REST API reference
Delete a node from a cluster
Deletes a node from a cluster when you need to remove it and its associated resources. Ensure that all shared resources are shut down before proceeding to prevent failures.
HTTP method and endpoint
DELETE /cluster/nodes/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Note that before deleting a node from the cluster, you must shut down all of the node's shared resources, such as virtual interfaces to clients. If any of the node's shared resources are still active, the command fails.
Optional parameters:
  • force - Forcibly removes a node that is down and cannot be brought online to remove its shared resources. This flag is set to "false" by default.
  • cluster remove-node
Learn more
uuid
string
path
True
force
boolean
query
False
Set the force flag to "true" to forcibly remove a node that is down and cannot be brought online to remove its shared resources.
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
458755
Replication service is offline.
458758
Failed to load job for cluster remove node operation as the job exists.
1179732
Cannot remove a node in a single-node cluster.
1179735
Node is not part of a cluster.
1182805
Cannot remove a node from the node network address of the node to be removed.
2293765
Removing a node only works for nodes not in failover configuration.
2293767
Node has volumes. Either move or delete them from the node before removing the node.
2293768
Node is the home node for one or more logical interfaces.
2293769
Node is the current node for one or more logical interfaces.
2293770
Node has data logical interfaces configured as target node.
2293789
Removing a node only works for nodes not in HA configuration.
2293796
Cluster ring is offline on the node
2293798
Cannot forcibly remove a node that is online.
2293800
Node is configured with MetroCluster.
2293801
Cannot remove node because it has foreign LUN Imports.
2293812
Node is a member of MetroCluster DR group.
2293813
Cannot remove a node from the cluster because a controller replacement is in progress.
2293814
The DELETE operation is not supported until the cluster is upgraded.
2293816
Cannot remove node because its Storage Encryption devices use authentication keys (AKs) that will not be available to the node after it leaves the cluster.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
