REST API reference
Delete a data SVM configured as a tunnel
Removes a data SVM configured as a tunnel for Active Directory-based authentication, which is used for managing cluster user accounts.
HTTP method and endpoint
DELETE /security/authentication/cluster/ad-proxy
Introduced in
ONTAP 9.7
Usage notes
Deletes the data SVM configured as a tunnel for Active Directory based authentication for cluster user accounts.
  • security login domain-tunnel delete
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
