Create an event destination
POST /support/ems/destinations
Creates an event destination.
Required properties
name- String that uniquely identifies the destination. -
type- Type of destination that is to be created. -
destination- String that identifies the destination. The contents of this field changes depending on type.
Recommended optional properties
filters.name- List of filter names that should direct to this destination. -
certificate- When specifying a rest api destination, a client certificate can be provided.
Related ONTAP commands
event notification destination create -
event notification create
Learn more
Request Body
| Name | Type | Description |
_links |
certificate |
Certificate information is valid for the "rest_api" type. |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
Destination name. Valid in POST. |
type |
string |
Type of destination. Valid in POST. |
Example request
"href": "/api/resourcelink"
"certificate": {
"ca": "VeriSign",
"serial_number": 1234567890
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"name": "Admin_Email",
"type": "email"
Status: 201, Created
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"num_records": 3,
"records": [
"certificate": {
"ca": "VeriSign",
"filters": [
"type": "email"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088 |
The destination name provided cannot be empty |
983089 |
The destination name provided cannot contain spaces |
983094 |
The destination name provided is invalid. The destination name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or _(underscore). The allowed special characters are _(underscore) and -(hyphen) |
983104 |
The syslog destination provided is invalid |
983116 |
The number of notifications has reached maximum capacity |
983117 |
The number of destinations has reached maximum capacity |
983129 |
The rest-api destination provided must contain a valid scheme, such as http// or https// |
983130 |
The rest-api destination provided contains an invalid URL |
983131 |
The rest-api destination provided contains an invalid IPv6 URL |
983144 |
The security certificate information provided is incomplete. Provide the certificate and serial number |
983145 |
The rest-api destination provided has an 'http://' scheme. It is invalid to provide certificate information |
983149 |
New SNMP destinations cannot be created |
983151 |
A property provided cannot be configured on the requested destination type |
983152 |
Default destinations cannot be modified or removed |
983153 |
The security certificate provided does not exist |
983154 |
The necessary private key is not installed on the system |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
ca |
string |
Client certificate issuing CA |
serial_number |
string |
Client certificate serial number |
filters
_links |
name |
string |
ems_destination
_links |
certificate |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
type |
string |
_links
next |
self |
records
_links |
certificate |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
type |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
