REST API reference
Create a volume on an SVM and storage aggregates
POST /storage/volumes
Introduced In: 9.6
Creates a volume on a specified SVM and storage aggregates.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the volume.
  • name - Name of the volume.
  • aggregates.name or aggregates.uuid - Existing aggregates in which to create the volume.
Default property values
  • state - online
  • size - 20MB
  • style - flexvol
  • type - rw
  • encryption.enabled - false
  • snapshot_policy.name - default
  • guarantee.type - volume
  • anti_ransomware.state - default
  • volume create
  • volume clone create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
activity_tracking
activity_tracking
aggregates
array[aggregates]
Aggregate(s) hosting the volume. Optional.
aggressive_readahead_mode
string
Specifies the aggressive_readahead_mode enabled on the volume. When set to file_prefetch, on a file read, the system aggressively issues readaheads for all of the blocks in the file and retains those blocks in a cache for a finite period of time. When the option is set to sequential_read, the system aggressively prefetches the file completely, or to a certain length based on the file size limit, and continues as the read makes progress. If the option is set to cross_file_sequential_read, then the system aggressively prefetches multiple files completely, or to a certain length, and continues as the read makes progress.
analytics
analytics
anti_ransomware
anti_ransomware
Anti-ransomware related information of the volume.
application
application
asynchronous_directory_delete
Configuration for asynchronous directory delete from the client. This is only supported on Flexible volumes and FlexGroup volumes.
autosize
autosize
clone
clone
cloud_retrieval_policy
string
This parameter specifies the cloud retrieval policy for the volume. This policy determines which tiered out blocks to retrieve from the capacity tier to the performance tier. The available cloud retrieval policies are "default" policy retrieves tiered data based on the underlying tiering policy. If the tiering policy is 'auto', tiered data is retrieved only for random client driven data reads. If the tiering policy is 'none' or 'snapshot_only', tiered data is retrieved for random and sequential client driven data reads. If the tiering policy is 'all', tiered data is not retrieved. "on_read" policy retrieves tiered data for all client driven data reads. "never" policy never retrieves tiered data. "promote" policy retrieves all eligible tiered data automatically during the next scheduled scan. It is only supported when the tiering policy is 'none' or 'snapshot_only'. If the tiering policy is 'snapshot_only', the only data brought back is the data in the AFS. Data that is only in a snapshot copy stays in the cloud and if tiering policy is 'none' then all data is retrieved.
cloud_write_enabled
boolean
Indicates whether or not cloud writes are enabled on the volume. NFS writes to this volume are sent to the cloud directly instead of the local performance tier. This feature is only available on volumes in FabricPools.
comment
string
A comment for the volume. Valid in POST or PATCH.
consistency_group
consistency_group
Consistency group the volume is part of.
constituents
array[constituents]
FlexGroup volume constituents. FlexGroup volume constituents can be retrieved more efficiently by specifying "is_constituent=true" or "is_constituent=true&flexgroup.uuid=" as query parameters.
constituents_per_aggregate
integer
Specifies the number of times to iterate over the aggregates listed with the "aggregates.name" or "aggregates.uuid" when creating or expanding a FlexGroup volume. If a volume is being created on a single aggregate, the system creates a flexible volume if the "constituents_per_aggregate" field is not specified, or a FlexGroup volume if it is specified. If a volume is being created on multiple aggregates, the system always creates a FlexGroup volume. If a volume is being created on multiple aggregates and the "constituents_per_aggregate" field is not specified, the default value of the "constituents_per_aggregate" field is 4. The root constituent of a FlexGroup volume is always placed on the first aggregate in the list, unless 'optimize_aggregates' is specified as 'true'. If the "aggregates.name" or "aggregates.uuid" is specified in a PATCH request to expand an existing FlexGroup volume, the default value of the "constituents_per_aggregate" field is 1. The volume expand operation is only supported on FlexGroup volumes.
convert_unicode
boolean
Specifies whether directory Unicode format conversion is enabled when directories are accessed by NFS clients.
create_time
string
Creation time of the volume. This field is generated when the volume is created.
efficiency
efficiency
encryption
encryption
error_state
error_state
files
files
flash_pool
flash_pool
flexcache_endpoint_type
string
FlexCache endpoint type. none ‐ The volume is neither a FlexCache nor origin of any FlexCache. cache ‐ The volume is a FlexCache volume. origin ‐ The volume is origin of a FlexCache volume.
flexgroup
flexgroup
granular_data
boolean
State of granular data on the volume. This setting is true by default when creating an AWS S3 FlexGroup volume via a POST request and false by default for creating any other type of FlexGroup volume via a POST request. On FlexVol volumes, the setting is always false, as only FlexGroup volumes support this feature. Once enabled, this setting can only be disabled by restoring a snapshot. Earlier versions of ONTAP (pre 9.12) are not compatible with this feature. Therefore, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the setting was enabled.
  • Introduced in: 9.12
  • x-nullable: true
granular_data_mode
string
Mode of granular data on the volume. This setting defaults to basic when the granular_data parameter is set to true, but can be specified at the time of creation via a POST request. Earlier versions of ONTAP (pre 9.12) are not compatible with the basic setting. Therefore, when set to basic, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the basic mode was enabled. Earlier versions of ONTAP (pre 9.16) are not compatible with the advanced setting. Therefore, when set to advanced, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the advanced mode was enabled.
  • enum: ["disabled", "basic", "advanced"]
  • Introduced in: 9.16
  • x-nullable: true
guarantee
guarantee
has_dir_index_public
boolean
Specifies whether the volume has directories with public index files.
has_large_dir
boolean
Specifies whether the volume has directories bigger than 4GB.
is_dir_index_transfer_enabled
boolean
When set to true, this field enables support for directory index transfer.
is_large_dir_enabled
boolean
When set to true, this field enables the large directory feature on a volume.
is_object_store
boolean
Specifies whether the volume is provisioned for an object store server.
is_s3_arbitrary_part_size_enabled
boolean
Specifies that the volume should allow Amazon S3 multipart uploads with arbitrary part lengths. This is only supported for FlexGroup volumes with advanced granular_data. The default value is false. When set to true, it cannot be reverted to false. Clusters with any volumes where this is true cannot be reverted to a release that does not support this feature.
is_svm_root
boolean
Specifies whether the volume is a root volume of the SVM it belongs to.
language
string
Language encoding setting for volume. If no language is specified, the volume inherits its SVM language encoding setting.
max_dir_size
integer
Maximum directory size. This value sets maximum size, in bytes, to which a directory can grow. The default maximum directory size for FlexVol volumes is model-dependent, and optimized for the size of system memory. Before increasing the maximum directory size, involve technical support.
movement
movement
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation.
msid
integer
The volume's Master Set ID.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroup volumes, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
nas
nas
nodes
array[nodes]
List of the nodes hosting the volume.
optimize_aggregates
boolean
Specifies whether to create the constituents of the FlexGroup volume on the aggregates specified in the order they are specified, or whether the system should optimize the ordering of the aggregates. If this value is 'true', the system optimizes the ordering of the aggregates specified. If this value is false, the order of the aggregates is unchanged. The default value is 'false'.
qos
qos
QoS information
quota
quota
Quotas track the space or file usage of a user, group, or qtree in a FlexVol volume or a FlexGroup volume.
rebalancing
rebalancing
Configuration and runtime properties involving non-disruptive volume capacity rebalancing for a FlexGroup volume.
scheduled_snapshot_naming_scheme
string
Naming Scheme for automatic snapshots:
  • create_time - Automatic snapshots are saved as per the start of their current date and time.
  • ordinal - Latest automatic snapshot copy is saved as .0 and subsequent copies will follow the create_time naming convention.
size
integer
Physical size of the volume, in bytes. The minimum size for a FlexVol volume is 20MB and the minimum size for a FlexGroup volume is 200MB per constituent. The recommended size for a FlexGroup volume is a minimum of 100GB per constituent. For all volumes, the default size is equal to the minimum size.
sizing_method
string
When expanding a FlexGroup volume, this specifies whether to add new constituents, or to resize the current constituents.
snaplock
snaplock
snapmirror
snapmirror
Specifies attributes for SnapMirror protection.
snapshot_count
integer
Number of snapshots in the volume.
snapshot_directory_access_enabled
boolean
This field, if true, enables the visible ".snapshot" directory from the client. The ".snapshot" directory will be available in every directory on the volume.
snapshot_locking_enabled
boolean
Specifies whether or not snapshot copy locking is enabled on the volume.
snapshot_policy
snapshot_policy
This is a reference to the snapshot policy.
space
space
state
string
Volume state. Client access is supported only when volume is online and junctioned. Taking volume to offline or restricted state removes its junction path and blocks client access. When volume is in restricted state some operations like parity reconstruction and iron on commit are allowed. The 'mixed' state applies to FlexGroup volumes only and cannot be specified as a target state. An 'error' state implies that the volume is not in a state to serve data.
status
array[string]
Describes the current status of a volume.
style
string
The style of the volume. If "style" is not specified, the volume type is determined based on the specified aggregates or license. Specifying a single aggregate, without "constituents_per_aggregate", creates a flexible volume. Specifying multiple aggregates, or a single aggregate with "constituents_per_aggregate", creates a FlexGroup volume. When the UDO License is installed, and no aggregates are specified, the system automatically provisions a FlexGroup volume on system selected aggregates. Specifying a volume "style" creates a volume of that type. For example, if the style is "flexvol", you must specify a single aggregate. If the style is "flexgroup", the system either uses the specified aggregates or automatically provisions aggregates if there are no specified aggregates. The style "flexgroup_constituent" is not supported when creating a volume. flexvol ‐ flexible volumes and FlexClone volumes flexgroup ‐ FlexGroup volumes flexgroup_constituent ‐ FlexGroup volume constituents.
svm
svm
SVM containing the volume. Required on POST.
tiering
tiering
type
string
Type of the volume. rw ‐ read-write volume. dp ‐ data-protection volume. ls ‐ load-sharing dp volume. Valid in GET.
use_mirrored_aggregates
boolean
Specifies whether mirrored aggregates are selected when provisioning a FlexGroup without specifying "aggregates.name" or "aggregates.uuid". Only mirrored aggregates are used if this parameter is set to 'true' and only unmirrored aggregates are used if this parameter is set to 'false'. Aggregate level mirroring for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. The default value is 'true' for a MetroCluster configuration and is 'false' for a non-MetroCluster configuration.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
validate_only
boolean
Validate the volume move or volume conversion operations and their parameters, without actually performing the operation.
Example request
  "_tags": [
    "team:csi",
    "environment:test"
  "access_time_enabled": true,
  "activity_tracking": {
    "notices": [
        "code": "124518424",
        "message": "The top metrics report contains partial data for read operations because NFSv4 reads using Multi-Processor I/O (MPIO) are not tracked."
    "state": "string",
    "unsupported_reason": {
      "code": "124518405",
      "message": "Volume activity tracking cannot be enabled on volumes that contain LUNs."
