Delete HTTP proxy configuration for an SVM or cluster IPspace
DELETE /network/http-proxy/{uuid}
Introduced In: 9.7
Deletes the HTTP proxy configuration of the specified SVM or Cluster IPspace.
Related ONTAP commands
vserver http-proxy delete
uuid |
string |
path |
True |
HTTP proxy UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
138281013 |
The HTTP Proxy cannot be deleted while in use by a cloud agent connection. |
2621574 |
This operation is not permitted on a SVM that is configured as the destination of a Metrocluster SVM relationship. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
