Delete a Kerberos realm
DELETE /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Introduced In: 9.6
Deletes a Kerberos realm.
vserver nfs kerberos realm delete
Learn more
svm.uuid |
string |
path |
True |
SVM UUID |
name |
string |
path |
True |
Kerberos realm |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error codes | Description |
1966125 |
Failed to remove hosts entry. |
1966126 |
Failed to lookup hosts entry. |
2949141 |
Failed to lookup Kerberos realm. |
2949142 |
Failed to remove Kerberos realm. |
3276942 |
Service principal name is invalid. It must of the format:"nfs/ |
3276976 |
"realm" is a required input |
3276998 |
Only the data Vservers can own NFS Kerberos realms. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
