjkl1234:asdfghjkl1234:worker:kubernetes-asdfghjkl-worker1",
    "rekey": null,
    "state": "string",
    "status": {
      "code": "string",
      "message": "string"
    "type": "string"
  "files": {
    "used": 0
  "flexcache_endpoint_type": "string",
  "guarantee": {
    "type": "string"
  "language": "string",
  "movement": {
      "name": "aggr1",
    "start_time": "2020-12-07T03:45:12-05:00",
  "name": "vol_cs_dept",
  "nas": {
    "export_policy": {
      "id": "100",
      "name": "default"
    "junction_parent": {
      "name": "vs1_root",
      "uuid": "75c9cfb0-3eb4-11eb-9fb4-005056bb088a"
    "path": "/user/my_volume",
    "security_style": "string",
    "unix_permissions": "0755"
  "qos": {
    "policy": {
      "max_throughput_iops": "10000",
      "max_throughput_mbps": "500",
      "min_throughput_iops": "2000",
      "min_throughput_mbps": "500",
      "name": "performance",
  "queue_for_encryption": null,
  "quota": {
    "state": "string"
  "snaplock": {
    "append_mode_enabled": "",
    "autocommit_period": "P30M",
    "compliance_clock_time": "2018-06-04T19:00:00Z",
    "expiry_time": "Wed Sep  5 11:02:42 GMT 2018",
    "is_audit_log": 1,
    "litigation_count": "10",
    "privileged_delete": "enabled",
    "retention": {
      "default": "P30Y",
      "maximum": "P30Y",
      "minimum": "P30Y"
    "type": "enterprise",
    "unspecified_retention_file_count": "10"
  "snapshot_policy": {
    "name": "default",
  "space": {
    "available": 0,
    "block_storage_inactive_user_data_percent": 0,
    "footprint": 0,
    "logical_space": {
      "available": 0,
      "used": 0,
      "used_by_afs": 0,
      "used_percent": 0
    "metadata": 0,
    "overwrite_reserve": 0,
    "overwrite_reserve_used": 0,
    "percent_used": 0,
    "size_available_for_snapshots": 0,
    "snapshot": {
      "reserve_size": 0,
      "space_used_percent": 0,
      "used": 0
    "used": 0
  "state": "string",
  "status": [
    "string"
  "style": "string",
  "svm": {
    "name": "svm1",
  "tiering": {
    "object_tags": [
      "string"
    "policy": "string"
  "type": "string",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
787140
One of "aggregates.uuid", "aggregates.name", or "style" must be provided.
787141
The specified "aggregates.name" and "aggregates.uuid" refer to different aggregates.
917526
The volume name specified is a duplicate.
917829
Volume autosize grow threshold must be larger than autosize shrink threshold.
917831
Volume minimum autosize must be smaller than the maximum autosize.
917835
Maximum allowed snapshot.reserve_percent value during a volume creation is 90. Use PATCH to set it to a higher value after the volume has been created.
918191
Flexvol tiering min cooling days requires an effective cluster version of ONTAP 9.4 or later.
918194
Tiering min cooling days not supported for SVMDR.
918195
Tiering min cooling days not supported for non data volumes.
918196
Tiering min cooling days not allowed for the provided tiering policy.
918215
FlexGroup tiering min cooling days requires an effective cluster version of ONTAP 9.5 or later.
918233
The target field cannot be specified for this operation.
918236
The specified "parent_volume.uuid" and "parent_volume.name" do not refer to the same volume.
918240
The target style is an invalid volume style.
918241
The target style is an unsupported volume style for volume creation.
918242
When creating a flexible volume, exactly one aggregate must be specified via either "aggregates.name" or "aggregates.uuid".
918243
The specified Snapshot copy UUID is not correct for the specified Snapshot copy name.
918244
Invalid "volume.type" for clone volume.
918246
"volume.clone.parent_volume.name" or "volume.clone.parent_volume.uuid" must be provided.
918247
Specifying a value is not valid for a volume FlexClone creation.
918252
"nas.path" is invalid.
