      Delete a data SVM configured as a tunnel
DELETE /security/authentication/cluster/ad-proxy
Introduced In: 9.7
Deletes the data SVM configured as a tunnel for Active Directory based authentication for cluster user accounts.
Related ONTAP commands
security login domain-tunnel delete
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
