REST API reference
ONTAP REST API support endpoints
Use ONTAP support APIs to manage configuration backups, autosupport settings, and event handling. Configuration backups protect node and cluster settings by saving copies to an external server, ensuring data integrity in single-node clusters.
Overview
You can use ONTAP support APIs to manage configuration backups, autosupport settings, and event handling.
Configuration backups are copies of node and cluster settings saved to an external server. Single-node clusters must have configuration backups as protection against corruption of the configuration database. Multi-node clusters back up the configuration automatically between the nodes in the cluster.
