Delete a node from a cluster
DELETE /cluster/nodes/{uuid}
Introduced In: 9.7
Deletes a node from the cluster. Note that before deleting a node from the cluster, you must shut down all of the node's shared resources, such as virtual interfaces to clients. If any of the node's shared resources are still active, the command fails.
Optional parameters:
force- Forcibly removes a node that is down and cannot be brought online to remove its shared resources. This flag is set to "false" by default.
Related ONTAP commands
cluster remove-node
Learn more
uuid |
string |
path |
True |
force |
boolean |
query |
False |
Set the force flag to "true" to forcibly remove a node that is down and cannot be brought online to remove its shared resources.
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
458755 |
Replication service is offline. |
458758 |
Failed to load job for cluster remove node operation as the job exists. |
1179732 |
Cannot remove a node in a single-node cluster. |
1179735 |
Node is not part of a cluster. |
1179848 |
Operation not supported at the current effective cluster version. |
1179849 |
Operation failed because the effective cluster version could not be verified. |
1182805 |
Cannot remove a node from the node network address of the node to be removed. |
2293765 |
Removing a node only works for nodes not in failover configuration. |
2293767 |
Node has volumes. Either move or delete them from the node before removing the node. |
2293768 |
Node is the home node for one or more logical interfaces. |
2293769 |
Node is the current node for one or more logical interfaces. |
2293770 |
Node has data logical interfaces configured as target node. |
2293787 |
Cannot remove node a node with epsilon. |
2293788 |
Failed to check HA configuration in the cluster. |
2293789 |
Removing a node only works for nodes not in HA configuration. |
2293790 |
Failed to check if the node has epsilon. |
2293796 |
Cluster ring is offline on the node |
2293798 |
Cannot forcibly remove a node that is online. |
2293800 |
Node is configured with MetroCluster. |
2293801 |
Cannot remove node because it has foreign LUN Imports. |
2293812 |
Node is a member of MetroCluster DR group. |
2293813 |
Cannot remove a node from the cluster because a controller replacement is in progress. |
2293814 |
The DELETE operation is not supported until the cluster is upgraded. |
2293816 |
Cannot remove node because its Storage Encryption devices use authentication keys (AKs) that will not be available to the node after it leaves the cluster. |
2293821 |
Cannot remove a node that is offline. |
2293842 |
A node can only be removed if all of its aggregates are home. |
2293843 |
Cannot determine if all aggregates belonging to the node to be removed are home. |
2293844 |
Cannot determine if storage failover is enabled. |
10551347 |
An update is in progress. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