  "aggregates": [
      "name": "aggr1",
  "aggressive_readahead_mode": "string",
  "analytics": {
    "by_accessed_time": {
      "bytes_used": {
        "aged_data_metric": 15.23,
        "labels": [
          "2019-07",
          "2019-06",
          "2019-05",
          "2019",
          "2018",
          "--2017",
          "unknown"
        "newest_label": "2019-07",
        "oldest_label": "2019-07",
        "percentages": [
          0.1,
          11.24,
          0.18,
          15.75,
          0.75,
          83.5,
          0
        "values": [
          15925248,
          1735569408,
          27672576,
          2430595072,
          116105216,
          12889948160,
          0
    "by_modified_time": {
      "bytes_used": {
        "labels": [
          "2019-07",
          "2019-06",
          "2019-05",
          "2019",
          "2018",
          "--2017",
          "unknown"
        "percentages": [
          0.1,
          11.24,
          0.18,
          15.75,
          0.75,
          83.5,
          0
        "values": [
          15925248,
          1735569408,
          27672576,
          2430595072,
          116105216,
          12889948160,
          0
    "bytes_used": 15436648448,
    "file_count": 21134,
    "files_scanned": 43002,
    "initialization": {
      "state": "string"
    "report_time": "2024-11-06 13:57:15 -0500",
    "scan_progress": 17,
    "scan_throttle_reason": {
      "arguments": [
        "string"
      "code": "6739881",
      "message": "The file system analytics scan running on volume \"fsavol2\" in SVM \"vs2\" has slowed down on node \"my_node\". Reason: Computing resources are being used by higher priority workloads."
    "state": "string",
    "subdir_count": 35,
    "total_files": 101890,
      "code": "111411207",
      "message": "File system analytics cannot be enabled on volumes that contain LUNs."
  "anti_ransomware": {
    "attack_detected_by": "string",
    "attack_detection_parameters": {
      "file_create_op_rate_surge_notify_percent": 100
    "attack_probability": "string",
    "attack_reports": [
        "time": "2021-06-01 20:36:41 +0530"
    "block_device_detection_start_time": "string",
    "block_device_detection_state": "string",
    "clear_suspect": {
      "phase": "string",
      "start_time": "string"
    "dry_run_start_time": "string",
    "space": {
      "snapshot_count": 0,
      "used": 0,
      "used_by_logs": 0,
      "used_by_snapshots": 0
    "state": "string",
    "surge_usage": {
      "file_create_peak_rate_per_minute": 10,
      "file_delete_peak_rate_per_minute": 50,
      "file_rename_peak_rate_per_minute": 30,
      "high_entropy_data_write_peak_percent": 30,
      "high_entropy_data_write_peak_rate_kb_per_minute": 2500,
      "time": "2021-12-01 23:16:20 +0530"
    "suspect_files": [
        "count": 0,
        "entropy": "string",
        "format": "string"
    "typical_usage": {
      "file_create_peak_rate_per_minute": 50,
      "file_delete_peak_rate_per_minute": 10,
      "file_rename_peak_rate_per_minute": 5,
      "high_entropy_data_write_peak_percent": 10,
      "high_entropy_data_write_peak_rate_kb_per_minute": 1200
    "workload": {
      "file_extension_types_count": 3,
      "file_extensions_observed": [
        "pdf",
        "jpeg",
        "txt"
      "historical_statistics": {
      "newly_observed_file_extensions": [
          "count": [
            20
          "name": [
            "lockile"
      "surge_statistics": {
      "surge_usage": {
            "count": [
              20
            "name": [
              "lockile"
      "typical_usage": {
  "application": {
    "name": "string",
    "uuid": "1cd8a442-86d1-11e0-ae1d-123478563412"
  "asynchronous_directory_delete": {
    "trash_bin": "string"
  "autosize": {
    "mode": "string"
  "clone": {
    "inherited_physical_used": 0,
    "inherited_savings": 0,
    "lun_name": "string",
    "parent_snapshot": {
      "name": "this_snapshot",
    "parent_svm": {
      "name": "svm1",
    "parent_volume": {
      "name": "volume1",
    "qtree_name": "string",
    "split_complete_percent": 0,
    "split_estimate": 0,
    "split_initiated": true
  "cloud_retrieval_policy": "string",
  "comment": "string",
  "consistency_group": {
    "name": "consistency_group_1",
  "constituents": [
      "aggregates": {
        "name": "string",
      "movement": {
        "cutover_window": 30,
        "destination_aggregate": {
          "name": "aggr1",
        "percent_complete": 0,
        "state": "replicating",
        "tiering_policy": "string"
      "name": "string",
      "node": {
        "name": "string",
        "uuid": "string"
      "space": {
        "available": 0,
        "block_storage_inactive_user_data": 0,
        "capacity_tier_footprint": 0,
        "footprint": 0,
        "local_tier_footprint": 0,
        "logical_space": {
          "available": 0,
          "used_by_afs": 0
        "max_size": "string",
        "metadata": 0,
        "over_provisioned": 0,
        "performance_tier_footprint": 0,
        "snapshot": {
          "used": 0
        "total_footprint": 0,
        "total_metadata": 0,
        "total_metadata_footprint": 0,
        "used": 0
  "create_time": "2018-06-04 19:00:00 +0000",
  "efficiency": {
    "application_io_size": "string",
    "auto_state": "string",
    "compaction": "string",
    "compression": "string",
    "compression_type": "string",
    "cross_volume_dedupe": "string",
    "dedupe": "string",
    "idcs_scanner": {
      "mode": "string",
      "operation_state": "string",
      "status": "string",
      "threshold_inactive_time": "P14D"
    "last_op_begin": "string",
    "last_op_end": "string",
    "last_op_err": "string",
    "last_op_size": 0,
    "last_op_state": "string",
    "op_state": "string",
    "policy": {
      "name": "string"
    "progress": "string",
    "ratio": 0,
    "scanner": {
      "compression": true,
      "dedupe": true,
      "scan_old_data": true
    "schedule": "string",
    "space_savings": {
      "compression": 0,
      "compression_percent": 0,
      "dedupe": 0,
      "dedupe_percent": 0,
      "dedupe_sharing": 0,
      "total": 0,
      "total_percent": 0
    "state": "string",
    "storage_efficiency_mode": "string",
    "type": "string",
    "volume_path": "string"
  "encryption": {
    "action": "string",
    "key_create_time": "2022-01-01 19:00:00 +0000",
    "key_id": "string",
    "key_manager_attribute": "CRN=v1:bluemix:public:containers-kubernetes:us-south:a/asdfghjkl1234:asdfghjkl1234:worker:kubernetes-asdfghjkl-worker1",
    "rekey": true,
    "state": "string",
    "status": {
      "code": "string",
      "message": "string"
    "type": "string"
  "files": {
    "inodefile_capacity": 0,
    "used": 0
  "flash_pool": {
    "cache_eligibility": "string",
    "cache_retention_priority": "string",
    "caching_policy": "string"
  "flexcache_endpoint_type": "string",
  "flexgroup": {
    "name": "my_flexgroup",
    "uuid": "75c9cfb0-3eb4-11eb-9fb4-005056bb088a"
  "granular_data_mode": "string",
  "guarantee": {
    "type": "string"
  "language": "string",
  "movement": {
    "capacity_tier_optimized": true,
    "start_time": "2020-12-07 03:45:12 -0500"
  "name": "vol_cs_dept",
  "nas": {
    "export_policy": {
      "id": 100,
      "name": "default"
    "junction_parent": {
      "name": "vs1_root",
    "path": "/user/my_volume",
    "security_style": "string",
    "unix_permissions": 493
  "nodes": [
      "name": "string",
      "uuid": "string"
  "qos": {
    "policy": {
      "max_throughput": [
        "900KB/s",
        "500MB/s",
        "120GB/s",
        "5000IOPS",
        "5000IOPS,500KB/s",
        "2500IOPS,100MB/s",
        "1000IOPS,25MB/s"
      "max_throughput_iops": 10000,
      "max_throughput_mbps": 500,
      "min_throughput": [
        "900KB/s",
        "500MB/s",
        "120GB/s",
        "5000IOPS",
        "5000IOPS,500KB/s",
        "2500IOPS,100MB/s",
        "1000IOPS,25MB/s"
      "min_throughput_iops": 2000,
      "min_throughput_mbps": 500,
      "name": "performance",
  "queue_for_encryption": true,
  "quota": {
    "state": "string"
  "rebalancing": {
    "data_moved": 0,
    "engine": {
      "movement": {
        "file_moves_started": 0,
        "last_error": {
          "code": 0,
          "destination": 0,
          "file_id": 0,
          "time": "2018-06-04 19:00:00 +0000"
        "most_recent_start_time": "2018-06-04 19:00:00 +0000"
      "scanner": {
        "blocks_scanned": 0,
        "blocks_skipped": {
          "efficiency_blocks": 0,
          "efficiency_percent": 0,
          "fast_truncate": 0,
          "footprint_invalid": 0,
          "in_snapshot": 0,
          "incompatible": 0,
          "metadata": 0,
          "on_demand_destination": 0,
          "other": 0,
          "remote_cache": 0,
          "too_large": 0,
          "too_small": 0,
          "write_fenced": 0
        "files_scanned": 0,
        "files_skipped": {
          "fast_truncate": 0,
          "in_snapshot": 0,
          "incompatible": 0,
          "metadata": 0,
          "other": 0,
          "remote_cache": 0,
          "too_large": 0,
          "too_small": 0,
          "write_fenced": 0
    "exclude_snapshots": true,
    "imbalance_percent": 0,
    "imbalance_size": 0,
    "max_constituent_imbalance_percent": 0,
    "notices": [
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
        "message": "entry doesn't exist"
    "runtime": "string",
    "stop_time": "string",
    "target_used": 0,
    "used_for_imbalance": 0
  "scheduled_snapshot_naming_scheme": "string",
  "sizing_method": "string",
  "snaplock": {
    "append_mode_enabled": "",
    "autocommit_period": "P30M",
    "compliance_clock_time": "2018-06-04 19:00:00 +0000",
    "expiry_time": "Wed Sep  5 11:02:42 GMT 2018",
    "is_audit_log": 1,
    "litigation_count": 10,
    "privileged_delete": "enabled",
    "retention": {
      "default": "P30Y",
      "maximum": "P30Y",
      "minimum": "P30Y"
    "type": "enterprise",
    "unspecified_retention_file_count": 10
  "snapshot_policy": {
    "name": "default",
  "space": {
    "auto_adaptive_compression_footprint_data_reduction": 0,
    "available": 0,
    "block_storage_inactive_user_data_percent": 0,
    "capacity_tier_footprint_data_reduction": 0,
    "compaction_footprint_data_reduction": 0,
    "cross_volume_dedupe_metafiles_footprint": 0,
    "cross_volume_dedupe_metafiles_temporary_footprint": 0,
    "dedupe_metafiles_footprint": 0,
    "dedupe_metafiles_temporary_footprint": 0,
    "delayed_free_footprint": 0,
    "effective_total_footprint": 0,
    "file_operation_metadata": 0,
    "filesystem_size": 0,
    "footprint": 0,
    "logical_space": {
      "available": 0,
      "used": 0,
      "used_by_afs": 0,
      "used_by_snapshots": 0,
      "used_percent": 0
    "metadata": 0,
    "overwrite_reserve": 0,
    "overwrite_reserve_used": 0,
    "percent_used": 0,
    "size_available_for_snapshots": 0,
    "snapmirror_destination_footprint": 0,
    "snapshot": {
      "reserve_available": 0,
      "reserve_size": 0,
      "space_used_percent": 0,
      "used": 0
    "snapshot_reserve_unusable": 0,
    "snapshot_spill": 0,
    "used": 0,
    "user_data": 0,
    "volume_guarantee_footprint": 0
  "state": "string",
  "status": [
    "string"
  "style": "string",
  "svm": {
    "name": "svm1",
  "tiering": {
    "object_tags": [
      "string"
    "policy": "string"
  "type": "string",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
460770
[Job "jobid"] Job failed.