918290
cloud retrieval policy requires an effective cluster version of 9.8 or later.
918291
Invalid volume cloud retrieval policy for the provided tiering policy.
918292
cloud retrieval policy not supported for non data volume.
918521
The volume maximum autosize must be smaller than or equal to the maximum volume size.
918524
Volume minimum autosize must be less than or equal to the current volume size.
2621706
The specified "svm.uuid" and "svm.name" do not refer to the same SVM.
2621707
No SVM was specified. Either "svm.name" or "svm.uuid" must be supplied.
111411205
File system analytics requires an effective cluster version of 9.8 or later.
111411206
The specified "analytics.state" is invalid.
111411207
string
aggregates
Aggregate
name
string
uuid
string
unsupported_reason
code
string
If file system analytics is not supported on the volume, this field provides the error code explaining why.
message
string
If file system analytics is not supported on the volume, this field provides the error message explaining why.
analytics
scan_progress
integer
Percentage of files in the volume that the file system analytics initialization scan has processed. Only returned when the state is initializing.
state
string
File system analytics state of the volume. If this value is "on", ONTAP collects extra file system analytics information for all directories on the volume. There will be a slight impact to I/O performance to collect this information. If this value is "off", file system analytics information is not collected and not available to be viewed. If this value is "initializing", that means file system analytics was recently turned on, and the initialization scan to gather information all all existing files and directories is currently running. If this value is 'unknown' that means there was an internal error when determining the file system analytics state for the volume.
  • enum: ["unknown", "initializing", "off", "on"]
  • Introduced in: 9.8
supported
boolean
This field indicates whether or not file system analytics is supported on the volume. If file system analytics is not supported, the reason will be specified in the "analytics.unsupported_reason" field.
unsupported_reason
unsupported_reason
application
name
string
Name of the application to which the volume belongs. Available only when the volume is part of an application.
uuid
string
UUID of the application to which the volume belongs. Available only when the volume is part of an application.
autosize
grow_threshold
integer
Used space threshold size, in percentage, for the automatic growth of the volume. When the amount of used space in the volume becomes greater than this threhold, the volume automatically grows unless it has reached the maximum size. The volume grows when 'space.used' is greater than this percent of 'space.size'. The 'grow_threshold' size cannot be less than or equal to the 'shrink_threshold' size..
maximum
integer
Maximum size in bytes up to which a volume grows automatically. This size cannot be less than the current volume size, or less than or equal to the minimum size of volume.
minimum
integer
Minimum size in bytes up to which the volume shrinks automatically. This size cannot be greater than or equal to the maximum size of volume.
mode
string
Autosize mode for the volume. grow ‐ Volume automatically grows when the amount of used space is above the 'grow_threshold' value. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled.
shrink_threshold
integer
Used space threshold size, in percentage, for the automatic shrinkage of the volume. When the amount of used space in the volume drops below this threshold, the volume automatically shrinks unless it has reached the minimum size. The volume shrinks when the 'space.used' is less than the 'shrink_threshold' percent of 'space.size'. The 'shrink_threshold' size cannot be greater than or equal to the 'grow_threshold' size.
snapshot_reference
name
string
uuid
string
parent_svm
name
string
The name of the SVM.
uuid
string
parent_volume
name
string
The name of the volume.
uuid
string
clone
is_flexclone
boolean
Specifies if this volume is a normal FlexVol or FlexClone. This field needs to be set when creating a FlexClone. Valid in POST.
parent_snapshot
snapshot_reference
parent_svm
parent_svm
parent_volume
parent_volume
integer
Percentage of FlexClone blocks split from its parent volume.
split_estimate
integer
Space required by the containing-aggregate to split the FlexClone volume.
split_initiated
boolean
This field is set when split is executed on any FlexClone, that is when the FlexClone volume is split from its parent FlexVol. This field needs to be set for splitting a FlexClone form FlexVol. Valid in PATCH.
consistency_group
name
string
Name of the consistency group.
aggregates
name
string
Name of the aggregate hosting the FlexGroup Constituent.
uuid
string
Unique identifier for the aggregate.
