REST API reference
Create an event destination
Creates an event destination to specify where notifications should be sent when particular events occur. This helps you manage and streamline event handling in your system.
HTTP method and endpoint
POST /support/ems/destinations
Introduced in
ONTAP 9.6
Required properties
  • name - String that uniquely identifies the destination.
  • type - Type of destination that is to be created.
  • destination - String that identifies the destination. The contents of this property changes depending on type.
  • filters.name - List of filter names that should direct to this destination.
  • certificate - When specifying a rest api destination, a client certificate can be provided.
  • event notification destination create
  • event notification create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
certificate
certificate
Certificate information is valid for the "rest_api" type.
destination
string
Event destination
filters
array[filters]
name
string
Destination name. Valid in POST.
system_defined
boolean
Flag indicating system-defined destinations.
type
string
Type of destination. Valid in POST.
Example request
  "certificate": {
    "ca": "VeriSign",
    "serial_number": "1234567890"
  "destination": "administrator@mycompany.com",
  "filters": [
      "name": "important-events"
  "name": "Admin_Email",
  "system_defined": 1,
  "type": "email"
Status: 201, Created
num_records
integer
Number of records
records
array[records]
  "num_records": 3,
  "records": [
      "certificate": {
        "ca": "VeriSign",
      "filters": [
      "type": "email"
Status: Default
ONTAP Error Response Codes
Error Code Description
983088
The destination name provided cannot be empty
983089
The destination name provided cannot contain spaces
983094
The destination name provided is invalid. The destination name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or _(underscore). The allowed special characters are _(underscore) and -(hyphen)
983104
The syslog destination provided is invalid
983116
The number of notifications has reached maximum capacity
983117
The number of destinations has reached maximum capacity
983129
The rest-api destination provided must contain a valid scheme, such as http// or https//
983130
The rest-api destination provided contains an invalid URL
983131
The rest-api destination provided contains an invalid IPv6 URL
983144
The security certificate information provided is incomplete. Provide the certificate and serial number
983145
The rest-api destination provided has an 'http://' scheme. It is invalid to provide certificate information
983149
New SNMP destinations cannot be created
983151
A property provided cannot be configured on the requested destination type
983152
Default destinations cannot be modified or removed
983153
The security certificate provided does not exist
983154
The necessary private key is not installed on the system
string
certificate
ca
string
Client certificate issuing CA
serial_number
string
Client certificate serial number
filters
name
string
ems_destination
certificate
certificate
destination
string
Event destination
filters
array[filters]
name
string
system_defined
boolean
type
string
records
certificate
certificate
destination
string
Event destination
filters
array[filters]
name
string
system_defined
boolean
type
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