524561
Unable to get the information for the specified SVM's root volume because of the specified reason.
524597
Failed to create the clone volume on the node.
524597
Failed to create clone volume on the node.
524601
Parent volume "name" not found.
524819
Failed to create the clone volume.
787140
One of "aggregates.uuid", "aggregates.name", or "style" must be provided.
787141
The specified "aggregates.name" and "aggregates.uuid" refer to different aggregates.
917508
The target aggregate could not be found.
917526
The volume name specified is a duplicate.
917534
The value specified for field "-size" is too small. Update the field "-size" with the minimum size allowed and retry.
917536
Job completed with specified error.
917551
Specified snapshot policy not found.
917597
Provisioning a volume on a root aggregate is not supported.
917775
Volume \"{0}:{1}\" is not online.
917829
Volume autosize grow threshold must be larger than autosize shrink threshold.
917831
Volume minimum autosize must be smaller than the maximum autosize.
917835
Maximum allowed snapshot.reserve_percent value during a volume creation is 90. Use PATCH to set it to a higher value after the volume has been created.
917886
Volume name is too long. It must be 203 characters or less.
917887
The first character of the volume name must be a letter or underscore.
918157
Node \"{0}\" in cluster \"{1}\" failed to allocate encryption resources. Wait a few minutes, and try the operation again. If the issue persists, reboot the node and try the operation again.
918162
Node \"{0}\" in cluster \"{1}\" is not reachable. Creation of the first encrypted volume requires encryption resources to be allocated on both node \"{2}\" and its HA partner node \"{0}\". Make sure that the node and its partner are healthy, and then try the operation again.
918191
Flexvol tiering min cooling days requires an effective cluster version of ONTAP 9.4 or later.
918194
Tiering min cooling days not supported for SVMDR.
918195
Tiering min cooling days not supported for non data volumes.
918196
Tiering min cooling days not allowed for the provided tiering policy.
918215
FlexGroup tiering min cooling days requires an effective cluster version of ONTAP 9.5 or later.
918232
The specified volume identifier fields must be provided.
918233
The target field cannot be specified for this operation.
918236
The specified "parent_volume.uuid" and "parent_volume.name" do not refer to the same volume.
918240
The target style is an invalid volume style.
918241
The target style is an unsupported volume style for volume creation.
918242
When creating a flexible volume, exactly one aggregate must be specified via either "aggregates.name" or "aggregates.uuid".
918243
The specified snapshot UUID is not correct for the specified snapshot name.
918244
Invalid "volume.type" for clone volume.
918247
Specifying a value is not valid for a volume FlexClone creation.
918252
"nas.path" is invalid.
918271
Failed to get valid export policy.
918290
cloud retrieval policy requires an effective cluster version of 9.8 or later.
918291
Invalid volume cloud retrieval policy for the provided tiering policy.
918292
cloud retrieval policy not supported for non data volume.
918334
Cache cloud retrieval policy requires an effective cluster version of 9.14 or later.
918521
The volume maximum autosize must be smaller than or equal to the maximum volume size.
918524
Volume minimum autosize must be less than or equal to the current volume size.
918652
"error" is an invalid value for field "-state". Valid values are "online", "offline" and "restricted".
918701
The specified operation on the volume endpoint is not supported on this platform.
1638400
Failed to retrieve snapshot information.
1638587
The specified snapshot_policy.name and snapshot_policy.uuid refer to different snapshot policies.
1638593
Operation failed because "snapdb" is disabled.
1638624
Internal error. Failed to lookup snapshot tags for \"{0}\".
2621462
The target SVM does not exist.
2621706
The specified "svm.uuid" and "svm.name" do not refer to the same SVM.
2621707
No SVM was specified. Either "svm.name" or "svm.uuid" must be supplied.
6881654
Disabling storage efficiency features is not allowed on this platform.
13107245
The specified FlexGroup volume layout exceeds the maximum number of volumes on node.
13107307
specifying this parameter when creating a flexible volume is not supported.
13107326
Request to provision FlexGroup volume "name" failed because the requested size is greater than the maximum size.
13107341
At least one valid aggregate assigned to SVM \"{0}\" with sufficient space and a homogeneous storage type is required on every node on the cluster to provision a FlexGroup volume.
13107349
Operation is only supported on flexible volumes and FlexGroup volumes.
13107405
Another volume is currently being created with the name "name" in SVM "svm.name".
13107413
Creating a FlexGroup volume is not supported on All SAN Arrays and systems that support large LUNs.
13109258
Cannot enable granular data on volume "name" in Vserver "svm.name". This setting can only be enabled on FlexGroups.
13109260
Failed to enable granular data on the volume.
13109290
Specifying the "aggregates" parameter on this platform requires that the "constituents_per_aggregate" parameter is also specified. Instead, consider using the "constituent_count" parameter to specify how many constituents to create, and the system will automatically select where to place them.
13109291
Specifying the "constituents_per_aggregate" parameter requires that the "aggregates" parameter is also specified.
13565983
A value of zero is not supported for \"-uid\" or \"-gid\".
13566001
LUN name length cannot be zero.
13566003
Specifying the "qtree_name" parameter requires that the "lun_name" parameter is also specified.
65537463
Volume encryption keys (VEK) cannot be created or deleted for data Vserver \"{0}\". External key management has been configured for data Vserver \"{0}\" but ONTAP is not able to encrypt or decrypt with the key manager. Resolve the external key manager key issues at the key manager's portal before creating any new encrypted volumes.
65537529
Encrypted volumes cannot be created or deleted for Vserver \"{0}\" as a rekey operation for the vserver is in progress. Try creating the encrypted volume again after some time. If the problem persists, run the rekey operation again after some time.
65537600
Encrypted volumes cannot be created or deleted for Vserver \"{0}\" while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent encrypted volume creation for Vserver \"{0}\". Use the \"security key-manager keystore enable\" command to re-run and complete the operation.
65539430
Cannot create or delete volumes on Vserver \"{0}\" while the keystore is being initialized. Wait until the keystore is in the active state, and rerun the volume operation.
65539431
Cannot create or delete volumes on Vserver \"{0}\" while the keystore is being disabled.
111411203
Failed to retrieve the volume file system analytics report on the volume.
111411204
Internal error. Failed to retrieve the volume file system analytics report on the volume.
111411205
File system analytics requires an effective cluster version of 9.8 or later.
111411206
The specified "analytics.state" is invalid.
111411207
111411207
Volume file system analytics is not supported on volumes that contain LUNs.
111411209
Volume file system analytics is not supported on FlexCache volumes.
111411210
Volume file system analytics is not supported on audit staging volumes.
111411211
Volume file system analytics is not supported on object store server volumes.
111411212
Volume file system analytics is not supported on SnapMirror destination volumes.
111411215
Internal error. Volume file system analytics report timed out for volume volume.name in SVM svm.name.
111411216
Enabling or disabling volume file system analytics is not supported on individual FlexGroup constituents.
111411217
Volume file system analytics is not supported on SnapLock volumes.
111411230
Volume file system analytics is not supported on volumes that contain NVMe namespaces.
111411241
Volume file system analytics is not supported on All SAN Array clusters.
111411252
Failed to enable file system analytics on volume "name" in SVM "svm.name" because there is insufficient available space. Ensure there is at least "space.available_percent`" available space in the volume, then try the operation again.
111411253
Failed to enable file system analytics on volume "name" in SVM "svm.name" because there is insufficient available space. Ensure there is at least "space.available_percent" available space in all constituents of the FlexGroup, then try the operation again."
111411257
Failed to enable file system analytics on volume "name" in SVM "svm.name" because there is insufficient available space. Increase the volume size to "size", then try the operation again."
111412203
Volume file system analytics is not enabled on the volume.
111415208
Cannot create a clone of volume "name" in SVM "svm.name" because the file system analytics state is not set to "off" or "on". Use REST API GET method "/api/storage/volumes/uuid?fields=analytics.state" to check the analytics state.
124518405
Volume activity tracking is not supported on volumes that contain LUNs.
124518407
Volume activity tracking is not supported on FlexCache volumes.
124518408
Volume activity tracking is not supported on audit staging volumes.
124518409
Volume activity tracking is not supported on object store server volumes.
124518410
Volume activity tracking is not supported on SnapMirror destination volumes.
124518411
Enabling or disabling volume activity tracking is not supported on individual FlexGroup constituents.
124518412
Volume activity tracking is not supported on SnapLock volumes.
124518414
Volume activity tracking is not supported on volumes that contain NVMe namespaces.
124518422
Volume activity tracking is not supported on All SAN Array clusters.
196608308
Node \"{0}\" in cluster \"{1}\" is not reachable. Creation of the first NAE (NetApp Aggregate Encryption) aggregate requires encryption resources to be allocated on both node \"{2}\" and its HA partner node \"{0}\". Make sure that the node and its partner are healthy, and then try the operation again.
196608399
One or more nodes in cluster \"{0}\" are not reachable. Creation of the first NAE (NetApp Aggregate Encryption) aggregate requires encryption resources to be allocated on all nodes in DR group \"{1}\". Ensure that all the nodes are healthy and then try the operation again.
196608400
One or more nodes in cluster \"{0}\" are not reachable. Creation of the first encrypted volume requires encryption resources to be allocated on all nodes in DR group \"{1}\". Ensure that all the nodes are healthy and then try the operation again.
196608401
Node \"{0}\" in cluster \"{1}\" is not reachable. Creation of the first NAE (NetApp Aggregate Encryption) aggregate requires encryption resources to be allocated on node \"{0}\". Make sure that the node is healthy, and then try the operation again.
196608402
Node \"{0}\" in cluster \"{1}\" is not reachable. Creation of the first encrypted volume requires encryption resources to be allocated on node \"{0}\". Make sure that the node is healthy, and then try the operation again.
string
notices
code
string
An error code related to activity tracking.
message
string
A notice message related to activity tracking.
unsupported_reason
code
string
If volume activity tracking is not supported on the volume, this field provides an appropriate error code.
message
string
If volume activity tracking is not supported on the volume, this field provides an error message detailing why this is the case.
activity_tracking
notices
array[notices]
List of activity-tracking notices.
state
string
Activity tracking state of the volume. If this value is "on", ONTAP collects top metrics information for the volume in real time. There is a slight impact to I/O performance in order to collect this information. If this value is "off", no activity tracking information is collected or available to view.
