REST API reference
Delete a Snapshot copy policy
Deletes a Snapshot copy policy when you need to remove it from the system. Use this action to manage and optimize your Snapshot configurations.
HTTP method and endpoint
DELETE /storage/snapshot-policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
  • snapshot policy delete
uuid
string
path
True
Snapshot copy policy UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
1638415
Cannot delete policy. Reason: Policy is in use by at least one volume.
1638416
Cannot delete policy. Reason: Cannot verify whether policy is in use.
1638430
Cannot delete policy. Reason: Policy is in use by at least one Vserver.
1638430
Cannot delete built-in policy.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
