REST API reference
Create an SVM migration operation
Initiates a migration operation for a Storage Virtual Machine (SVM) to a destination cluster, preserving its identity from the source cluster. This operation is useful when you want to seamlessly transfer an SVM while maintaining its configuration and identity.
HTTP method and endpoint
POST /svm/migrations
Introduced in
ONTAP 9.10
Usage notes
Creates an SVM migration operation. This API must be executed on the destination cluster. This API creates an SVM on the destination cluster and preserves the SVM's identity specified in the source cluster. Optionally, you can specify the aggregate list for creating the volumes, and IPspace. You can perform pre-checks to verify if SVM migration is possible, by setting the "check-only" option to "true". By default the values for auto-source-cleanup and auto-cutover is true.
Required properties
  • source.svm.name or source.svm.uuid - Source SVM name or source SVM UUID.
  • source.cluster.name or source.cluster.uuid - Source cluster name or source cluster UUID
Optional properties
  • destination.ipspace.name or destination.ipspace.uuid - Destination IP Space name or UUID where the SVM will be migrated to.
  • destination.volume_placement.aggregates - List of aggregates where the migrating volumes should go on the destination.
  • destination.volume_placement.volume_aggregate_pairs - List of volume aggregate pairs indicating where the migrating volumes should go on the destination.
  • ip_interface_placement - List of source SVM's IP interface and port pairs on the destination for migrating the SVM's IP interfaces.
  • auto_cutover - Option to specify whether to perform cutover automatically. Default is true.
  • auto_source_cleanup - Option to specify whether to perform source cleanup automatically. Default is true.
  • check_only - Option to perform all the prechecks for migrate without actually starting the migrate. Default is false.
  • throttle - Option to specify a throttle value in KB/s. Defaults to unlimited.
  • vserver migrate start
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
auto_cutover
boolean
Optional property that when set to true automatically performs cutover when the migration state reaches "ready for cutover".
auto_source_cleanup
boolean
Optional property that when set to true automatically cleans up the SVM on the source cluster after the migration cutover.
check_only
boolean
Optional property that when set to true performs only migration pre-checks not the actual migration.
current_operation
string
destination
destination
Destination cluster details for the SVM migration.
svm_migration_ip_interface_placement
Optional property used to specify the list of source SVM's IP interface and network port pairs in the destination for migrating the source SVM IP interfaces. Note that the SVM migration does not perform any reachability checks on the IP interfaces provided.
last_failed_state
string
Indicates the state of the migration.
last_operation
string
messages
array[messages]
Errors and warnings returned/displayed during migration.
point_of_no_return
boolean
Indicates if the migration has progressed beyond the point of no return. When true, the migration cannot be aborted or paused. When false, the migration can be paused or aborted.
post_ponr_retry_count
integer
Number of times the migration restarted after the point of no return.
restart_count
integer
Number of times migrate restarted the transfer, for example, rollback to transfer after starting the cutover.
source
source
Source cluster details for the SVM migration.
state
string
throttle
integer
Optional property to specify a throttle value in KB/s for each individual volume transfer. Defaults to 0 if not set, which is interpreted as unlimited. The minimum throttle value is 4 KB/s, so if you specify a throttle value between 1 and 4, it will be treated as if you specified 4.
