Delete a Kerberos realm
DELETE /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Introduced In: 9.6
Deletes a Kerberos realm.
vserver nfs kerberos realm delete
Learn more
svm.uuid  |
string  |
path  |
True  |
SVM UUID  |
name  |
string  |
path  |
True  |
Kerberos realm  |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error codes | Description |
1966125  |
Failed to remove hosts entry.  |
1966126  |
Failed to lookup hosts entry.  |
2949141  |
Failed to lookup Kerberos realm.  |
2949142  |
Failed to remove Kerberos realm.  |
3276942  |
Service principal name is invalid. It must of the format:"nfs/  |
3276976  |
"realm" is a required input  |
3276998  |
Only the data Vservers can own NFS Kerberos realms.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
