REST API reference
Delete HTTP proxy configuration for an SVM or cluster IPspace
Deletes the HTTP proxy configuration for a specified SVM or Cluster IPspace, removing the associated proxy settings. Use this endpoint when you need to update or clear existing proxy configurations.
HTTP method and endpoint
DELETE /network/http-proxy/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Deletes the HTTP proxy configuration of the specified SVM or Cluster IPspace.
  • vserver http-proxy delete
uuid
string
path
True
HTTP proxy UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
138281013
The HTTP proxy cannot be deleted while in use by a cloud agent connection.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