Aggregate
name
string
uuid
string
movement
cutover_window
integer
Time window in seconds for cutover. The allowed range is between 30 to 300 seconds.
Aggregate
percent_complete
integer
Completion percentage
state
string
State of volume move operation. PATCH the state to "aborted" to abort the move operation. PATCH the state to "cutover" to trigger cutover. PATCH the state to "paused" to pause the volume move operation in progress. PATCH the state to "replicating" to resume the paused volume move operation. PATCH the state to "cutover_wait" to go into cutover manually. When volume move operation is waiting to go into "cutover" state, this is indicated by the "cutover_pending" state. A change of state is only supported if volume movement is in progress.
tiering_policy
string
Tiering policy for FabricPool
logical_space
available
integer
The amount of space available in this volume with storage efficiency space considered used, in bytes.
enforcement
boolean
Specifies whether space accounting for operations on the volume is done along with storage efficiency.
reporting
boolean
Specifies whether space reporting on the volume is done along with storage efficiency.
used_by_afs
integer
The virtual space used by AFS alone (includes volume reserves) and along with storage efficiency, in bytes.
snapshot
autodelete_enabled
boolean
Specifies whether Snapshot copy autodelete is currently enabled on this volume.
reserve_percent
integer
The space that has been set aside as a reserve for Snapshot copy usage, in percent.
used
integer
The total space used by Snapshot copies in the volume, in bytes.
space
afs_total
integer
Total size of AFS, excluding snap-reserve, in bytes.
available
integer
The available space, in bytes.
available_percent
integer
The space available, as a percent.
integer
The size that is physically used in the block storage of the volume and has a cold temperature. In bytes. This parameter is only supported if the volume is in an aggregate that is either attached to a cloud store or could be attached to a cloud store.
integer
Space used by capacity tier for this volume in the FabricPool aggregate, in bytes.
footprint
integer
Data used for this volume in the aggregate, in bytes.
integer
Space used by the local tier for this volume in the aggregate, in bytes.
logical_space
logical_space
metadata
integer
Space used by the volume metadata in the aggregate, in bytes.
over_provisioned
integer
The amount of space not available for this volume in the aggregate, in bytes.
integer
Space used by the performance tier for this volume in the FabricPool aggregate, in bytes.
size
integer
Total provisioned size. The default size is equal to the minimum size of 20MB, in bytes.
snapshot
snapshot
total_footprint
integer
Data and metadata used for this volume in the aggregate, in bytes.
used
integer
The virtual space used (includes volume reserves) before storage efficiency, in bytes.
used_by_afs
integer
The space used by Active Filesystem, in bytes.
constituents
aggregates
aggregates
movement
movement
name
string
FlexGroup Constituents name
space
space
policy
name
string
Specifies the name of the efficiency policy. Valid for PATCH.
efficiency
application_io_size
string
Block size to use by compression. Valid for POST.
compaction
string
The system can be enabled/disabled compaction. inline ‐ Data will be compacted first and written to the volume. none ‐ None mixed ‐ Read only field for FlexGroups, where some of the constituent volumes are compaction enabled and some are disabled.
compression
string
The system can be enabled/disabled compression. inline ‐ Data will be compressed first and written to the volume. background ‐ Data will be written to the volume and compressed later. both ‐ Inline compression compresses the data and write to the volume, background compression compresses only the blocks on which inline compression is not run. none ‐ None mixed ‐ Read only field for FlexGroups, where some of the constituent volumes are compression enabled and some are disabled.
cross_volume_dedupe
string
The system can be enabled/disabled cross volume dedupe. it can be enabled only when dedupe is enabled. inline ‐ Data will be cross volume deduped first and written to the volume. background ‐ Data will be written to the volume and cross volume deduped later. both ‐ Inline cross volume dedupe dedupes the data and write to the volume, background cross volume dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroups, where some of the constituent volumes are cross volume dedupe enabled and some are disabled.
dedupe
string
The system can be enabled/disabled dedupe. inline ‐ Data will be deduped first and written to the volume. background ‐ Data will be written to the volume and deduped later. both ‐ Inline dedupe dedupes the data and write to the volume, background dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroups, where some of the constituent volumes are dedupe enabled and some are disabled.
