REST API reference
Delete an existing file or directory
Deletes an existing file or directory to remove unnecessary or outdated data from your system.
HTTP method and endpoint
DELETE /storage/volumes/{volume.uuid}/files/{path}
Introduced in
ONTAP 9.8
Usage notes
Query-based DELETE operations are not supported.
volume.uuid
string
path
True
Volume UUID
path
string
path
True
The relative path of a directory in the volume. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided.
recurse
boolean
query
False
Delete an entire directory. The behaviour of this call is equivalent to rm -rf.
  • Default value:
throttle_deletion
integer
query
False
The maximum number of directory delete operations per second. A valid throttle_deletion number is an integer from 10 to 100000.
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
131074
No such file or directory.
131102
Read-only file system.
131138
Directory not empty.
918235
A volume with UUID {volume.uuid} was not found.
6488081
The {field} field is not supported for DELETE operations.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
