REST API reference
Delete an existing file or directory
Deletes an existing file or directory, which is useful when you need to remove unnecessary data from your storage system.
HTTP method and endpoint
DELETE /storage/volumes/{volume.uuid}/files/{path}
Introduced in
ONTAP 9.8
Usage notes
Query-based DELETE operations are not supported.
volume.uuid
string
path
True
Volume UUID
path
string
path
True
The relative path of a directory in the volume. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided.
recurse
boolean
query
False
Delete an entire directory. The behaviour of this call is equivalent to rm -rf.
  • Default value:
throttle_deletion
integer
query
False
The maximum number of directory delete operations per second. A valid throttle_deletion number is an integer from 10 to 100000.
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
131074
No such file or directory.
131102
Read-only file system.
131138
Directory not empty.
918235
A volume with UUID {volume.uuid} was not found.
6488081
The {field} field is not supported for DELETE operations.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