last_op_begin
string
Last sis operation begin timestamp.
last_op_end
string
Last sis operation end timestamp.
last_op_err
string
Last sis operation error text.
last_op_size
integer
Last sis operation size.
last_op_state
string
Last sis operation state.
op_state
string
Sis status of the volume.
path
string
Absolute volume path of the volume.
progress
string
Sis progress of the volume.
schedule
string
Schedule associated with volume.
state
string
Sis state of the volume.
type
string
Sis Type of the volume.
status
code
string
Encryption progress message code.
message
string
Encryption progress message.
encryption
enabled
boolean
Creates an encrypted or an unencrypted volume. For POST, when set to 'true', a new key is generated and used to encrypt the given volume. In that case, the underlying SVM must be configured with the key manager. When set to 'false', the volume created will be unencrypted. For PATCH, when set to 'true', it encrypts an unencrypted volume. Specifying the parameter as 'false' in a PATCH operation for an encrypted volume is only supported when moving the volume to another aggregate.
key_id
string
The key ID used for creating encrypted volume. A new key-id is generated for creating an encrypted volume. This key-id is associated with the generated key.
string
Specifies an additional key manager attribute that is an identifier-value pair, separated by '='. For example, CRN=unique-value. This parameter is required when using the POST method and an IBM Key Lore key manager is configured on the SVM.
state
string
Volume encryption state. encrypted ‐ The volume is completely encrypted. encrypting ‐ Encryption operation is in progress. partial ‐ Some constituents are encrypted and some are not. Applicable only for FlexGroup volume. rekeying. Encryption of volume with a new key is in progress. unencrypted ‐ The volume is a plain-text one.
status
status
type
string
Volume encryption type. none ‐ The volume is a plain-text one. volume ‐ The volume is encrypted with NVE (NetApp Volume Encryption). aggregate ‐ The volume is encrypted with NAE (NetApp Aggregate Encryption).
error_state
has_bad_blocks
boolean
Indicates whether the volume has any corrupt data blocks. If the damaged data block is accessed, an IO error, such as EIO for NFS or STATUS_FILE_CORRUPT for CIFS, is returned.
is_inconsistent
boolean
Indicates whether the file system has any inconsistencies. true ‐ File system is inconsistent. false ‐ File system in not inconsistent.
files
maximum
integer
The maximum number of files (inodes) for user-visible data allowed on the volume. This value can be increased or decreased. Increasing the maximum number of files does not immediately cause additional disk space to be used to track files. Instead, as more files are created on the volume, the system dynamically increases the number of disk blocks that are used to track files. The space assigned to track files is never freed, and this value cannot be decreased below the current number of files that can be tracked within the assigned space for the volume. Valid in PATCH.
used
integer
Number of files (inodes) used for user-visible data permitted on the volume. This field is valid only when the volume is online.
guarantee
honored
boolean
Is the space guarantee of this volume honored in the aggregate?
type
string
The type of space guarantee of this volume in the aggregate.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
cloud
Performance numbers (IOPS and latency) for cloud store. These numbers are relevant only for volumes hosted on FabricPools.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
timestamp
string
The timestamp of the performance data.
flexcache
Performance number for FlexCache used to measure cache effectiveness.
bandwidth_savings
integer
Bandwidth savings denoting the amount of data served locally by the cache, in bytes.
cache_miss_percent
integer
Cache miss percentage.
duration
string
status
string
timestamp
string
throughput
other
integer
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS, latency and throughput.
cloud
cloud
duration
string
flexcache
flexcache
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
movement
cutover_window
integer
Aggregate
percent_complete
integer
start_time
string
Start time of volume move.
state
string
tiering_policy
string
export_policy
Export Policy
id
integer
name
string
junction_parent
name
string
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume.
uuid
string
Unique identifier for the parent volume.
nas
export_policy
export_policy
Export Policy
gid
integer
The UNIX group ID of the volume. Valid in POST or PATCH.
