REST API reference
Create an event destination
Creates an event destination, specifying necessary properties like name and type to define where and how event notifications are sent. This setup helps direct event notifications to desired locations for monitoring or logging purposes.
HTTP method and endpoint
POST /support/ems/destinations
Introduced in
ONTAP 9.6
Required properties
  • name - String that uniquely identifies the destination.
  • type - Type of destination that is to be created.
  • destination - String that identifies the destination. The contents of this property changes depending on type.
  • filters.name - List of filter names that should direct to this destination.
  • certificate - When specifying a rest api destination, a client certificate can be provided.
  • syslog - When specifying a syslog destination, a port, transport protocol, message format, timestamp format and hostname format can be provided.
  • event notification destination create
  • event notification create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
certificate
certificate
Specifies the client-side certificate used by the ONTAP system when mutual authentication is required. This object is only applicable for rest_api type destinations. Both the ca and serial_number fields must be specified when configuring a certificate in a PATCH or POST request. The name field is read-only and cannot be used to configure a client-side certificate.
  • Introduced in: 9.6
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
name
string
Destination name. Valid in POST.
syslog
syslog
system_defined
boolean
Flag indicating system-defined destinations.
type
string
Type of destination. Valid in POST.
Example request
  "certificate": {
    "ca": "VeriSign",
    "name": "cert1",
    "serial_number": 1234567890
  "connectivity": {
    "errors": [
        "message": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "message": "entry doesn't exist"
        "node": {
          "name": "node1",
    "state": "fail"
  "destination": "administrator@mycompany.com",
  "filters": [
      "name": "important-events"
  "name": "Admin_Email",
  "syslog": {
    "format": {
      "hostname_override": "string",
      "message": "string",
      "timestamp_override": "string"
    "port": 514,
    "transport": "string"
  "system_defined": 1,
  "type": "email"
Status: 201, Created
num_records
integer
Number of records
records
array[records]
  "num_records": 1,
  "records": [
      "certificate": {
        "ca": "VeriSign",
        "name": "cert1",
      "connectivity": {
        "errors": [
            "message": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
            "node": {
              "name": "node1",
        "state": "fail"
      "filters": [
      "syslog": {
        "format": {
        "port": 514,
      "type": "email"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
983104
The syslog destination provided is invalid
983107
A provided filter does not exist
983116
The number of notifications has reached maximum capacity
983117
The number of destinations has reached maximum capacity
983129
The rest-api destination provided must contain a valid scheme, such as http// or https//
983130
The rest-api destination provided contains an invalid URL
983131
The rest-api destination provided contains an invalid IPv6 URL
983144
The security certificate information provided is incomplete. Provide the certificate and serial number
983145
The rest-api destination provided has an 'http://' scheme. It is invalid to provide certificate information
983149
New SNMP destinations cannot be created
983152
Default destinations cannot be modified or removed
983153
The security certificate provided does not exist
983154
The necessary private key is not installed on the system
983170
Connectivity check is not supported for the specified destination type on the node
983171
Connectivity check failed for the specified destination on the node
983176
Connectivity check is only supported for TCP-based syslog destinations
983179
The value for the destination field cannot be empty
983180
The destination name provided cannot be empty
983181
The destination name provided cannot contain spaces
983182
The destination name provided is invalid. The destination name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or _(underscore). The allowed special characters are _(underscore) and -(hyphen)
983184
A provided property cannot be configured on the requested destination type
983200
Access control role compatibility issue with provided filters
string
access_control_role
Indicates the access control role that created the event destination and is used to control access to the destination based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset.
_links
_links
name
string
Role name
certificate
_links
_links
ca
string
Client certificate issuing CA
name
string
Certificate name
serial_number
string
Client certificate serial number
arguments
code
string
Argument code
message
string
Message argument
message
arguments
array[arguments]
Message arguments
code
string
Unique message code.
message
string
User message.
node
name
string
uuid
string
errors
Error object included in the event of connectivity failure.
message
message
node
node
connectivity
errors
array[errors]
A list of errors encountered during connectivity checks.
state
string
Current connectivity state.
filters
name
string
format
hostname_override
string
Syslog Hostname Format Override. The supported hostname formats are no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp), fqdn (Fully Qualified Domain Name) and hostname_only.
message
string
Syslog Message Format. The supported message formats are legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG) and rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG).
timestamp_override
string
Syslog Timestamp Format Override. The supported timestamp formats are no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424), rfc_3164 (format: Mmm dd hh:mm:ss), iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm) and iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ).
syslog
format
format
port
integer
Syslog Port.
transport
string
Syslog Transport Protocol.
ems_destination
certificate
certificate
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
name
string
syslog
syslog
system_defined
boolean
type
string
access_control_role
name
string
Role name
records
certificate
certificate
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
name
string
syslog
syslog
system_defined
boolean
type
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