  • enum: ["off", "on"]
  • Introduced in: 9.10
  • x-nullable: true
supported
boolean
This field indicates whether or not volume activity tracking is supported on the volume. If volume activity tracking is not supported, the reason why is provided in the "activity_tracking.unsupported_reason" field.
unsupported_reason
unsupported_reason
aggregates
Aggregate
name
string
uuid
string
bytes_used
Number of bytes used on-disk, broken down by date of last access.
aged_data_metric
number
A score summarizing how old the data is. A higher value means the data is older.
labels
array[string]
Labels for this histogram
newest_label
string
Each label indicates the period of time the corresponding data is associated with. A label can take one of the following forms:<ul> a partial date in an extended ISO8601 representation an interval between partial dates in an extended ISO8601 representation, where "--" is used to separate the beginning and end of the interval the string literal "unknown"
</ul>For partial dates and partial date intervals where components of a date are unspecified, the label allows for any valid normalized values the unspecified components might take. For example, the label "2017" allows for any time within the year 2017. Essentially, this is the fully specified interval 2017-01-01T00:00:00—​2017-12-31T23:59:59. Similarly, the interval "2018-05—​2018-07" allows for any time within the months of May, June, and July in 2018, corresponding to the fully specified interval 2018-05-01T00:00:00—​2018-07-31T23:59:59.
The following extensions to ISO8601 are used:<ul> Quarters may be specified. The form yyyy-Qq is used to represent the qth quarter of the year yyyy. Q1 consists of the months January, February, and March; Q2 consists of April, May, and June; Q3 consists of July, August, and September; Q4 consists of October, November, and December. For example, the label "2019-Q2" represents the second quarter of the year 2019, which corresponds to the interval 2019-04-01T00:00:00—​2019-06-30T23:59:59. Either the beginning or end of an interval may be omitted. When the beginning is omitted, the interval includes points in time arbitrarily far in the past. When the end is omitted, the interval includes points in time through the end of the current week.
</ul>The "unknown" label tracks data that could not be associated with any other time period. This usually occurs when the data was at some point associated with a time in the future.
oldest_label
string
percentages
array[number]
Percentages for this histogram
values
array[integer]
Values for this histogram
by_accessed_time
File system analytics information, broken down by date of last access.
bytes_used
bytes_used
bytes_used
Number of bytes used on-disk, broken down by date of last modification.
aged_data_metric
number
labels
array[string]
newest_label
string
oldest_label
string
percentages
array[number]
values
array[integer]
by_modified_time
File system analytics information, broken down by date of last modification.
bytes_used
bytes_used
initialization
state
string
State of the analytics file system scan.
arguments
array[string]
Arguments present in the warning message encountered.
code
string
Warning code indicating why scanner throttling is reported.
message
string
A message that provides details for scan throttling.
unsupported_reason
code
string
If file system analytics is not supported on the volume, this field provides the error code explaining why.
message
string
If file system analytics is not supported on the volume, this field provides the error message explaining why.
analytics
by_accessed_time
by_accessed_time
by_modified_time
by_modified_time
bytes_used
integer
Number of bytes used on-disk.
file_count
integer
Number of descendants.
files_scanned
integer
Number of files in the volume that the file system analytics initialization scan has processed. Only returned when the state is initializing.
incomplete_data
boolean
Returns true if data collection is incomplete for this directory tree.
initialization
initialization
report_time
string
Time of data collection.
scan_progress
integer
Percentage of files in the volume that the file system analytics initialization scan has processed. Only returned when the state is initializing.
state
string
File system analytics state of the volume. If this value is "on", ONTAP collects extra file system analytics information for all directories on the volume. There will be a slight impact to I/O performance to collect this information. If this value is "off", file system analytics information is not collected and not available to be viewed. If this value is "initializing", that means file system analytics was recently turned on, and the initialization scan to gather information for all existing files and directories is currently running. If this value is "initialization_paused", this means that the initialization scan is currently paused. If this value is 'unknown', this means that there was an internal error when determining the file system analytics state for the volume.
  • enum: ["unknown", "initializing", "initialization_paused", "off", "on"]
  • Introduced in: 9.8
  • x-nullable: true
subdir_count
integer
Number of sub-directories.
supported
boolean
This field indicates whether or not file system analytics is supported on the volume. If file system analytics is not supported, the reason will be specified in the "analytics.unsupported_reason" field.
total_files
integer
Total number of files in the volume that the file system analytics initialization scan will process. Only returned when the state is initializing.
unsupported_reason
unsupported_reason
anti_ransomware_volume_attack_detection_parameters
based_on_file_create_op_rate
boolean
Specifies whether attack detection is based on the file create operations rate. This parameter is valid only for NAS volumes.
based_on_file_delete_op_rate
boolean
Specifies whether attack detection is based on the file delete operations rate. This parameter is valid only for NAS volumes.
based_on_file_rename_op_rate
boolean
Specifies whether attack detection is based on the file rename operations rate. This parameter is valid only for NAS volumes.
based_on_high_entropy_data_rate
boolean
Specifies whether a high entropy data rate should be considered for attack detection.
based_on_never_seen_before_file_extension
boolean
Specifies whether file extensions never seen before should be considered for attack detection.
block_device_auto_learned_encryption_threshold
integer
Specifies the block device auto learned encryption threshold.
integer
Specifies the percentage of surge in the file create rate up to which it is considered normal behavior.
file_delete_op_rate_surge_notify_percent
integer
Specifies the percentage of surge in the file delete rate up to which it is considered normal behavior.
file_rename_op_rate_surge_notify_percent
integer
Specifies the percent of surge in the file rename rate up to which it is considered normal behavior.
high_entropy_data_surge_notify_percent
integer
Specifies the percentage of surge in high entropy data up to which it is considered as normal behavior. For example, if the usual high entropy data rate in the volume is 5% and if this parameter is set to 100%, it will be considered as an unusual surge if the high entropy data rate of the volume exceeds 10% at any time. Similarly, if this parameter is set to 400%, it will be considered as an unusual surge if the high entropy data rate of the volume exceeds 25%, and so on.
never_seen_before_file_extension_count_notify_threshold
integer
Specifies the number of files found with a never seen before file extension up to which it is considered normal behavior.
never_seen_before_file_extension_duration_in_hours
integer
Specifies the duration within which the specified number of files found with never seen before file extensions is considered normal behavior.
relaxing_popular_file_extensions
boolean
Specifies whether popular file extensions should be relaxed from being treated as a suspect for the attack. Some popular file extensions are .txt, .pdf, and so on.
anti_ransomware_attack_report
_links
_links
time
string
Timestamp at which ransomware attack is observed.
clear_suspect
Clear suspect status.
phase
string
Clear suspect phase.
start_time
string
Clear suspect start time.
event_log
is_enabled_on_new_file_extension_seen
boolean
Specifies whether to send an EMS when a new file extension is discovered.
is_enabled_on_snapshot_copy_creation
boolean
Specifies whether to send an EMS when a snapshot is created.
space
snapshot_count
integer
Total number of Anti-ransomware backup snapshots.
used
integer
Total space in bytes used by the Anti-ransomware feature.
used_by_logs
integer
Space in bytes used by the Anti-ransomware analytics logs.
used_by_snapshots
integer
Space in bytes used by the Anti-ransomware backup snapshots.
surge_usage
Usage values of the volume's workload during surge. This object is no longer supported use surge_statistics instead.
integer
Peak rate of file creates per minute in the workload of the volume during surge.
integer
Peak rate of file deletes per minute in the workload of the volume during surge.
integer
Peak rate of file renames per minute in the workload of the volume during surge.
integer
Peak percentage of high entropy data writes in the volume during surge.
integer
Peak high entropy data write rate in the volume during surge, in KBs per minute.
time
string
Timestamp at which the first surge in the volume's workload is observed.
suspect_files
count
integer
Total number of suspect_files.format files observed by the Anti-ransomware analytics engine on the volume.
entropy
string
Indicates the entropy level of this file type.
format
string
File formats observed by the Anti-ransomware analytics engine on the volume.
typical_usage
Typical usage values of volume workload. This object is no longer supported use historical_statistics instead.
integer
Typical peak rate of file creates per minute in the workload of the volume.
integer
Typical peak rate of file deletes per minute in the workload of the volume.
integer
Typical peak rate of file renames per minute in the workload of the volume.
integer
Typical peak percentage of high entropy data writes in the volume.
integer
Typical peak high entropy data write rate in the volume, in KBs per minute.
integer
integer
integer
integer
integer
count
integer
Count of newly observed file extensions.
name
string
Name of the newly observed file extension.
surge_statistics
integer
integer
integer
integer
integer
time
string
surge_usage
integer
integer
integer
integer
integer
array[newly_observed_file_extensions]
New file extensions observed in the volume during surge.
time
string
anti_ransomware_volume_workload
integer
Count of types of file extensions observed in the volume.
array[string]
File extensions observed in the volume.
surge_statistics
surge_statistics
surge_usage
surge_usage
typical_usage
typical_usage
anti_ransomware
attack_detected_by
string
This field specifies whether the attack was reported by File Analysis or Encrypted data percentage analysis.
attack_probability
string
Probability of a ransomware attack. none No suspected ransomware activity. low Minimally suspected ransomware activity. moderate Moderately suspected ransomware activity. high Significantly suspected ransomware activity.
attack_reports
array[anti_ransomware_attack_report]
string
This field specifies the block device evaluation start time.
string
This field specifies the block device attack detection status. evaluation_period Attack detection is currently in its evaluation phase. active_unsuitable_workload Attack detection is active, but the current workload is not suitable for Anti-ransomware protection. active_suitable_workload Attack detection is active, and the current workload is appropriate for Anti-ransomware protection.
clear_suspect
clear_suspect
dry_run_start_time
string
Time when anti-ransomware monitoring state is set to dry-run value for starting evaluation mode.This field will no longer be supported in a future release.
event_log
event_log
space
space
state
string
Anti-ransomware state. disabled Anti-ransomware monitoring is disabled on the volume. This is the default state in a POST operation. disable_in_progress Anti-ransomware monitoring is being disabled and a cleanup operation is in effect. Valid in GET operation. dry_run Anti-ransomware monitoring is enabled in the evaluation mode. enabled Anti-ransomware monitoring is active on the volume. paused Anti-ransomware monitoring is paused on the volume. enable_paused Anti-ransomware monitoring is paused on the volume from its earlier enabled state. Valid in GET operation. dry_run_paused Anti-ransomware monitoring is paused on the volume from its earlier dry_run state. Valid in GET operation. For POST, the valid Anti-ransomware states are only disabled, enabled and dry_run, whereas for PATCH, paused is also valid along with the three valid states for POST.
surge_as_normal
boolean
Indicates whether or not to set the surge values as historical values. This field is no longer supported. Use update_baseline_from_surge instead.