junction_parent
junction_parent
path
string
The fully-qualified path in the owning SVM's namespace at which the volume is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one volume can be mounted at any given junction path. An empty path in POST creates an unmounted volume. An empty path in PATCH deactivates and unmounts the volume. Taking a volume offline removes its junction path. This attribute is reported in GET only when the volume is mounted.
security_style
string
Security style associated with the volume. Valid in POST or PATCH. mixed ‐ Mixed-style security ntfs ‐ NTFS/WIndows-style security unified ‐ Unified-style security, unified UNIX, NFS and CIFS permissions unix ‐ Unix-style security.
uid
integer
The UNIX user ID of the volume. Valid in POST or PATCH.
unix_permissions
integer
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write) and 1 (execute). First digit selects the set user ID(4), set group ID (2) and sticky (1) attributes. The second digit selects permission for the owner of the file; the third selects permissions for other users in the same group; the fourth for other users not in the group. Valid in POST or PATCH. For security style "mixed" or "unix", the default setting is 0755 in octal (493 in decimal) and for security style "ntfs", the default setting is 0000. In cases where only owner, group and other permissions are given (as in 755, representing the second, third and fourth dight), first digit is assumed to be zero.
policy
When "min_throughput_iops", "min_throughput_mbps", "max_throughput_iops" or "max_throughput_mbps" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed.
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos
QoS information
policy
policy
quota
enabled
boolean
This option is used to enable or disable the quota for the volume. This option is valid only in PATCH. Quotas are enabled for FlexVols or FlexGroup volumes when the quota state is "on". Quotas are disabled for FlexVols or FlexGroup volumes when the quota state is "off".
state
string
Quota state of the volume
retention
default
string
Specifies the default retention period that is applied to files while committing them to the WORM state without an associated retention period. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period and the string "unspecified" to set an unspecified retention period.
maximum
string
Specifies the maximum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period.
minimum
string
Specifies the minimum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, month,s and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period.
snaplock
append_mode_enabled
boolean
Specifies if the volume append mode is enabled or disabled. When it is enabled, all the files created with write permissions on the volume are, by default, WORM appendable files. The user can append the data to a WORM appendable file but cannot modify the existing contents of the file nor delete the file until it expires.
autocommit_period
string
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater than the autocommit period of the volume are committed to the WORM state. The autocommit period value represents a duration and must be specified in the ISO-8601 duration format. The autocommit period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the autocommit field also accepts the string "none".
string
This is the volume compliance clock time which is used to manage the SnapLock objects in the volume.
expiry_time
string
Expiry time of the volume.
is_audit_log
boolean
Indicates if this volume has been configured as SnapLock audit log volume for the SVM .
litigation_count
integer
Litigation count indicates the number of active legal-holds on the volume.
privileged_delete
string
Specifies the privileged-delete attribute of a SnapLock volume. On a SnapLock Enterprise (SLE) volume, a designated privileged user can selectively delete files irrespective of the retention time of the file. SLE volumes can have privileged delete as disabled, enabled or permanently_disabled and for SnapLock Compliance (SLC) volumes it is always permanently_disabled.
retention
retention
type
string
The SnapLock type of the volume. compliance ‐ A SnapLock Compliance(SLC) volume provides the highest level of WORM protection and an administrator cannot destroy a SLC volume if it contains unexpired WORM files. enterprise ‐ An administrator can delete a SnapLock Enterprise(SLE) volume. non_snaplock ‐ Indicates the volume is non-snaplock.
integer
Indicates the number of files with an unspecified retention time in the volume.
destinations
is_cloud
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to a cloud destination.
is_ontap
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to an ONTAP destination.
