Delete a node from a cluster
Deletes a node from the cluster when you need to remove it permanently. Ensure all shared resources are shut down before proceeding to avoid command failure.
HTTP method and endpoint
DELETE /cluster/nodes/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Note that before deleting a node from the cluster, you must shut down all of the node's shared resources, such as virtual interfaces to clients. If any of the node's shared resources are still active, the command fails.
Optional parameters:
force- Forcibly removes a node that is down and cannot be brought online to remove its shared resources. This flag is set to "false" by default.
Related ONTAP commands
cluster remove-node
Learn more
uuid |
string |
path |
True |
force |
boolean |
query |
False |
Set the force flag to "true" to forcibly remove a node that is down and cannot be brought online to remove its shared resources.
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
458755 |
Replication service is offline. |
458758 |
Failed to load job for cluster remove node operation as the job exists. |
1179732 |
Cannot remove a node in a single-node cluster. |
1179735 |
Node is not part of a cluster. |
1182805 |
Cannot remove a node from the node network address of the node to be removed. |
2293765 |
Removing a node only works for nodes not in failover configuration. |
2293767 |
Node has volumes. Either move or delete them from the node before removing the node. |
2293768 |
Node is the home node for one or more logical interfaces. |
2293769 |
Node is the current node for one or more logical interfaces. |
2293770 |
Node has data logical interfaces configured as target node. |
2293789 |
Removing a node only works for nodes not in HA configuration. |
2293796 |
Cluster ring is offline on the node |
2293798 |
Cannot forcibly remove a node that is online. |
2293800 |
Node is configured with MetroCluster. |
2293801 |
Cannot remove node because it has foreign LUN Imports. |
2293812 |
Node is a member of MetroCluster DR group. |
2293813 |
Cannot remove a node from the cluster because a controller replacement is in progress. |
2293814 |
The DELETE operation is not supported until the cluster is upgraded. |
2293816 |
Cannot remove node because its Storage Encryption devices use authentication keys (AKs) that will not be available to the node after it leaves the cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
