REST API reference
Deletes the data svm configured as a tunnel for active directory based authentication for cluster user accounts
learn more
  • [doc /security/authentication/cluster/ad-proxy](#docs-security-security_authentication_cluster_ad-proxy)
  • [doc /security/accounts](#docs-security-security_accounts)
DELETE /security/authentication/cluster/ad-proxy
Introduced In: 9.7
Deletes the data SVM configured as a tunnel for Active Directory based authentication for cluster user accounts.
  • security login domain-tunnel delete
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
