REST API reference
Delete a Kerberos realm
Deletes a Kerberos realm to remove its configuration from the system. Use this when a realm is no longer needed or should not be part of your network setup.
HTTP method and endpoint
DELETE /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
  • vserver nfs kerberos realm delete
svm.uuid
string
path
True
SVM UUID
name
string
path
True
Kerberos realm
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error codes Description
1966125
Failed to remove hosts entry.
1966126
Failed to lookup hosts entry.
2949141
Failed to lookup Kerberos realm.
2949142
Failed to remove Kerberos realm.
3276942
Service principal name is invalid. It must of the format:"nfs/@REALM\\\"
3276976
"realm" is a required input
3276998
Only the data Vservers can own NFS Kerberos realms.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
