Create an SVM migration operation
Creates an SVM migration operation on the destination cluster to transfer an SVM while preserving its identity from the source cluster. This operation allows you to specify aggregates for volume creation and perform pre-checks to ensure migration readiness.
HTTP method and endpoint
POST /svm/migrations
Introduced in
ONTAP 9.10
Usage notes
This API must be executed on the destination cluster. This API creates an SVM on the destination cluster and preserves the SVM's identity specified in the source cluster. Optionally, you can specify the aggregate list for creating the volumes, and IPspace. You can perform pre-checks to verify if SVM migration is possible, by setting the "check-only" option to "true". By default the values for auto-source-cleanup and auto-cutover is true.
Required properties
source.svm.nameorsource.svm.uuid- Source SVM name or source SVM UUID. -
source.cluster.nameorsource.cluster.uuid- Source cluster name or source cluster UUID
Optional properties
destination.ipspace.nameordestination.ipspace.uuid- Destination IP Space name or UUID where the vserver will be migrated to. -
destination.volume_placement.aggregates- List of aggregates where the migrating volumes should go on destination. -
auto_cutover- Option to specify whether to perform cutover automatically. Default is true. -
auto_source_cleanup- Option to specify whether to perform souce cleanup automatically. Default is true. -
check_only- Option to perform all the prechecks for migrate without actually starting the migrate. Default is false.
Related ONTAP commands
vserver migrate start
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
auto_cutover |
boolean |
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover". |
auto_source_cleanup |
boolean |
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover. |
check_only |
boolean |
Optional property that when set to true performs only migration pre-checks not the actual migration. |
current_operation |
string |
destination |
Destination cluster details for the SVM migration. |
last_failed_state |
string |
Indicates the state of the migration. |
last_operation |
string |
messages |
array[messages] |
Errors and warnings returned/displayed during migration. |
point_of_no_return |
boolean |
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted. |
restart_count |
integer |
Number of times SVM migration was restarted since initially started. |
source |
Source cluster details for the SVM migration. |
state |
string |
time_metrics |
Various time metrics details |
uuid |
string |
SVM migration UUID |
Example request
"current_operation": "string",
"destination": {
"ipspace": {
"name": "exchange",
"volume_placement": {
"aggregates": [
"name": "aggr1",
"last_failed_state": "string",
"last_operation": "string",
"messages": [
"message": "string"
"restart_count": 0,
"source": {
"cluster": {
"name": "cluster1",
"svm": {
"name": "svm1",
"state": "string",
"time_metrics": {
"cutover_complete_time": "2020-12-02T19:30:19-08:00",
"cutover_start_time": "2020-12-02T18:20:19-08:00",
"cutover_trigger_time": "2020-12-02T19:15:19-08:00",
"end_time": "2020-12-02T19:36:19-08:00",
"last_pause_time": "2020-12-02T18:50:19-08:00",
"last_resume_time": "2020-12-02T18:54:19-08:00",
"start_time": "2020-12-02T18:36:19-08:00"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262245 |
The value provided is invalid. |
13172746 |
SVM migration cannot be started. This is a generic code, see the response message for details. |
href |
string |
_links
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
aggregates
Aggregate
name |
string |
uuid |
string |
volume_placement
Optional property to specify the source volume placement in the destination.
aggregates |
array[aggregates] |
Optional property used to specify the list of desired aggregates to use for volume creation in the destination. |
destination
ipspace |
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used. |
volume_placement |
Optional property to specify the source volume placement in the destination. |
messages
Specifies failure codes and messages.
code |
integer |
Message code |
message |
string |
Detailed message of warning or error. |
cluster
Source cluster for the SVM migration.
name |
string |
uuid |
string |
svm
Source SVM
name |
string |
The name of the SVM. |
uuid |
string |
source
cluster |
Source cluster for the SVM migration. |
svm |
Source SVM |
time_metrics
cutover_complete_time |
string |
Cutover end time |
cutover_start_time |
string |
Cutover start time |
cutover_trigger_time |
string |
Cutover trigger time |
end_time |
string |
Migration end time |
last_pause_time |
string |
Last migration pause time |
last_resume_time |
string |
Last migration resume time |
start_time |
string |
Migration start time |
svm_migration
Provides information on SVM migration, default and user specified configurations, the state of the migration, and volume transfer metrics.
auto_cutover |
boolean |
boolean |
check_only |
boolean |
current_operation |
string |
destination |
last_failed_state |
string |
last_operation |
string |
messages |
array[messages] |
boolean |
restart_count |
integer |
source |
state |
string |
time_metrics |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
