Delete a Snapshot copy policy
Deletes a Snapshot copy policy, removing the policy configuration from the system. Use this endpoint when you need to retire or replace outdated policies.
HTTP method and endpoint
DELETE /storage/snapshot-policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Related ONTAP commands
snapshot policy delete
Learn more
uuid |
string |
path |
True |
Snapshot copy policy UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Code
| Error Code | Description |
1638415 |
Cannot delete policy. Reason: Policy is in use by at least one volume. |
1638416 |
Cannot delete policy. Reason: Cannot verify whether policy is in use. |
1638430 |
Cannot delete policy. Reason: Policy is in use by at least one Vserver. |
1638431 |
Cannot delete built-in policy. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