surge_usage
surge_usage
suspect_files
array[suspect_files]
typical_usage
typical_usage
boolean
Sets the observed surge value as the new baseline on a volume.
workload
application
name
string
Name of the application to which the volume belongs. Available only when the volume is part of an application.
uuid
string
UUID of the application to which the volume belongs. Available only when the volume is part of an application.
enabled
boolean
Specifies whether asynchronous directory delete from the client is enabled on the volume.
trash_bin
string
Name of the trash bin directory. If no "trash_bin" property is specified when enabling, the default trash bin name, "._ontaptrashbin", is used.
autosize
grow_threshold
integer
Used space threshold size, in percentage, for the automatic growth of the volume. When the amount of used space in the volume becomes greater than this threshold, the volume automatically grows unless it has reached the maximum size. The volume grows when 'space.used' is greater than this percent of 'space.size'. The 'grow_threshold' size cannot be less than or equal to the 'shrink_threshold' size..
maximum
integer
Maximum size in bytes up to which a volume grows automatically. This size cannot be less than the current volume size, or less than or equal to the minimum size of volume.
minimum
integer
Minimum size in bytes up to which the volume shrinks automatically. This size cannot be greater than or equal to the maximum size of volume.
mode
string
Autosize mode for the volume. grow ‐ Volume automatically grows when the amount of used space is above the 'grow_threshold' value. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled.
shrink_threshold
integer
Used space threshold size, in percentage, for the automatic shrinkage of the volume. When the amount of used space in the volume drops below this threshold, the volume automatically shrinks unless it has reached the minimum size. The volume shrinks when the 'space.used' is less than the 'shrink_threshold' percent of 'space.size'. The 'shrink_threshold' size cannot be greater than or equal to the 'grow_threshold' size.
snapshot_reference
name
string
uuid
string
parent_svm
name
string
uuid
string
parent_volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • x-nullable: true
clone
has_flexclone
boolean
Specifies whether this volume is a parent of any FlexClone volume.
integer
Inherited physical used from the clone's base snapshot.
inherited_savings
integer
Inherited savings from the clone's base snapshot.
is_flexclone
boolean
Specifies if this volume is a normal FlexVol volume or FlexClone volume. This field needs to be set when creating a FlexClone volume. Valid in POST.
lun_name
string
This optional parameter specifies the name of a LUN that will be non-disruptively migrated to the newly created FlexClone volume. If not specified, no LUNs are migrated.
parent_snapshot
snapshot_reference
parent_svm
parent_svm
parent_volume
parent_volume
qtree_name
string
This optional parameter specifies the name of the qtree containing the LUN that will be non-disruptively migrated to the newly created FlexClone volume.
integer
Percentage of FlexClone volume blocks split from its parent volume.
split_estimate
integer
Space required by the containing-aggregate to split the FlexClone volume.
consistency_group
name
string
The name of the consistency group to which the volume belongs. Available only when the volume is part of a consistency group. If this volume belongs to a child consistency group, then this will be the UUID of the parent consistency group.
uuid
string
The UUID of the consistency group to which the volume belongs. Available only when the volume is part of a consistency group. If this volume belongs to a child consistency group, then this will be the UUID of the parent consistency group.
aggregates
name
string
Name of the aggregate hosting the FlexGroup volume constituent.
uuid
string
Unique identifier for the aggregate.
Aggregate
name
string
uuid
string
movement
cutover_window
integer
Time window in seconds for cutover. The allowed range is between 30 to 300 seconds.
Aggregate
percent_complete
integer
Completion percentage
state
string
State of volume move operation. PATCH the state to "aborted" to abort the move operation. PATCH the state to "cutover" to trigger cutover. PATCH the state to "paused" to pause the volume move operation in progress. PATCH the state to "replicating" to resume the paused volume move operation. PATCH the state to "cutover_wait" to go into cutover manually. When volume move operation is waiting to go into "cutover" state, this is indicated by the "cutover_pending" state. A change of state is only supported if volume movement is in progress.
tiering_policy
string
Tiering policy for FabricPool
node
name
string
List of the node names hosting the FlexGroup volume constituent.
uuid
string
List of the node UUIDs hosting the FlexGroup volume constituent.
logical_space
available
integer
The amount of space available in this volume with storage efficiency space considered used, in bytes.
enforcement
boolean
Specifies whether space accounting for operations on the volume is done along with storage efficiency.
reporting
boolean
Specifies whether space reporting on the volume is done along with storage efficiency.
used_by_afs
integer
The virtual space used by AFS alone (includes volume reserves) and along with storage efficiency, in bytes.
snapshot
autodelete_enabled
boolean
Specifies whether snapshot autodelete is currently enabled on this volume.
reserve_percent
integer
The space that has been set aside as a reserve for snapshot usage, in percent.
used
integer
The total space used by snapshots in the volume, in bytes.
space
afs_total
integer
Total size of AFS, excluding snap-reserve, in bytes.
available
integer
The available space, in bytes.
available_percent
integer
The space available, as a percent.
integer
The size that is physically used in the block storage of the volume and has a cold temperature. In bytes. This parameter is only supported if the volume is in an aggregate that is either attached to a cloud store or could be attached to a cloud store.
integer
Space used by capacity tier for this volume in the FabricPool aggregate, in bytes.
footprint
integer
Data used for this volume in the aggregate, in bytes.
large_size_enabled
boolean
Specifies whether the support for large volumes and large files is enabled on the volume.
integer
Space used by the local tier for this volume in the aggregate, in bytes.
logical_space
logical_space
max_size
string
Indicates the maximum size supported for each constituent of the FlexGroup volume.
metadata
integer
Space used by the volume metadata in the aggregate, in bytes.
over_provisioned
integer
The amount of space not available for this volume in the aggregate, in bytes.
integer
Space used by the performance tier for this volume in the FabricPool aggregate, in bytes.
size
integer
Total provisioned size. The default size is equal to the minimum size of 20MB, in bytes.
snapshot
snapshot
total_footprint
integer
Data and metadata used for this volume in the aggregate, in bytes.
total_metadata
integer
Space used by the total metadata in the volume, in bytes.
integer
Space used by the volume metadata footprint in the aggregate, in bytes.
used
integer
The virtual space used (includes volume reserves) before storage efficiency, in bytes.
used_by_afs
integer
The space used by Active Filesystem, in bytes.
used_percent
integer
The virtual space used (includes volume reserves) before storage efficiency, as a percent.
constituents
aggregates
aggregates
movement
movement
name
string
FlexGroup volume constituent name.
node
node
space
space
idcs_scanner
Inactive data compression scan looks and picks up blocks that have not been read for a certain amount of time(threshold_inactive_days). These blocks are then compressed in 32K chunks. All attributes are valid for GET only, except for 'operation_state' which is valid for PATCH and GET, and is used to start/stop the scanner.
enabled
boolean
Specifies the administrative state of the inactive data compression scanner. Disabling inactive data compression is not allowed on Capacity optimized Flash with QAT supported platforms.
inactive_days
integer
Data blocks older than, or equal to, 'inactive_days' are picked up by the inactive data compression scanner. Valid for PATCH only. Only applicable when 'operation_state' set to 'active'.
mode
string
Specifies the mode of inactive data compression scanner. Valid for PATCH and GET.
operation_state
string
Specifies the operational state of the inactive data compression scanner. VALID for PATCH and GET. Valid options for PATCH are "idle" and "active".
status
string
Status of last inactive data compression scan on the volume.
string
Time interval after which inactive data compression is automatically triggered. The value is in days and is represented in the ISO-8601 format "PD", for example "P3D" represents a duration of 3 days. This field is not supported on QAT supported platforms.
policy
name
string
Specifies the name of the efficiency policy. The "inline-only" and "none" policies are not supported on Capacity optimized Flash with QAT supported platform.
scanner
space_savings
compression
integer
Total disk space that is saved by compressing blocks on the referenced file system, in bytes.
compression_percent
integer
Percentage of total disk space that is saved by compressing blocks on the referenced file system.
dedupe
integer
Total disk space that is saved by deduplication and file cloning, in bytes.
dedupe_percent
integer
Percentage of total disk space that is saved by deduplication and file cloning.
dedupe_sharing
integer
Total disk space that is shared due to deduplication and file cloning.
total
integer
Total disk space saved in the volume due to deduplication, compression and file cloning, in bytes.
total_percent
integer
Percentage of total disk space saved in the volume due to deduplication, compression and file cloning.
efficiency
application_io_size
string
Block size to use by compression. 8k and auto are only allowed for POST. Only auto is supported on QAT supported platforms.
auto_state
string
Automatic deduplication schedule volume state. auto ‐ Volumes with auto_state set to auto start post-process deduplication automatically. deprioritized ‐ Volumes with auto_state set to deprioritized do not start post-process deduplication automatically.
compaction
string
The system can be enabled/disabled compaction. inline ‐ Data will be compacted first and written to the volume. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are compaction enabled and some are disabled.
compression
string
The system can be enabled/disabled compression. Disabling compression is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be compressed first and written to the volume. background ‐ Data will be written to the volume and compressed later. both ‐ Inline compression compresses the data and write to the volume, background compression compresses only the blocks on which inline compression is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are compression enabled and some are disabled.
Note that On volumes with container compression enabled, background compression refers to inactive data compression scan enabled on the volume.
compression_type
string
Compression type to use by compression. Valid for PATCH and GET.
cross_volume_dedupe
string
The system can be enabled/disabled cross volume dedupe. it can be enabled only when dedupe is enabled. Disabling cross volume dedupe is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be cross volume deduped first and written to the volume. background ‐ Data will be written to the volume and cross volume deduped later. both ‐ Inline cross volume dedupe dedupes the data and write to the volume, background cross volume dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are cross volume dedupe enabled and some are disabled.
dedupe
string
The system can be enabled/disabled dedupe. Disabling dedupe is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be deduped first and written to the volume. background ‐ Data will be written to the volume and deduped later. both ‐ Inline dedupe dedupes the data and write to the volume, background dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are dedupe enabled and some are disabled.
has_savings
boolean
When true, indicates that the volume contains shared(deduplication, file clones) or compressed data.
idcs_scanner
idcs_scanner
last_op_begin
string
Last sis operation begin timestamp.
last_op_end
string
Last sis operation end timestamp.
last_op_err
string
Last sis operation error text.
last_op_size
integer
Last sis operation size.
last_op_state
string
Last sis operation state.
logging_enabled
boolean
When true, indicates that space savings for any newly-written data are being logged.
op_state
string
Sis status of the volume.
policy
policy
progress
string
Sis progress of the volume.
ratio
number
Storage efficiency that does not include the savings provided by snapshots.
scanner
scanner
schedule
string
Schedule associated with volume.
space_savings
space_savings
state
string
Storage efficiency state of the volume. Currently, this field supports POST/PATCH only for RW (Read-Write) volumes on FSx for ONTAP and Cloud Volumes ONTAP. disabled ‐ All storage efficiency features are disabled. mixed ‐ Read-only field for FlexGroup volumes, storage efficiency is enabled on certain constituents and disabled on others. On FSx for ONTAP and Cloud Volumes ONTAP ‐   enabled ‐ All supported storage efficiency features for the volume are enabled.   custom ‐ Read-only field currently only supported for the FSx for ONTAP and Cloud Volumes ONTAP, user-defined storage efficiency features are enabled. For other platforms ‐   enabled ‐ At least one storage efficiency feature for the volume is enabled.