time_metrics
time_metrics
Various time metrics details
uuid
string
SVM migration UUID
Example request
  "current_operation": "string",
  "destination": {
    "ipspace": {
      "name": "Default",
    "volume_placement": {
      "aggregates": [
          "name": "aggr1",
      "volume_aggregate_pairs": [
          "aggregate": {
            "name": "aggr1",
          "volume": {
            "name": "volume1",
  "ip_interface_placement": {
    "ip_interfaces": [
        "interface": {
          "name": "lif1",
        "port": {
          "name": "e1b",
          "node": {
            "name": "node1"
  "last_failed_state": "string",
  "last_operation": "string",
  "messages": [
      "code": "string",
      "message": "string"
  "post_ponr_retry_count": 0,
  "restart_count": 0,
  "source": {
    "cluster": {
      "name": "cluster1",
    "svm": {
      "name": "svm1",
  "state": "string",
  "throttle": 0,
  "time_metrics": {
    "cutover_complete_time": "2020-12-02 19:30:19 -0800",
    "cutover_start_time": "2020-12-02 18:20:19 -0800",
    "cutover_trigger_time": "2020-12-02 19:15:19 -0800",
    "end_time": "2020-12-02 19:36:19 -0800",
    "last_pause_time": "2020-12-02 18:50:19 -0800",
    "last_post_ponr_retry_time": "2020-12-02 19:30:19 -0800",
    "last_resume_time": "2020-12-02 18:54:19 -0800",
    "start_time": "2020-12-02 18:36:19 -0800"
Status: 202, Accepted
job
job_link
num_records
integer
Number of records
records
array[svm_migration]
  "job": {
    "uuid": "string"
  "num_records": 1,
  "records": [
      "destination": {
        "ipspace": {
          "name": "Default",
          "aggregates": [
              "name": "aggr1",
              "aggregate": {
                "name": "aggr1",
              "volume": {
                "name": "volume1",
        "ip_interfaces": [
            "interface": {
              "name": "lif1",
            "port": {
              "name": "e1b",
              "node": {
                "name": "node1"
      "messages": [
          "code": "string",
          "message": "string"
      "restart_count": 0,
      "source": {
        "cluster": {
          "name": "cluster1",
        "svm": {
          "name": "svm1",
      "state": "string",
      "throttle": 0,
      "time_metrics": {
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
262245
The value provided is invalid.
13172746
SVM migration cannot be started. This is a generic code, see the response message for details.
13173748
Migrate request cannot contain both \"aggregates\" and \"volume_aggregate_pairs\" within the \"volume_placement\" object.
13173758
The property \"{property}\" is not supported for this operation.
13173759
Migrate operation failed. To use LIF placement specify either the port UUID, or both the port name and the port node name.
13173760
Migrate operation failed. LIF placement requires either the port node name or the port UUID to be specified if the port name is specified.
13173761
Migrate operation failed. LIF placement requires either the port name or the port UUID to be specified if the port node name is specified.
13173762
Migrate operation failed. To use LIF placement specify at least one of the following: IP interface UUID, IP interface name, or IP interface IP.
13173764
Migrate operation failed because LIF placement is not supported on the destination cluster. Both clusters must have an effective cluster version of 9.12.1 or later.
13173765
Migrate operation failed. Unable to determine if LIF placement is supported. Reason: \"{Reason}\"
string
ipspace
Optional property used to specify which IPspace to use for the SVM. By default, the "default" ipspace is used.
name
string
IPspace name
uuid
string
IPspace UUID
aggregates
Aggregate
name
string
uuid
string
aggregate
Aggregate to use for volume creation.
name
string
uuid
string
volume
Property indicating the source volume.
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
Volume-aggregate pair information.
aggregate
aggregate
volume
volume
volume_placement
Optional property to specify the source volume placement in the destination. It is input only and won't be returned by a subsequent GET. Volume placement is ignored if the migration resumes from the cleanup_failed state.
aggregates
array[aggregates]
Optional property used to specify the list of desired aggregates to use for volume creation in the destination.
array[volume_aggregate_pairs]
Optional property used to specify the list of desired volume-aggregate pairs in the destination.
destination
ipspace
ipspace
volume_placement
volume_placement
ip
IP information
interface
Network interface on the source SVM.
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
node
name
string
Name of node on which the port is located.
port
Port to use for IP interface placement on the destination SVM.
name
string
node
node
uuid
string
ip_interfaces
IP interface and network port pair information.
interface
interface
port
port
ip_interfaces
array[ip_interfaces]
List of source SVM's IP interface and port pairs on the destination for migrating the source SVM's IP interfaces.
messages
code
string
Argument code
message
string
Message argument
cluster
Source cluster for the SVM migration.
name
string
uuid
string
svm
Source SVM
name
string
uuid
string
source
cluster
cluster
svm
svm
Source SVM
time_metrics
string
Cutover end time
cutover_start_time
string
Cutover start time
string
Cutover trigger time
end_time
string
Migration end time
last_pause_time
string
Last migration pause time
string
Last post point of no return retry time
last_resume_time
string
Last migration resume time
start_time
string
Migration start time
svm_migration
Provides information on SVM migration, default and user specified configurations, the state of the migration, and volume transfer metrics.
auto_cutover
boolean
auto_source_cleanup
boolean
check_only
boolean
current_operation
string
destination
destination
last_failed_state
string
last_operation
string
messages
array[messages]
point_of_no_return
boolean
integer
restart_count
integer
source
source
state
string
throttle
integer
time_metrics
time_metrics
uuid
string
SVM migration UUID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
