Create an event destination
Creates an event destination to specify where ONTAP sends event notifications. Use this to configure how you receive alerts and manage event tracking effectively.
HTTP method and endpoint
POST /support/ems/destinations
Introduced in
ONTAP 9.6
Required properties
name- String that uniquely identifies the destination. -
type- Type of destination that is to be created. -
destination- String that identifies the destination. The contents of this property changes depending on type.
Recommended optional properties
filters.name- List of filter names that should direct to this destination. -
certificate- When specifying a rest api destination, a client certificate can be provided.
Related ONTAP commands
event notification destination create -
event notification create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
certificate |
Certificate information is valid for the "rest_api" type. |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
Destination name. Valid in POST. |
type |
string |
Type of destination. Valid in POST. |
Example request
"certificate": {
"ca": "VeriSign",
"serial_number": "1234567890"
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"name": "Admin_Email",
"type": "email"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": "3",
"records": [
"certificate": {
"ca": "VeriSign",
"filters": [
"type": "email"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088 |
The destination name provided cannot be empty |
983089 |
The destination name provided cannot contain spaces |
983094 |
The destination name provided is invalid. The destination name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or _(underscore). The allowed special characters are _(underscore) and -(hyphen) |
983104 |
The syslog destination provided is invalid |
983116 |
The number of notifications has reached maximum capacity |
983117 |
The number of destinations has reached maximum capacity |
983129 |
The rest-api destination provided must contain a valid scheme, such as http// or https// |
983130 |
The rest-api destination provided contains an invalid URL |
983131 |
The rest-api destination provided contains an invalid IPv6 URL |
983144 |
The security certificate information provided is incomplete. Provide the certificate and serial number |
983145 |
The rest-api destination provided has an 'http://' scheme. It is invalid to provide certificate information |
983149 |
New SNMP destinations cannot be created |
983151 |
A property provided cannot be configured on the requested destination type |
983152 |
Default destinations cannot be modified or removed |
983153 |
The security certificate provided does not exist |
983154 |
The necessary private key is not installed on the system |
href |
string |
_links
certificate
ca |
string |
Client certificate issuing CA |
serial_number |
string |
Client certificate serial number |
filters
name |
string |
ems_destination
certificate |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
type |
string |
records
certificate |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
type |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