  • enum: ["disabled", "enabled", "mixed", "custom"]
  • Introduced in: 9.9
  • x-nullable: true
string
Storage efficiency mode used by volume. This parameter is supported only on AFF platforms. There is no difference between default and efficient modes on QAT supported platforms and auto adaptive compression is set irrespective of the modes.
type
string
Sis Type of the volume.
volume_path
string
Absolute volume path of the volume.
status
Name Type Description
code
string
Encryption progress message code.
message
string
Encryption progress message.
encryption
action
string
This field can be used to pause an ongoing rekey or conversion operation or resume a paused rekey or conversion operation. Valid in PATCH. The following actions are supported for this field: conversion_pause ‐ Pause an encryption conversion operation currently in progress. conversion_resume ‐ Resume a paused encryption conversion operation. rekey_pause ‐ Pause an encryption rekey operation currently in progress. rekey_resume ‐ Resume a paused encryption rekey operation.
enabled
boolean
Creates an encrypted or an unencrypted volume. For POST, when set to 'true', a new key is generated and used to encrypt the given volume. In that case, the underlying SVM must be configured with the key manager. When set to 'false', the volume created will be unencrypted. For PATCH, when set to 'true', it encrypts an unencrypted volume. Specifying the parameter as 'false' in a PATCH operation for an encrypted volume is only supported when moving the volume to another aggregate.
key_create_time
string
Encryption key creation time of the volume.
key_id
string
The key ID used for creating encrypted volume. A new key-id is generated for creating an encrypted volume. This key-id is associated with the generated key.
string
Specifies an additional key manager attribute that is an identifier-value pair, separated by '='. For example, CRN=unique-value. This parameter is required when using the POST method and an IBM Key Lore key manager is configured on the SVM.
state
string
Volume encryption state. encrypted ‐ The volume is completely encrypted. encrypting ‐ Encryption operation is in progress. partial ‐ Some constituents are encrypted and some are not. Applicable only for FlexGroup volume. rekeying. Encryption of volume with a new key is in progress. unencrypted ‐ The volume is a plain-text one.
status
status
type
string
Volume encryption type. none ‐ The volume is a plain-text one. volume ‐ The volume is encrypted with NVE (NetApp Volume Encryption). aggregate ‐ The volume is encrypted with NAE (NetApp Aggregate Encryption).
error_state
has_bad_blocks
boolean
Indicates whether the volume has any corrupt data blocks. If the damaged data block is accessed, an IO error, such as EIO for NFS or STATUS_FILE_CORRUPT for CIFS, is returned.
is_inconsistent
boolean
Indicates whether the file system has any inconsistencies. true ‐ File system is inconsistent. false ‐ File system in not inconsistent.
files
inodefile_capacity
integer
Number of inodes that can currently be stored on the volume for user-visible files. This number dynamically increases as more user-visible files are created.
maximum
integer
The maximum number of files (inodes) for user-visible data allowed on the volume. This value can be increased or decreased. Increasing the maximum number of files does not immediately cause additional disk space to be used to track files. Instead, as more files are created on the volume, the system dynamically increases the number of disk blocks that are used to track files. The space assigned to track files is never freed, and this value cannot be decreased below the current number of files that can be tracked within the assigned space for the volume. Valid in PATCH.
used
integer
Number of files (inodes) used for user-visible data permitted on the volume. This field is valid only when the volume is online.
flash_pool
cache_eligibility
string
If this parameter is specified, the command displays information only about the volume or volumes with the specified Flash Pool caching attributes.
string
If this parameter is specified, the command displays the volumes that match the specified cache retention priority policy. A cache retention priority defines how long the blocks of a volume will be cached in the Flash Pool once they become cold.
caching_policy
string
This optionally specifies the caching policy to apply to the volume. A caching policy defines how the system caches a volume's data in Flash Cache modules. If a caching policy is not assigned to a volume, the system uses the caching policy that is assigned to the containing SVM. If a caching policy is not assigned to the containing SVM, the system uses the default cluster-wide policy.
flexgroup
name
string
Name of the FlexGroup volume that the constituent is part of.
uuid
string
Unique identifier for the FlexGroup volume that the constituent is part of.
guarantee
honored
boolean
Is the space guarantee of this volume honored in the aggregate?
type
string
The type of space guarantee of this volume in the aggregate.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
cloud
Performance numbers (IOPS and latency) for cloud store. These numbers are relevant only for volumes hosted on FabricPools.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
timestamp
string
The timestamp of the performance data.
flexcache
Performance number for FlexCache used to measure cache effectiveness.
bandwidth_savings
integer
Bandwidth savings denoting the amount of data served locally by the cache, in bytes.
cache_miss_percent
integer
Cache miss percentage.
duration
string
status
string
timestamp
string
throughput
other
integer
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS, latency and throughput.
cloud
cloud
duration
string
flexcache
flexcache
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
movement
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation.
percent_complete
integer
start_time
string
Start time of volume move.
export_policy
Export Policy
id
integer
name
string
junction_parent
name
string
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume.
uuid
string
Unique identifier for the parent volume.
nas
export_policy
export_policy
Export Policy
gid
integer
The UNIX group ID of the volume. Valid in POST or PATCH.
junction_parent
junction_parent
path
string
The fully-qualified path in the owning SVM's namespace at which the volume is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one volume can be mounted at any given junction path. An empty path in POST creates an unmounted volume. An empty path in PATCH deactivates and unmounts the volume. Taking a volume offline or restricted state removes its junction path. This attribute is reported in GET only when the volume is mounted.
security_style
string
Security style associated with the volume. Valid in POST or PATCH. mixed ‐ Mixed-style security ntfs ‐ NTFS/WIndows-style security unified ‐ Unified-style security, unified UNIX, NFS and CIFS permissions unix ‐ Unix-style security.
uid
integer
The UNIX user ID of the volume. Valid in POST or PATCH.
unix_permissions
integer
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write) and 1 (execute). First digit selects the set user ID(4), set group ID (2) and sticky (1) attributes. The second digit selects permission for the owner of the file; the third selects permissions for other users in the same group; the fourth for other users not in the group. Valid in POST or PATCH. For security style "mixed" or "unix", the default setting is 0755 in octal (493 in decimal) and for security style "ntfs", the default setting is 0000. In cases where only owner, group and other permissions are given (as in 755, representing the second, third and fourth dight), first digit is assumed to be zero.
nodes
name
string
List of the node names hosting the volume.
uuid
string
List of the node UUIDs hosting the volume.
policy
When "min_throughput_iops", "min_throughput_mbps", "min_throughput", "max_throughput_iops", "max_throughput_mbps" or "max_throughput" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed.
max_throughput
string
Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
min_throughput
string
Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos
QoS information
policy
policy
quota
Quotas track the space or file usage of a user, group, or qtree in a FlexVol volume or a FlexGroup volume.
enabled
boolean
This option is used to enable or disable the quota for the volume. This option is valid only in PATCH. Quotas are enabled for FlexVol volumes or FlexGroup volumes when the quota state is "on". Quotas are disabled for FlexVol volumes or FlexGroup volumes when the quota state is "off".
state
string
Quota state of the volume
last_error
Error information for the last failed file move on the constituent.
code
integer
Error code of the last file move error on the constituent.
destination
integer
DSID of the destination constituent of the last file move error on the constituent.
file_id
integer
File ID of the last file move error on the constituent.
time
string
Time of the last file move error on the constituent.
movement
Properties on this constituent related to file movement.
file_moves_started
integer
Number of file moves started on this constituent.
last_error
last_error
string
Start time of the most recent file move on the constituent.
blocks_skipped
Number of blocks skipped by the scanner on this constituent due to various reasons.
efficiency_blocks
integer
Number of blocks skipped by the scanner on this constituent because storage efficiency lost, in blocks, would be too high.
efficiency_percent
integer
Number of blocks skipped by the scanner on this constituent because storage efficiency lost, in percent, would be too high.
fast_truncate
integer
Number of blocks skipped by the scanner on this constituent because fast truncate is currently running on files.
footprint_invalid
integer
Number of blocks skipped by the scanner on this constituent because of files with invalid space footprints.
in_snapshot
integer
Number of blocks skipped by the scanner on this constituent because of files in snapshots.
incompatible
integer
Number of blocks skipped by the scanner on this constituent because of incompatible files.
metadata
integer
Number of blocks skipped by the scanner on this constituent because of metadata files.
integer
Number of blocks skipped by the scanner on this constituent because of on demand destination files.
other
integer
Number of blocks skipped by the scanner on this constituent for all other reasons.
remote_cache
integer
Number of blocks skipped by the scanner on this constituent because of remote caches.
too_large
integer
Number of blocks skipped by the scanner on this constituent because of files that are larger than rebalancing.max_file_size.
too_small
integer
Number of blocks skipped by the scanner on this constituent because of files that are smaller than rebalancing.min_file_size.
write_fenced
integer
Number of blocks skipped by the scanner on this constituent because of files fenced for write operations.
files_skipped
Number of files skipped by the scanner on this constituent due to various reasons.
efficiency_blocks
integer
Number of files skipped by the scanner on this constituent because storage efficiency lost, in blocks, would be too high.
efficiency_percent
integer
Number of files skipped by the scanner on this constituent because storage efficiency lost, in percent, would be too high.
fast_truncate
integer
Number of files skipped by the scanner on this constituent because fast truncate is currently running on the file.
footprint_invalid
integer
Number of files skipped by the scanner on this constituent because their space footprints are invalid.
in_snapshot
integer
Number of files skipped by the scanner on this constituent because they are trapped in snapshots.
incompatible
integer
Number of files skipped by the scanner on this constituent because they are incompatible.
metadata
integer
Number of files skipped by the scanner on this constituent because they metadata files.
integer
Number of files skipped by the scanner on this constituent because they are on demand destinations.
other
integer
Number of files skipped by the scanner on this constituent for all other reasons.
remote_cache
integer
Number of files skipped by the scanner on this constituent because they are remote caches.
too_large
integer
Number of files skipped by the scanner on this constituent because they are larger than rebalancing.max_file_size.
too_small
integer
Number of files skipped by the scanner on this constituent because they are smaller than rebalancing.min_file_size.
write_fenced
integer
Number of files skipped by the scanner on this constituent because they are fenced for write operations.
scanner
Properties related to determining which files to move and where to move them to.
blocks_scanned
integer
Number of blocks scanned on this constituent.
blocks_skipped
blocks_skipped
files_scanned
integer
Number of files scanned on this constituent.
files_skipped
files_skipped
engine
Each constituent has one rebalancing engine that co-ordinates scanning constituents for free space and files to move, as well as moving files between constituents. The engine properties must be explicitly requested, are meant for helping diagnose why the volume rebalancer is making decisions.
