ONTAP REST API Support endpoints
Overview
You can use ONTAP support APIs to manage configuration backups, autosupport settings, and event handling.
Configuration backups
Configuration backups are copies of node and cluster settings saved to an external server. Single-node clusters must have configuration backups as protection against corruption of the configuration database. Multi-node clusters back up the configuration automatically between the nodes in the cluster.
