ONTAP REST API support endpoints
Utilize the support endpoints to manage configuration backups, autosupport settings, and handle events effectively. These APIs help ensure your system's configuration remains protected and that events are reported accurately for timely troubleshooting and support.
Overview
You can use ONTAP support APIs to manage configuration backups, autosupport settings, and event handling.
Configuration backups
Configuration backups are copies of node and cluster settings saved to an external server. Single-node clusters must have configuration backups as protection against corruption of the configuration database. Multi-node clusters back up the configuration automatically between the nodes in the cluster.
Event Management System (EMS)
The Event Management System (EMS) collects and processes events, and sends notification of the events through various reporting mechanisms.
The following example configures EMS to send a support email when a WAFL event is observed with a severity of error, alert, or emergency.
Configuring the system-wide email parameters
# The API:
PATCH /support/ems
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_config_patch.txt"
test_ems_config_patch.txt(body):
"mail_from": "administrator@mycompany.com",
"mail_server": "smtp@mycompany.com"
# The response:
200 OK
Configuring a filter with an enclosed rule
# The API:
POST /support/ems/filters
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_post.txt"
test_ems_filters_post.txt(body):
"name": "error-wafl",
"rules": [
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "wafl.*",
"severities": "emergency,alert,error"
# The response:
201 Created
Setting up an email destination
# The API:
POST /support/ems/destinations
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_dest_post.txt"
test_ems_dest_post.txt(body):
"name": "Technician_Email",
"type": "email",
"destination": "technician@mycompany.com",
"filters": [
{ "name" : "error-wafl" }
# The response:
201 Created
