REST API reference
Delete a Snapshot copy policy
Removes a Snapshot copy policy, eliminating it from the storage system configuration. Use this endpoint to manage and organize your Snapshot policies effectively, ensuring your storage environment remains optimized.
HTTP method and endpoint
DELETE /storage/snapshot-policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes a Snapshot copy policy
  • snapshot policy delete
uuid
string
path
True
Snapshot copy policy UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
1638415
Cannot delete policy. Reason: Policy is in use by at least one volume.
1638416
Cannot delete policy. Reason: Cannot verify whether policy is in use.
1638430
Cannot delete policy. Reason: Policy is in use by at least one Vserver.
1638430
Cannot delete built-in policy.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