movement
movement
scanner
scanner
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
rebalancing
Configuration and runtime properties involving non-disruptive volume capacity rebalancing for a FlexGroup volume.
data_moved
integer
The amount of data that has been moved in or out of a constituent. A positive value represents data moving into the constituent while a negative value is data moving out of the constituent.
engine
engine
imbalance_percent
integer
Represents the percentage the volume is out of balance.
imbalance_size
integer
Represents how much the volume is out of balance, in bytes.
max_constituent_imbalance_percent
integer
Absolute percentage of the constituent that is most out of balance. This value will update every 30 seconds when rebalancing is not active and every 10 seconds when rebalancing is active.
notices
array[error]
Capacity rebalancing notice messages.
runtime
string
Duration the capacity rebalancing operation has been running.
stop_time
string
Time when the capacity rebalancing operation stopped.
target_used
integer
Represents the ideal used size of each constituent. Calculated by dividing the total FlexGroup volume used size by the number of constituents.
used_for_imbalance
integer
Represents the used size of each constituent, as determined by the rebalancing engine. Calculated by subtracting the size used by snapshots, the size of files pending deletion and the size of filesystem metadata from the volume used size.
retention
default
string
Specifies the default retention period that is applied to files while committing them to the WORM state without an associated retention period. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period and the string "unspecified" to set an unspecified retention period.
maximum
string
Specifies the maximum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period.
minimum
string
Specifies the minimum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, month,s and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period.
snaplock
append_mode_enabled
boolean
Specifies if the volume append mode is enabled or disabled. When it is enabled, all the files created with write permissions on the volume are, by default, WORM appendable files. The user can append the data to a WORM appendable file but cannot modify the existing contents of the file nor delete the file until it expires.
autocommit_period
string
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater than the autocommit period of the volume are committed to the WORM state. The autocommit period value represents a duration and must be specified in the ISO-8601 duration format. The autocommit period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the autocommit field also accepts the string "none".
compliance_clock_time
string
This is the volume compliance clock time which is used to manage the SnapLock objects in the volume.
expiry_time
string
Expiry time of the volume. For volumes with an infinite, indefinite or unspecified SnapLock expiry time, "9999-12-31T23:59:59" is used to denote the time.
is_audit_log
boolean
Indicates if this volume has been configured as SnapLock audit log volume for the SVM .
litigation_count
integer
Litigation count indicates the number of active legal-holds on the volume.
privileged_delete
string
Specifies the privileged-delete attribute of a SnapLock volume. On a SnapLock Enterprise (SLE) volume, a designated privileged user can selectively delete files irrespective of the retention time of the file. SLE volumes can have privileged delete as disabled, enabled or permanently_disabled and for SnapLock Compliance (SLC) volumes it is always permanently_disabled.
retention
retention
type
string
The SnapLock type of the volume. compliance ‐ A SnapLock Compliance(SLC) volume provides the highest level of WORM protection and an administrator cannot destroy a SLC volume if it contains unexpired WORM files. enterprise ‐ An administrator can delete a SnapLock Enterprise(SLE) volume. non_snaplock ‐ Indicates the volume is non-snaplock.
unspecified_retention_file_count
integer
Indicates the number of files with an unspecified retention time in the volume.
destinations
is_cloud
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to a cloud destination.
is_ontap
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to an ONTAP destination.
  • readOnly: 1
  • x-nullable: true
snapmirror
Specifies attributes for SnapMirror protection.
destinations
destinations
is_protected
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data.
snapshot_policy
This is a reference to the snapshot policy.
name
string
uuid
string
logical_space
available
integer
enforcement
boolean
reporting
boolean
used
integer
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), in bytes.
used_by_afs
integer
used_by_snapshots
integer
Size that is logically used across all snapshots in the volume, in bytes.
used_percent
integer
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), as a percentage.
autodelete
enabled
boolean
snapshot
autodelete
autodelete
autodelete_enabled
boolean
Specifies whether snapshot autodelete is currently enabled on this volume. This field will no longer be supported in a future release. Use autodelete.enabled instead.
reserve_available
integer
Size available for snapshots within the snapshot reserve, in bytes.
reserve_percent
integer
reserve_size
integer
Size in the volume that has been set aside as a reserve for snapshot usage, in bytes.
space_used_percent
integer
Percentage of snapshot reserve size that has been used.
used
integer
space
afs_total
integer
auto_adaptive_compression_footprint_data_reduction
integer
Savings achieved due to Auto Adaptive Compression, in bytes.
available
integer
available_percent
integer
block_storage_inactive_user_data
integer
block_storage_inactive_user_data_percent
integer
Percentage of size that is physically used in the performance tier of the volume.
capacity_tier_footprint
integer
capacity_tier_footprint_data_reduction
integer
Savings achieved in the space used by the capacity tier for this volume in the FabricPool aggregate, in bytes.
compaction_footprint_data_reduction
integer
Savings achieved due to Data Compaction, in bytes.
cross_volume_dedupe_metafiles_footprint
integer
Cross volume deduplication metadata footprint, in bytes.
cross_volume_dedupe_metafiles_temporary_footprint
integer
Cross volume temporary deduplication metadata footprint, in bytes.
integer
Deduplication metadata footprint, in bytes.
integer
Temporary deduplication metadata footprint, in bytes.
delayed_free_footprint
integer
Delayed free blocks footprint, in bytes.
effective_total_footprint
integer
Volume footprint after efficiency savings, in bytes. effective total footprint represents total footprint after deducting auto adaptive compression and compaction savings. effective-footprint includes aggregate metadata used by volume.
expected_available
integer
Size that should be available for the volume, irrespective of available size in the aggregate, in bytes.
file_operation_metadata
integer
File operation metadata footprint, in bytes.
filesystem_size
integer
Total usable size of the volume, in bytes.
filesystem_size_fixed
boolean
Specifies whether the file system is to remain of the same size when set to true or to grow when set to false. This option is automatically set to true when a volume becomes SnapMirrored.
footprint
integer
fractional_reserve
integer
Used to change the amount of space reserved for overwrites of reserved objects in a volume.
full_threshold_percent
integer
Volume full threshold percentage at which EMS warnings can be sent.
is_used_stale
boolean
Specifies if the virtual space used is stale.
large_size_enabled
boolean
Indicates if the support for large FlexVol volumes and large files is enabled on this volume. When configured to true, FlexVol volume size can reach up to 300TB and single file size can reach 128TB.
local_tier_footprint
integer
logical_space
logical_space
max_size
string
Indicates the maximum size supported for the FlexVol volume or for each constituent of the FlexGroup volume.
metadata
integer
nearly_full_threshold_percent
integer
Volume nearly full threshold percentage at which EMS warnings can be sent.
over_provisioned
integer
overwrite_reserve
integer
Reserved space for overwrites, in bytes.
overwrite_reserve_used
integer
Overwrite logical reserve space used, in bytes.
percent_used
integer
Percentage of the volume size that is used.
performance_tier_footprint
integer
physical_used
integer
Size that is physically used in the volume, in bytes. Physical used is effective total footprint which is equivalent to total footprint after deducting auto adaptive compression and compaction savings. Physical-used also includes aggregate metadata used by volume.
physical_used_percent
integer
Size that is physically used in the volume, as a percentage.
size
integer
size_available_for_snapshots
integer
Available space for snapshots from snap-reserve, in bytes.
snapmirror_destination_footprint
integer
SnapMirror destination footprint, in bytes.
snapshot
snapshot
snapshot_reserve_unusable
integer
Snapshot reserve that is not available for snapshot creation, in bytes.
snapshot_spill
integer
Space used by the snapshot copies beyond the snap-reserve, in bytes.
total_footprint
integer
total_metadata
integer
total_metadata_footprint
integer
used
integer
used_by_afs
integer
user_data
integer
User data, in bytes.
volume_guarantee_footprint
integer
Space reserved for future writes in the volume, in bytes.
access
Raw count and latency data for access operations.
count
integer
Number of operations of the given type performed on this volume.
total_time
integer
The raw data component latency in microseconds measured within ONTAP for all operations of the given type.
  • example: 200
  • Introduced in: 9.11
  • x-nullable: true
audit
Raw count and latency data for audit operations. These statistics are only applicable for CIFS protocol operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
dir
Raw count and latency data for directory-create operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
file
Raw count and latency data for file-create operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
other
Raw count and latency data for create operations on objects other than files, directories and symlinks.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
Raw count and latency data for symlink-create operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
create
Raw count and latency data for create operations.
getattr
Raw count and latency data for getattr operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
Raw count and latency data for link operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
lock
Raw count and latency data for lock operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
lookup
Raw count and latency data for lookup operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
open
Raw count and latency data for open operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
read
Raw count and latency data for read operations, including histograms categorizing operations by size and latency.
count
integer
total_time
integer
  • example: 200
  • readOnly: 1
  • x-ntap-advanced: true
  • x-nullable: true
volume_protocol_latency_histogram_counts
array[integer]
volume_protocol_latency_histogram_labels
array[string]
Labels for the latency histogram, ranging from <2us to >20s.
volume_protocol_size_histogram_counts
array[integer]
volume_protocol_size_histogram_labels
array[string]
Labels for the size histogram, ranging from <4KB to >1024KB.
readdir
Raw count and latency data for readdir operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
Raw count and latency data for readlink operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
rename
Raw count and latency data for rename operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
setattr
Raw count and latency data for setattr operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
Raw count and latency data for unlink operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
watch
Raw count and latency data for watch operations. These statistics are only applicable for CIFS protocol operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
write
Raw count and latency data for write operations, including histograms categorizing operations by size and latency.
count
integer
total_time
integer
  • example: 200
  • readOnly: 1
  • x-nullable: true
array[integer]
array[string]
array[integer]
array[string]
cifs_ops_raw
Raw data component performance values for CIFS operations on this volume, including number of operations and raw latency, in microseconds for each operation. The values are cumulative and increase while the volume is online.
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
cloud
These are raw performance numbers (IOPS and latency) for the cloud store. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. These numbers are relevant only for volumes hosted on FabricPools.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
timestamp
string
flexcache_raw
Performance numbers for FlexCache used to measure cache effectiveness.
cache_miss_blocks
integer
Blocks retrieved from origin in case of a cache miss. This can be divided by the raw client_requested_blocks and multiplied by 100 to calculate the cache miss percentage.
integer
Total blocks requested by the client.
status
string
timestamp
string
nfs_ops_raw
Raw data component performance values for NFS operations on this volume, including number of operations and raw latency, in microseconds for each operation. The values are cumulative and increase while the volume is online.