  • readOnly: 1
  • Introduced in: 9.9
snapmirror
destinations
destinations
is_protected
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data.
snapshot_policy
name
string
uuid
string
logical_space
available
integer
enforcement
boolean
reporting
boolean
used
integer
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), in bytes.
used_by_afs
integer
used_percent
integer
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), as a percentage.
snapshot
autodelete_enabled
boolean
reserve_percent
integer
reserve_size
integer
Size in the volume that has been set aside as a reserve for Snapshot copy usage, in bytes.
space_used_percent
integer
Percentage of snapshot reserve size that has been used.
used
integer
space
afs_total
integer
available
integer
available_percent
integer
integer
integer
Percentage of size that is physically used in the performance tier of the volume.
integer
footprint
integer
fractional_reserve
integer
Used to change the amount of space reserved for overwrites of reserved objects in a volume.
full_threshold_percent
integer
Volume full threshold percentage at which EMS warnings can be sent.
integer
logical_space
logical_space
metadata
integer
nearly_full_threshold_percent
integer
Volume nearly full threshold percentage at which EMS warnings can be sent.
over_provisioned
integer
overwrite_reserve
integer
Reserved space for overwrites, in bytes.
integer
Overwrite logical reserve space used, in bytes.
percent_used
integer
Percentage of the volume size that is used.
integer
size
integer
integer
Available space for Snapshot copies from snap-reserve, in bytes.
snapshot
snapshot
total_footprint
integer
used
integer
used_by_afs
integer
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
cloud
These are raw performance numbers (IOPS and latency) for the cloud store. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. These numbers are relevant only for volumes hosted on FabricPools.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
timestamp
string
flexcache_raw
Performance numbers for FlexCache used to measure cache effectiveness.
cache_miss_blocks
integer
Blocks retrieved from origin in case of a cache miss. This can be divided by the raw client_requested_blocks and multiplied by 100 to calculate the cache miss percentage.
integer
Total blocks requested by the client.
status
string
timestamp
string
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
cloud
cloud
flexcache_raw
flexcache_raw
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
svm
name
string
uuid
string
tiering
min_cooling_days
integer
This parameter specifies the minimum number of days that user data blocks of the volume must be cooled before they can be considered cold and tiered out to the cloud tier. Note that this parameter is only used for tiering purposes and does not affect the reporting of inactive data. The value specified should be greater than the frequency with which applications in the volume shift between different sets of data. This parameter cannot be set when volume tiering policy is either "none" or "all". The default value of this parameter depends on the volume's tiering policy. See the tiering policy section of this documentation for corresponding default values. If the tiering policy on the volume gets changed, then this parameter will be reset to the default value corresponding to the new tiering policy.
object_tags
array[string]
This parameter specifies tags of a volume for objects stored on a FabricPool-enabled aggregate. Each tag is a key,value pair and should be in the format "key=value".
policy
string
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH. all ‐ This policy allows tiering of both Snapshot copies and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks. auto ‐ This policy allows tiering of both snapshot and active file system user data to the cloud store none ‐ Volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the volume Snapshot copies not associated with the active file system. The default tiering policy is "snapshot-only" for a FlexVol and "none" for a FlexGroup. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy is 31 days.
supported
boolean
This parameter specifies whether or not FabricPools are selected when provisioning a FlexGroup without specifying "aggregates.name" or "aggregates.uuid". Only FabricPool aggregates are used if this parameter is set to true and only non FabricPool aggregates are used if this parameter is set to false. Tiering support for a FlexGroup can be changed by moving all of the constituents to the required aggregates. Note that in order to tier data, not only does the volume need to support tiering by using FabricPools, the tiering "policy" must not be 'none'. A volume that uses FabricPools but has a tiering "policy" of 'none' supports tiering, but will not tier any data.
volume
aggregates
array[aggregates]
analytics
analytics
application
application
autosize
autosize
clone
clone
string
comment
string
consistency_group
consistency_group
constituents
array[constituents]
integer
create_time
string
efficiency
efficiency
encryption
encryption
error_state
error_state
files
files
string
guarantee
guarantee
is_object_store
boolean
is_svm_root
boolean
language
string
movement
movement
name
string
nas
nas
qos
qos
QoS information
quota
quota
size
integer
snaplock
snaplock
snapmirror
snapmirror
snapshot_policy
snapshot_policy
space
space
state
string
status
array[string]
style
string
svm
svm
tiering
tiering
type
string
boolean
uuid
string
  • readOnly: 1
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
