Delete the HTTP proxy configuration for an SVM or cluster IPspace
Deletes the HTTP proxy configuration for a specified SVM or cluster IPspace, removing the proxy settings from the network configuration.
HTTP method and endpoint
DELETE /network/http-proxy/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Deletes the HTTP proxy configuration of the specified SVM or Cluster IPspace.
Related ONTAP commands
vserver http-proxy delete
uuid |
string |
path |
True |
HTTP proxy UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
138281013 |
The HTTP proxy cannot be deleted while in use by a cloud agent connection. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