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
cifs_ops_raw
cifs_ops_raw
cloud
cloud
flexcache_raw
flexcache_raw
iops_raw
iops_raw
latency_raw
latency_raw
nfs_ops_raw
nfs_ops_raw
status
string
throughput_raw
throughput_raw
timestamp
string
svm
SVM containing the volume. Required on POST.
name
string
uuid
string
tiering
min_cooling_days
integer
This parameter specifies the minimum number of days that user data blocks of the volume must be cooled before they can be considered cold and tiered out to the cloud tier. Note that this parameter is only used for tiering purposes and does not affect the reporting of inactive data. The value specified should be greater than the frequency with which applications in the volume shift between different sets of data. This parameter cannot be set when volume tiering policy is either "none" or "all". The default value of this parameter depends on the volume's tiering policy. See the tiering policy section of this documentation for corresponding default values. If the tiering policy on the volume gets changed, then this parameter will be reset to the default value corresponding to the new tiering policy.
object_tags
array[string]
This parameter specifies tags of a volume for objects stored on a FabricPool-enabled aggregate. Each tag is a key,value pair and should be in the format "key=value".
policy
string
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH. all ‐ This policy allows tiering of both snapshots and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks. auto ‐ This policy allows tiering of both snapshot and active file system user data to the cloud store none ‐ Volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the volume snapshots not associated with the active file system. The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy is 31 days.
supported
boolean
This parameter specifies whether or not FabricPools are selected when provisioning a FlexGroup volume without specifying "aggregates.name" or "aggregates.uuid". Only FabricPool aggregates are used if this parameter is set to true and only non FabricPool aggregates are used if this parameter is set to false. Tiering support for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. Note that in order to tier data, not only does the volume need to support tiering by using FabricPools, the tiering "policy" must not be 'none'. A volume that uses FabricPools but has a tiering "policy" of 'none' supports tiering, but will not tier any data.
volume
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
activity_tracking
activity_tracking
aggregates
array[aggregates]
Aggregate(s) hosting the volume. Optional.
aggressive_readahead_mode
string
Specifies the aggressive_readahead_mode enabled on the volume. When set to file_prefetch, on a file read, the system aggressively issues readaheads for all of the blocks in the file and retains those blocks in a cache for a finite period of time. When the option is set to sequential_read, the system aggressively prefetches the file completely, or to a certain length based on the file size limit, and continues as the read makes progress. If the option is set to cross_file_sequential_read, then the system aggressively prefetches multiple files completely, or to a certain length, and continues as the read makes progress.
analytics
analytics
anti_ransomware
anti_ransomware
Anti-ransomware related information of the volume.
application
application
asynchronous_directory_delete
Configuration for asynchronous directory delete from the client. This is only supported on Flexible volumes and FlexGroup volumes.
autosize
autosize
clone
clone
cloud_retrieval_policy
string
This parameter specifies the cloud retrieval policy for the volume. This policy determines which tiered out blocks to retrieve from the capacity tier to the performance tier. The available cloud retrieval policies are "default" policy retrieves tiered data based on the underlying tiering policy. If the tiering policy is 'auto', tiered data is retrieved only for random client driven data reads. If the tiering policy is 'none' or 'snapshot_only', tiered data is retrieved for random and sequential client driven data reads. If the tiering policy is 'all', tiered data is not retrieved. "on_read" policy retrieves tiered data for all client driven data reads. "never" policy never retrieves tiered data. "promote" policy retrieves all eligible tiered data automatically during the next scheduled scan. It is only supported when the tiering policy is 'none' or 'snapshot_only'. If the tiering policy is 'snapshot_only', the only data brought back is the data in the AFS. Data that is only in a snapshot copy stays in the cloud and if tiering policy is 'none' then all data is retrieved.
cloud_write_enabled
boolean
Indicates whether or not cloud writes are enabled on the volume. NFS writes to this volume are sent to the cloud directly instead of the local performance tier. This feature is only available on volumes in FabricPools.
comment
string
A comment for the volume. Valid in POST or PATCH.
consistency_group
consistency_group
Consistency group the volume is part of.
constituents
array[constituents]
FlexGroup volume constituents. FlexGroup volume constituents can be retrieved more efficiently by specifying "is_constituent=true" or "is_constituent=true&flexgroup.uuid=" as query parameters.
constituents_per_aggregate
integer
Specifies the number of times to iterate over the aggregates listed with the "aggregates.name" or "aggregates.uuid" when creating or expanding a FlexGroup volume. If a volume is being created on a single aggregate, the system creates a flexible volume if the "constituents_per_aggregate" field is not specified, or a FlexGroup volume if it is specified. If a volume is being created on multiple aggregates, the system always creates a FlexGroup volume. If a volume is being created on multiple aggregates and the "constituents_per_aggregate" field is not specified, the default value of the "constituents_per_aggregate" field is 4. The root constituent of a FlexGroup volume is always placed on the first aggregate in the list, unless 'optimize_aggregates' is specified as 'true'. If the "aggregates.name" or "aggregates.uuid" is specified in a PATCH request to expand an existing FlexGroup volume, the default value of the "constituents_per_aggregate" field is 1. The volume expand operation is only supported on FlexGroup volumes.
convert_unicode
boolean
Specifies whether directory Unicode format conversion is enabled when directories are accessed by NFS clients.
create_time
string
Creation time of the volume. This field is generated when the volume is created.
efficiency
efficiency
encryption
encryption
error_state
error_state
files
files
flash_pool
flash_pool
flexcache_endpoint_type
string
FlexCache endpoint type. none ‐ The volume is neither a FlexCache nor origin of any FlexCache. cache ‐ The volume is a FlexCache volume. origin ‐ The volume is origin of a FlexCache volume.
flexgroup
flexgroup
granular_data
boolean
State of granular data on the volume. This setting is true by default when creating an AWS S3 FlexGroup volume via a POST request and false by default for creating any other type of FlexGroup volume via a POST request. On FlexVol volumes, the setting is always false, as only FlexGroup volumes support this feature. Once enabled, this setting can only be disabled by restoring a snapshot. Earlier versions of ONTAP (pre 9.12) are not compatible with this feature. Therefore, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the setting was enabled.
  • Introduced in: 9.12
  • x-nullable: true
granular_data_mode
string
Mode of granular data on the volume. This setting defaults to basic when the granular_data parameter is set to true, but can be specified at the time of creation via a POST request. Earlier versions of ONTAP (pre 9.12) are not compatible with the basic setting. Therefore, when set to basic, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the basic mode was enabled. Earlier versions of ONTAP (pre 9.16) are not compatible with the advanced setting. Therefore, when set to advanced, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the advanced mode was enabled.
  • enum: ["disabled", "basic", "advanced"]
  • Introduced in: 9.16
  • x-nullable: true
guarantee
guarantee
has_dir_index_public
boolean
Specifies whether the volume has directories with public index files.
has_large_dir
boolean
Specifies whether the volume has directories bigger than 4GB.
is_dir_index_transfer_enabled
boolean
When set to true, this field enables support for directory index transfer.
is_large_dir_enabled
boolean
When set to true, this field enables the large directory feature on a volume.
is_object_store
boolean
Specifies whether the volume is provisioned for an object store server.
is_s3_arbitrary_part_size_enabled
boolean
Specifies that the volume should allow Amazon S3 multipart uploads with arbitrary part lengths. This is only supported for FlexGroup volumes with advanced granular_data. The default value is false. When set to true, it cannot be reverted to false. Clusters with any volumes where this is true cannot be reverted to a release that does not support this feature.
is_svm_root
boolean
Specifies whether the volume is a root volume of the SVM it belongs to.
language
string
Language encoding setting for volume. If no language is specified, the volume inherits its SVM language encoding setting.
max_dir_size
integer
Maximum directory size. This value sets maximum size, in bytes, to which a directory can grow. The default maximum directory size for FlexVol volumes is model-dependent, and optimized for the size of system memory. Before increasing the maximum directory size, involve technical support.
movement
movement
msid
integer
The volume's Master Set ID.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroup volumes, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
nas
nas
nodes
array[nodes]
List of the nodes hosting the volume.
optimize_aggregates
boolean
Specifies whether to create the constituents of the FlexGroup volume on the aggregates specified in the order they are specified, or whether the system should optimize the ordering of the aggregates. If this value is 'true', the system optimizes the ordering of the aggregates specified. If this value is false, the order of the aggregates is unchanged. The default value is 'false'.
qos
qos
QoS information
quota
quota
rebalancing
rebalancing
scheduled_snapshot_naming_scheme
string
Naming Scheme for automatic snapshots:
  • create_time - Automatic snapshots are saved as per the start of their current date and time.
  • ordinal - Latest automatic snapshot copy is saved as .0 and subsequent copies will follow the create_time naming convention.
size
integer
Physical size of the volume, in bytes. The minimum size for a FlexVol volume is 20MB and the minimum size for a FlexGroup volume is 200MB per constituent. The recommended size for a FlexGroup volume is a minimum of 100GB per constituent. For all volumes, the default size is equal to the minimum size.
sizing_method
string
When expanding a FlexGroup volume, this specifies whether to add new constituents, or to resize the current constituents.
snaplock
snaplock
snapmirror
snapmirror
snapshot_count
integer
Number of snapshots in the volume.
snapshot_directory_access_enabled
boolean
This field, if true, enables the visible ".snapshot" directory from the client. The ".snapshot" directory will be available in every directory on the volume.
snapshot_locking_enabled
boolean
Specifies whether or not snapshot copy locking is enabled on the volume.
snapshot_policy
snapshot_policy
space
space
state
string
Volume state. Client access is supported only when volume is online and junctioned. Taking volume to offline or restricted state removes its junction path and blocks client access. When volume is in restricted state some operations like parity reconstruction and iron on commit are allowed. The 'mixed' state applies to FlexGroup volumes only and cannot be specified as a target state. An 'error' state implies that the volume is not in a state to serve data.
status
array[string]
Describes the current status of a volume.
style
string
The style of the volume. If "style" is not specified, the volume type is determined based on the specified aggregates or license. Specifying a single aggregate, without "constituents_per_aggregate", creates a flexible volume. Specifying multiple aggregates, or a single aggregate with "constituents_per_aggregate", creates a FlexGroup volume. When the UDO License is installed, and no aggregates are specified, the system automatically provisions a FlexGroup volume on system selected aggregates. Specifying a volume "style" creates a volume of that type. For example, if the style is "flexvol", you must specify a single aggregate. If the style is "flexgroup", the system either uses the specified aggregates or automatically provisions aggregates if there are no specified aggregates. The style "flexgroup_constituent" is not supported when creating a volume. flexvol ‐ flexible volumes and FlexClone volumes flexgroup ‐ FlexGroup volumes flexgroup_constituent ‐ FlexGroup volume constituents.
svm
svm
tiering
tiering
type
string
Type of the volume. rw ‐ read-write volume. dp ‐ data-protection volume. ls ‐ load-sharing dp volume. Valid in GET.
use_mirrored_aggregates
boolean
Specifies whether mirrored aggregates are selected when provisioning a FlexGroup without specifying "aggregates.name" or "aggregates.uuid". Only mirrored aggregates are used if this parameter is set to 'true' and only unmirrored aggregates are used if this parameter is set to 'false'. Aggregate level mirroring for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. The default value is 'true' for a MetroCluster configuration and is 'false' for a non-MetroCluster configuration.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
validate_only
boolean
Validate the volume move or volume conversion operations and their parameters, without actually performing the operation.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
